screaming noise back wheel
Bikes: Raleigh Sports 1963, Phillips 1959, Cannondale F700 1999, Cannondale Crit 500 1980s, Bianchi Limited 80s, Bianchi Brava 80s
Quoted: 28 Post(s)
I have a 10 speed old bike I been working on. Took it for a spin yesterday and at times, mostly when going slow it makes this screaming noise at back wheel. It does this when I hit back breaks as well.
Any suggestions or thoughts?
Mechanic/Tourist
It's BRAKES, and you need to provide more info.
First, what do you mean by "working on," specifically what did you work on just before the noise started occurring? Most likely what you did had something to do with the noise.
Secondly, does the noise have a pattern, like once per wheel revolution, or is it more random
Thirdly, what if anything have you checked so far, and how?
Quoted: 5256 Post(s)
Liked 1,561 Times
As CNY points out detailed info is necessary, otherwise it's GIGO.
A key point is whether it makes this noise, when coasting only, when pedaling only, or both when pedaling and coasting. If while pedaling is it always or only when pedaling hard as uphill. Is it louder if you pedal harder, does it pulse or it is steady?
etc.
The more you tell us the better we can diagnose the cause. BTW- as CNY pointed out brakes are what you use to stop your bike, breaks are what may happen when the brakes don't work. Don't rely 100% on spell check for your writing.
etc.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FB
Chain-L site
Quoted: 28 Post(s)
I removed wheel to remove rust and clean it up, when I got it it was awefully dirty. I did not touch the breaks, due to limited knowledge, this is my first old bike to learn to repair. I rode it just to test it out when i first got it and it didnt make the noise. I think wheel needs some truing. The noise does have a pattern, so it happens at a certain part of the wheel, except when i hit breaks it happens every time. I looked at the breaks and it seems that one side is closer to the wheel than the other. So how do I got about balancing them?
Thanks for your response
Quoted: 28 Post(s)
etc.
etc.
Liked 1,561 Times
OK, from your description it sounds like the BRAKES are rubbing. The easiest way to confirm this is to remove both brake shoes and see if the noise disappears during a test ride in a parking lot, or some other controlled conditions. (not in traffic please).
If it is the brake, then it's either wheel position when you installed it, wheel alignment, or a brake adjustment, or some combination of the the three.
Do the elimination test as I suggested, and come back for more. BTW- if the noise continues, check that the tire isn't rubbing in the frame (look for scuffing on the side of the tire, or lift the bike and spin the wheel watching for rub).
FB
Chain-L site
FB
Chain-L site
I know, I'm a bad, bad man.
Knows the weight of my bike to the nearest 10 pounds.
Liked 1,561 Times
Anyone want to bet on the spelling when the OP next posts?
FB
Chain-L site
FB
Chain-L site
Quoted: 28 Post(s)
I will check the "brakes" and let u know what happens.
Liked 1,561 Times
Unlike some others on BF, I've pretty much given up on expecting decent grammar, punctuation and syntax here. So I limit my pet peeves to the bicycle related cases, such as Breaks/brakes, forks (there's only one per bicycle), and as a courtesy to my friend at SKF bearings, when one means only the balls.
I do, however, wonder what they teach in English classes for 12 years.
FB
Chain-L site
FB
Chain-L site
One of the tasks I always give to candidates who make it past the first cut is to take a poorly-written set of user requests and turn them into a paragraph or two of system requirements. Trivially easy, but it helps to weed out the people who had someone else write their resumes and letters.
Imagine my lack of surprise when the guy presented me with a document written almost entirely in text-speak. When I pointed out that it was ambiguous and self-contradictory in the few places where it wasn't entirely wrong he attempted to justify his work by claiming that it had the "benefit" of being concise and understandable to younger software engineers.
For what it's worth, our candidates from state schools and community colleges tended to have practical writing skills that were noticeably superior to the ones from private schools.
Liked 1,561 Times
it's gotten very bad. Some months ago, I was presented with a legal document that was barely literate, (and I don't mean in legalese). I wonder if judges downscore for poorly written motions.
FB
Chain-L site
FB
Chain-L site
Bikes: Surly Steamroller
As they say, "them's the brakes!".
Bikes: 20" Folder, Road Bike
Hi,
You have probably either moved the brakes if you tightened them,
or refitted the wheel slightly differently causing brake rub.
You don't have to take the pads off and ride it to check it, just lift
the back and spin the wheel forward, any problems will be obvious.
Check your wheel in pretty centered (I don't insist on UK spelling)
between the chainstays, if not walk it straight, if that is OK, look
at your brakes centering adjustment, it varies between types.
rgds, sreten.
rgds, sreten.
Quoted: 28 Post(s)
So took brakes off n no more noise! However not I got another prob. Brake pads screws pretty much felt apart while loosening. So at this point I ll just put new cables and find some brake pads. And by the way, thanks for making super conscious about my spelling!
Location: England, currently dividing my time between university in Guildford and home just outside Reading
Bikes: Too many to list here!
Wait, what? Surely it can't be that hard to put a couple of washers and a nut back on a threaded stud?
I'd still suggest replacement pads, but that's because the old rubber will have degraded with age, and new pads will likely give better braking.
Quoted: 28 Post(s)
Lol
Quoted: 28 Post(s)
At how anal and judgmental some of you seem
Quoted: 28 Post(s)
It's ok! It s funny! The nut on the pad that was rubbing against wheel
