How hard is it to strip seatpost collar screw?
So ~5 miles into my ride today I needed to adjust my seatpost a bit higher. Unscrewed it, adjusted the seatpost height and then tried to screw it back on but it started turning.
Took out the screw and saw this:
The collar says 5Nm which is ~45in*lb. Having installed my stem using a torque wrench at 5Nm I'm sure there is NO WAY I was near that.
If I had put too much torque on it wouldn't it have gone further or damaged the seatpost before doing this?
Before I contact the manufactuer I'm trying to rule out error on my part. What do you guys think?
It's ALL base...
Probably user error. Maye due to repeated tightening over time, too.
I say this because 45 in-lb is about 3.5 foot pounds, or the equivalent of 3.5 lb force on a lever 12" long. That's not a whole lot of force.
However, I personally crank on the seatpost bolt until it feels tight, and it's probably way above that spec. It is a collar type seat post bolt, maybe that's different.
What kind of a seatpost bolt setup is that? I'd think it would be easy to strip the bolt if it had a steel barrel nut like that, instead of screwing into an alu. alloy collar...
Bikes: 2010 Jamis Xenith Comp
i can't really tell from that picture how the setup works, though, so it's hard to know what happened.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I've done it with one of those tri allen wrenches before.
It's like riding a bicycle
It's ALL base...
The pic is pretty telling, really. Unless the screw is made of pot-metal derived from the factory slave children's leg-braces and crutches, it can only be stripped via over-torqueing. Work on stuff long enough, you'll do it, too.
This happens. Take it to the shop where you bought your bike or a local shop that is a distributor for that manufacturer and have them submit a warranty claim.
On my other bikes I've put on quite a bit more torque and they have held up just fine. The only reason I'm questioning this is because the seatpost was still wiggling side to side when I got it this tight...
It's on my BMC... I guess CC will help me out?
You're going to warranty a $10 collar?
Go to LBS. Buy collar. Install. Ride bike.
Try not to be so ham-fisted this time. Unless you're a millwright, then I guess you can't help it.
- just kidding. some collars suck, don't sweat it.
Not too hard...I've done it on my mountain bike 5 minutes before loading up to ride. But on the bright side, I'm pretty sure I'm the ONLY dude within a 100 miles that has campy comps on a mountain bike. That's the only one the lbs had on hand to replace the one I broke...
He drop me
Bikes: '03 Marin Mill Valley, '02 Eddy Merckx Corsa 0.1, '12 Giant Defy Advance, '20 Giant Revolt 1, '20 Giant Defy Advanced Pro 1, some random 6KU fixie
Quoted: 138 Post(s)
Liked 12 Times
Here you go https://fairwheelbikes.com/tune-wurge...ar-p-2911.html
That's definitely the one you need.
Or maybe this one.
Or maybe this one.
The views expressed by this poster do not reflect the views of BikeForums.net.
It's ALL base...
Honestly, get the correct one that fits your frame. There are different sizes and styles, depending. I'm used to the collar style, not sure what kind of mechanism that uses a barrel nut like that.
What's that from?
What's that from?
Gluteus Enormus
Bikes: Yes
You gotta get the right one for the frame. It doesn't necessarily correlate with the seat post size. Take in the broken one to match it up is maybe best.
Mine are all 29.8s, but yours is probably 35mm.
