7 speed hub spaced to fit 10 speed cassette - slight issue
I have a really nice NOS HG70 7 speed cassette I am trying to put on a 10 speed shimano XT hub. Looks like a 4mm spacer gives me the proper spacing. Issue I am running into is that the hub has (3) rivets behind the large cog that seat up against the spacers, they poke out maybe .5mm. Due to this, no matter how tight I get the cassette, it has very slight play, rocking back and forth since the the cassette is basically sitting on the those (3) rivets and not sitting flush on the spacers.
Wouldn't be a problem if using a 7-speed hub as the rivets would be sitting above the cassette flange.
Any thoughts? Pic below:
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
I ran into the same issue when using a 9-speed cassette on an 11-speed hub. The fix in my case was to find s spacer with notches for the cassette's rivets. Glancing at Google, it seems that there may be notched 4 mm spacers that'll do the trick for you.
Quoted: 86 Post(s)
or you can make three little indentations in a spacer yourself. a punch and a hammer might suffice. or a drill...
you might want to check that a four millimeter spacer is enough. if not, the lockring may be bottoming out before reaching the face of the cassette. i say this because i find it hard to understand how what is a essentially a three legged stool can rock, especially since it is being forced into a comparatively soft piece of plastic that should easily deform.
Bikes: 89 Schwinn 754, 90 Trek 1100, 93 Trek 2300, 94 Trek 1400 (under construction), 94 Trek 930, 97 Trek 1400
Quoted: 29 Post(s)
The three rivets are not spaced equally. Place the spacer on top of the cassette and mark the locations. A hammer and chisel, or screwdriver, or nailset will not provide enough control to accurately cut, or indent the spacer ring. Use a dremel tool with a cutting disc to notch the spacer deep enough to provide clearance (about 1/2 the thickness of the spacer) for the rivet heads.
Mark the spacer so you will know how to line it up when assembling it to the freehub so the notches will line back up with the cassette when you install it.
Quoted: 1438 Post(s)
Liked 1,092 Times
I just grind the rivets flush. They are there to keep the cogs together before assembly. Once the cassette has been mounted to the freehub they serve no purpose. There are notched spacers, which were mentioned in an earlier thread, available but I do not see the need for them. If you want to leave them and they are uneven, a few quick strokes with a file should even them up sufficiently.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Just grind divots into the spacer, then you don't have to mess with a stack of loose cogs whenever you service the wheel.
Quoted: 2026 Post(s)
Liked 1,095 Times
The rivets, or often small diameter bolts, are there to just make assembly easier and they provide no needed structural support, particularly if used on a steel or Ti freehub body. You can remove them by grinding off the heads or unscrewing them using a 1.5 mm (IIRC) hex key.
Another method is to put the spacer on after the entire cassette is installed and under the lockring. That works and bypasses the rivet/bolt interference. Done either way you will have to readjust the rear derailleurs limit screws.
BTW, the standard spacer is 4.5 mm.
Liked 2,563 Times
FWIW, I favor grinding rivet clearance into the spacer because it's a one-time thing. If you remove or grind off the rivets on the cassette, you'll need to do that again for each new cassette.
Liked 1,095 Times
Liked 2,563 Times
That's good to know. I've always played it safe since I don't use a torque wrench to install the lockring -- I probably should.
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times
One the Shimano 7 speed 13-26 cassette I have, it was held together with three hex bolts, which required a 3mm socket (or similar) to remove. On other cassettes it has been 1.5mm hex key bolts or rivets. My moto-tool make short work of the rivets. All my freehubs are steel.
I have also put the spacer ring on the outside - no issues - yes I use a torque wrench. They are $10- at Harbor Freight so no excuse for not having one.
If you don't have a torque wrench, measure the length of your wrench in inches, divide by 12 to get feet. 40 n-m is ~30 ft-lbs. So if you have a 1ft long wrench on the lock ring tool, you need to exert 30 lbs on the wrench. If you have an 8 inch long wrench, you'll need to exert 45 lbs of force. You can calibrate your force with the weight of your bike.
Liked 2,563 Times
I've got a torque wrench and use it for most fasteners, it just seemed awkward to use on cassette lockrings, and I've never had one come loose. I need to check if I have a 1" socket at home...
The rivets on the HG50 cassettes don't seem to protrude as much as the bolt heads on HG70 and up cassettes, so there's that. I bet HG20 cassettes wouldn't need any of this, since the largest cogs piggyback on smaller ones rather than being attached with shared rivets. Haven't tried those ones as I don't use 12-28T or 12-32T.
Constant tinkerer
Sometimes it is necessary to cut up a cassette when making a custom cassette or picking out a desired cog.
Bikes: Scott addict Team Highroad (2010), Peroni Track bike
though on a light alloy cassette driver each cog spline will make a gouge mark as it transfers the force to get you up Hills
Liked 1,095 Times
+1 Which is why I mentioned the bolts aren't needed if you have a steel or Ti freehub body. Shimano uses steel on all but Dura Ace which has a Ti body. Their sole exception was the 10-speed only 7800 hubs and those weren't in production long and certainly aren't an issue for the OP.
Constant tinkerer
jhatfie
Bicycle Mechanics
8
10-09-15 04:14 PM
wilber.71
Bicycle Mechanics
4
06-27-10 09:29 AM
