Campagnolo Athena 11-speed after 4 years: junk
Just over 4 years ago I reported how thrilled I was about my 1981 Trek 957 outfitted with new paint, new decals, new wheels with pretty silver rims, new leather bar tape, and new gorgeous silver Campagnolo Athena 11-speed components. (Silver unavailable in Record...I don't recall if silver Chorus was an option).
Since then I perhaps have 2500 miles on the bike always ridden in good weather.
Well in the past 2 weeks-- the rear brake caliper stopped returning. I managed to repair that with a deep clean and disassembly. Never had that happen in any of my other dirty/grimy bikes.
But then my left STI shifter started flaking out. I started to investigate by removing the cable and poof, a plastic part just flew off.
The plastic part appears deformed.
What junk. No idea if I'll find a replacement part.
My commuter is equipped with the cheapest Shimano 7-speed STI shifters which are holding up great after years of abuse, rain, dirt, etc.
Quoted: 1104 Post(s)
Liked 1,824 Times
Have a look at this link:
https://www.velocipedesalon.com/foru...ers-34788.html
Pay particular attention to the guy in the 2nd post. He's one of the most knowledgeable people on the planet about Campagnolo.
Quoted: 1607 Post(s)
Liked 2,216 Times
Check this out:
https://www.campagnolo.com/US/en/Support/support
What kind of warranty does Campagnolo give for its products?
Campagnolo guarantees its products for three years from the date of purchase.
Likes For old's'cool:
Quoted: 1856 Post(s)
Liked 664 Times
Likes For Road Fan:
Liked 664 Times
Her newer 2015 Terry has Athena 3x11, like yours, except that looks like a double compact CT crank in your picture. Mine is still actually a triple, and tuning it up has been an odyssey of several years. I've built a few other bikes with 3x10 systems, so I started to look at it. The shop that built the bike for us and collected the parts is now closed. We had balky shifting after a year, so I thought let's get our installation warrantee honored. It came back with the front mech not aligned properly and not shifting any better than it did before. I know from my previous triple and compact builds that the complex cages of the front derailleurs need to be positioned as Campy says, and it has taken a while to get it working correctly. Shifting down from big ring to middle was a problem, it would always jump to granny, and now it doesn't, it shifts well going down in sequence.
But I haven't had any failures like you showed, or any parts of an Ergo falling off. If you bought your components through a store in the Campagnolo channel, you might be eligible for some warranty coverage. I haven't seen any silver ones on Ebay, but occasionally there are black parts. If you're going to Shimano, I'd be interested in the derailleurs and possibly the compact chainset.
Likes For Road Fan:
I think I can still purchase 11-speed Potenza shifters that are compatible. I think I recall that UltraShift parts (Record, Chorus, etc) are not compatible in terms of cable pull?
Sorry to hear the Athena components aren't holding up after such a short period. I purposely selected Campy Super Record components on my first racing bike in the early 80s since it was race proven. I've ridden the same bike now for 35 years now and never had a problem with any of the components. The only parts I've replaced due to wear are the derailleur cables and brake pads. It still shifts flawlessly and brakes well.
1984 custom frame with Campy Super Record gruppo
Likes For Chubby715:
shockingly good looking bike!
that sucks, I have some athena 11 on my Zunow - so far have not had any serious issues... seems very finicky with cable housing to get it super smooth.. but otherwise. But I am also nearing the 4 year mark...
Quoted: 702 Post(s)
Liked 672 Times
Combining a shifter with a brake lever in one lightweight package would require plastic parts and extremely intricate and precise adjustment....seems like a recipe for failure. I don't know anything about them since I have always used DT shifters and non-aero levers. Much easier to maintain and repair I suppose.
Likes For branko_76:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
Looks like the screw backed out is all. Shouldn't it have had some blue retaining coating on the threads?
Can't it just be screwed back together, this time with a drop of blue LocTite on the screw threads?
Likes For dddd:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3883 Post(s)
Liked 6,476 Times
Be like Lance and use a down tube shifter for the front.
Likes For SurferRosa:
The white plastic piece has a slot to fit a metal piece that applies the cranking force. It is now somewhat deformed. It might still work if I can figure out how to put the spring back in it's place before rescrewing.
Liked 2,216 Times
Liked 664 Times
It can't be so impossible, it's been done by Campagnolo, Shimano, Sachs, SRAM, and Microshift, just for the ones I can easily think of.
Likes For Road Fan:
Liked 664 Times
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
This whole thread is pearl clutching, a couple minutes with google would give him his part and list a more than a few people that can fix it for a couple of 20's.
Likes For Germany_chris:
https://www.campagnolo.com/media/fil...5_part_A_1.pdf
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I've found the Campagnolo parts catalog, and they only show the major assembly as the replacement part. Basically the entire shifter. Yeah dude, I know I can replace the entire shifter.
Replacing the entire lever is a Shimano thing, again there are plenty of people all over the world that would fix it for $40 or less to include some people mentioned in this thread.
I did look at the second post . And the Campagnolo parts catalog does indicate that for Record shifters there are parts kits available that contain 8 individual parts. The Campagnolo parts catalog for Athena lists the entire assembly. Moreover I've checked resellers of individual Campagnolo shifter parts like https://www.modernbike.com/campagnolo-shifter-parts
But hey, I do plan on taking the shifter to a Campagnolo expert in a few days (Yellow Jersey bike shop which is a Campagnolo dealer and one of the best vintage and Campagnolo guys in all of the United States). And I suspect he can probably reassemble using the existing deformed white part in a way that functions. And if he tells me that "yeah, I can get a replacement part for that individual piece", I'll be the first to come back and tell you that YOU WERE RIGHT.
Quoted: 3808 Post(s)
Liked 6,681 Times
I think the problem is that you referred to them as STI in your original post, and they clearly got insulted in a made-in-Italy kind of way.
Fwiw, I’ve been running several sets of 10-speed and 11-speed Campy ergo grifters on various bikes, some for thousands of miles, and have never had a problem. I have 11-speed Potenza hydro on a new project, so I hope that holds true.
EDIT: Mine had vertical dropouts. components were a mixture of Zeus 2000 and SR (I liked the Zeus brakes and hubs).
Disciple of St. Tullio
Bikes: Ciöcc, Bianchi, DeRosa, Eddy Merckx, Frejus, Hampsten, Kondor, Losa, Magni, Pegoretti, Pelizzoli, Pogliaghi, Scapin
Quoted: 267 Post(s)
Liked 334 Times
That shifter is Powershift and yes, it's a poor design internally. The powershift design was changed at some point because the early design had problems. You could rebuild it if you find the part.
The smart thing to do is to buy used Ultrashift Ergos and transfer your silver brake and shift blades over to it. It will work fine with your Athena derailleurs, I have a bike with Athena that I shift with Chorus Ergos.
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
^^^^^ I had Peter rebuild my Chorus shifters that are now on my Masi build. Good guy to deal with and definitely knows his stuff. Turnaround was pretty quick too, faster than I expected and a very reasonable price too.
Dale, NL4T
Dale, NL4T
