Advise on custom Ti frame
Looking into a custom Ti frame, I already have a steel one.
I have some questions regarding the head tube size and fork.
The options are 44mm and 34mm diameter head tube.
44mm allows internal headset and tapered fork.
34mm would use external cup headset.
In general I like the look of smaller tubes better and I am not sure I would need or benefit from a tapered fork, looking at using a Ritchey WCS fork which is a straight 1-1/8" fork so I am leaning towards a 34mm head tube.
I weigh 140 lbs. I am 65 years old and do not race, I usually ride at a moderate pace but do like to climb hills.
Thanks for any input.
Quoted: 4743 Post(s)
Liked 3,860 Times
I would put steerer and headtube dimensions fairly far down the list of what's important in a custom frame. For me, #1 - the builder, the bikes he favors building, and are we on the same page? #2 (closely related to #1) - the bike fit. #3 - do the details he prefers to build with work for me? I put head tube /steerer in this category. A lot of excellent bikes have been built around all the standards. (Look at all the great bikes built around 1" standard steerers and steel forks over the past century.)
Different builders vary a lot in how comfortable they are working outside their "normal" practices. Some will say "I do it this way. Go to someone else if you want different." Others view the same request as a challenge they love taking on.
Randomhead
Liked 3,664 Times
I don't like the looks of 44mm straight head tubes, but I think tapered head tubes look okay. I don't know if there are options other than Paragon for tapered Ti head tubes. Theirs are rather expensive. If I were buying a Ti bike, I think that's the way I would go anyway. Selection of tapered forks is much better than straight steerer forks.
Quoted: 4172 Post(s)
Liked 3,792 Times
I also don't like the mix of huge headtubes and skinny blades. Andy
AndrewRStewart
AndrewRStewart
