Larger Handlebar Bag for touring/randonneur trips - less expensive options
Quoted: 95 Post(s)
Liked 50 Times
I am now leaning toward mounting a small 1/8" thick aluminum plate (8"x10") on the canti mini-rack and then using this bag - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The belt strap mounting is more symmetrical than the other Shangri-La bag, and I think it will work well mounted to the stem tube.
iti biking
Probably somewhere between the Rene Herse and the Shangri-La options might be a Carradice saddlebag, attached to the bars and the head tube? If the side pockets make it too wide, you can either unpick them (good if you find one secondhand) or ask the factory nicely to make you one without them.
Quoted: 3452 Post(s)
Liked 1,452 Times
Will you be disappointed in the rain, or do you have a plan for rain days? A rain cover can be simple. I did not open the Amazon link so I do not know if one is included, if so, great. Mine did not come with a rain cover, I later bought one elsewhere, see photo.
Quoted: 95 Post(s)
Liked 50 Times
When you said stem tube, I assume you mean the frame head tube. I think 1/8 inch aluminum plate is a bit overkill, but it it works you could find something lighter later.
If you want large capacity at a reasonable cost consider some of the bikepacking front rolls/packs.
https://www.apidura.com/shop/backcou...andlebar-pack/
https://www.apidura.com/shop/expedition-handlebar-pack/
Ortlieb also has a new front bag that has an expanding roll top
https://www.ortlieb.com/en_us/handlebar-pack-qr
But IMO it's hard to beat the Classic Ortlieb front bag if you are going to be to touring through towns and cities
because of it's simplicity and Klick Fix quick release which allows you to take the bag with you for even the
shortest times you might be away from your bike.
https://www.campfirecycling.com/prod...201.html#specs
Palmer
Quoted: 1659 Post(s)
Liked 1,806 Times
Palmer
Liked 1,806 Times
Liked 1,452 Times
My old bag from the last century was designed for a quill stem, it did not fit on a threadless stem. I bought a piece of steel rod and bent it to fit for my old bag. Sprayed it black but a lot of the paint has chipped off of it.
Photos are over a decade ago from my first digital camera, a whopping three megapixels. (The memory card was measured in meg, not gb.)
