Threadless adapter moves too easy on Giant Cypress
Return window is past gone because I haven't rode in a couple months and forgot about this issue. Happened again the other day when I was out riding it.
I have a mid 2000s giant cypress. The quill stem was starting to get a lot of play so I decided to go threadless.
The threadless adapter i got was 1 1/8. Ot wasnt the super popular one thats on amazon. It was a cheaper one. Seemed to install fine. Even snugging it down as much as possible it isn't securing. Solid as far as trying to come out. But I can very easily twist the handle bars and the adaptor is what's moving. Originally I thought the stem was to blame but it isn't. It's an easton.
I know it's supposed to give but this seems excessively easy. Do not have the issue riding it on the pavement. But if I've had to dart around people and ride on grass/bumps for a while, the handle bars will be crooked.
Advice is appreciated
Bikes: Bicycles? Yup.
Quoted: 477 Post(s)
Liked 1,552 Times
You say the original quill stem was moving too. Makes me wonder about the fork tube, have you inspected it? Possibly bulged or cracked where the quill wedge sits?
I think my adapter is from Origin8 and it is solid.
Likes For BTinNYC:
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Hi and welcome!
Could you attach some photos so we have a better idea of what's going on?
Likes For Lombard:
I would suggest you take the top two headset threaded nuts off and if you have enough cable length drop it out the bottom and inspect it very carefully. If you don't have enough cable length I'm sure that you would have enough to drop it down to where the threadless adapter seats.
Likes For RiceAWay:
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
There could be other issues with your fork. Without pictures or inspecting it in person it is hard to tell for sure but it sounds like something else could be up. The bike is a low initial cost bike so be careful putting a lot into it especially if you need a new fork. Also keep in mind 1 1/8 threaded forks aren't common it was a cheap kludge for a lot of bike manufacturers making low cost bikes. It is becoming less and less common but is still practiced for some reason.
For those with 1" quill stems who want to go threadless and want a good clean look without having to change forks or deal with another quill stem try this: https://www.innicycle.com/ I don't work for the company or get anything from it I just think it is a really nice product and super practical for those old bikes we love.
Likes For veganbikes:
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,203 Times
Stuart Black
Stuart Black
Likes For cyccommute:
I'm super sorry, I fixed it and forgot about my thread.
It won't let me post links or pics since I still don't have 10 posts on here.
The wedge nut on the adapter ended up being the problem. I switched it for the one that came with the stock quill stem. The adapter nut is grooved/slotted the whole way around. The middle of the old nut is smooth and not grooved. Just wasn't making enough metal on metal contact I guess.
It takes a good amount of force for the handle bars to move.
stock and new adaptor are both marked 25.4mm so I definitely got the right size.
The adaptor I bought is branded as zukka on amazon.
The original one started having problems where you adjust the angle.
Sock Puppet
Liked 863 Times
