Calories and cycling
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
When you lost your first 100lbs through diet alone, what did you change in your diet?
Also, i'm curious, once you lose all that weight, do you generally eat less, like is your appetite lower (unrelated to junk food or over eating)?
HOw many calories do you eat now you think?
B. Without working out, I was constantly hungry. I actually eat quite a bit, but I try to make as much of that vegetables (and some fruit) as possible. I do eat a lot of meat as the extreme mileage I ride regularly requires a lot of muscle maintenance.
C. I stopped counting calories a few years ago. It's the primary benefit of exercising as much as I do that I can do that and not put on weight, I make no bones about the fact that I like to eat a lot. I have lost a lot of bad habits like eating several big pieces of pizza in a single meal. If I let myself do that whenever I wanted to, I don't think I could exercise enough to counter that.
D. I have no idea if the low carb thing has any relevance to my success or not and I certainly don't follow it when I'm on a 130 mile ride, but the no starch/no white sugar thing had a real practical impact--try to find a fast food joint where it's possible to order much of a meal without starch or sugar. It made mindless snacking nearly impossible.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,204 Times
56yr 6’1” 185lb…… flat ground, 12-13mph…. rule of thumb … 25cal per mile.
Based on reading from a Stages Cycling power meter.
Hills do increase cal, but not as much as you’d hope.
Barry
Barry
Likes For Barry2:
Quoted: 365 Post(s)
Liked 419 Times
It is really difficult to eat less calories for me, i feel sooo low in energy, and worst of all , l get low sugar symptoms (light headed, dizzy, sometimes the sweats), after doctors testing, they said i'm generally healthy
I personally don't think eating less calories will be option for me, all thought it is most effective
18 years ago, i had gone from 250 to 180, by cutting lot of calories, and maintained around 195-200 until i was 34-35, , at which point i started gaining, from 195 to 230, however bc i get the symptoms i described, it is hard to lose weight by calories cutting.
I literally, just naturally eat more, when i gained my weight, albiet, they are healthy choices, its kind of strange.
Weight loss has to be considered as a lifestyle change, as others in this thread have said, not as a limited term deprivation. Weight loss does not occur overnight, anymore than the gain did (admittedly, the gain part is much more enjoyable than the lose part). Also, weight loss is not necessarily a simple process - it may not be as simple as calories in < calories out = weight loss. Our bodies and our metabolism can adjust to changes. A reduction in calorie intake may result in a change in metabolism so your body can maintain (or even increase) its weight at the reduced level of calorie intake.
In my case, for example, when I make a change to reduce weight I notice that I lose a significant amount of weight at first (maybe 1 - 2 weeks), then the weight loss levels off (or even reverses) for a time (another 1 - 2 weeks, or longer), even though I'm doing the same thing I was doing when I was losing weight. Only after the "rebound" effect does my weight start to, gradually, trend in a negative direction.
The toughest time is the beginning. And calorie restriction can be ... unpleasant. As you said: low energy, lethargy, hunger pains, etc. It will get better, eventually, and you'll have more energy, eventually, and if you push through you'll get an increased feeling of wellbeing, but while you're going through it, it is not fun. In our society it is so easy to make all the pain go away by abandoning the change you've made. For me distractions work - go on a bike ride (a favorite), or work in the yard, clean the kitchen, go on a hike, build a bookcase ... anything that occupies your hands and mind with something other than food.
Another huge mistake that people make is to reward themselves with food. "If I lose 5 lbs I'll treat myself to (a Big Mac, or ice cream from B&J, or whatever)." You're subverting your own efforts. Yes, it can be helpful to ease calorie restrictions occasionally, but that should never be structured as a "reward", it should be built into your lifestyle change from the beginning.
You have to be prepared for negative feedback. You would think that others would value your change because the goal is a healthier and happier you. This is not always the case. "You're too skinny." "You're losing muscle." "Here, have another burger!" Etc. This can be surprising, and if you're not prepared for it this type of negativity can derail your new lifestyle.
Many people (so I've heard) do not cook for themselves much (or at all). It is very, very, very difficult to control calorie intake by eating restaurant food, fast food, prepared foods. IMHO, the one lifestyle change with the biggest benefit to your health (and only incidentally to your weight) is to prepare the vast majority of your meals yourself from raw ingredients. I, personally, eat out about 1 - 2 meals per month.
There are many other factors to consider (people drink far to many calories - soda, juice, alcohol, fancy coffees, smoothies, protein shakes, etc.; portion control - put your meal on a plate and eat only that, no seconds; buy smaller plates to avoid piling too much on; having a partner in your lifestyle change to help keep you on track/for encouragement/for reinforcement; etc.), and the effect that each factor has is different for each person. Even your approach can vary - for some it is better to try different things to see what works, while for others it may be better to just choose one strategy (or set of strategies) and stick with it.
There's a lot to consider, and there are no easy (or, indeed, few even simple) answers.
Likes For noimagination:
Bikes: Rossetti Vertigo
Quoted: 229 Post(s)
Liked 119 Times
Happy-go-luck has rarely led to significant weight loss. You have to keep an eye on things and track food/exercise at some level. You don't have to be obsessive about it, but you do need to be concerned with it.
Quoted: 229 Post(s)
Liked 119 Times
Losing weight is difficult for many of us, due to many factors, and many of the factors that affect weight loss are not considered when planning/evaluating weight loss, or are misunderstood.
Tragically Ignorant
Liked 9,098 Times
What I really like about your post is that's there's a lot of practical considerations in there that are explained very well, but you're not overextending it into "these are the foods and exercises that will work for you" kind of crap that no one really can authoritatively define for another. CI/CO is not simple except at extreme imbalance.
One trick I learned cooking for myself, pretty much any spice is calorie free or close to it, so making food taste very different satisfies my craving for variety.
Also, for me, I can't watch cooking shows on TV. The "every meal has to be special" thing is just about the worst enemy to a rational relationship with food I can think of, especially when I can get just about anything delivered.
Another YMMV situation, but here is what worked for me: I could lose some weight just by adding exercise, but it was impossible to maintain.
More simplified math with lots of generalization: losing 1 lb requires burning roughly 3500 calories more than you consume. That is about 6 hours of cycling per week, using my 10 calories per minute and it assumes you will not eat anything extra doing all that exercise. A business trip or vacation interrupts the exercise regime or you eat more during or after the cycling that you do on days with no cycling and you are not losing weight.
So, cutting 500 calories per day will help you lose 1 lb per week with no additional exercise, the exercise calories are a bonus above that.
What worked for me was using a free app (LoseIt) to log what I ate and keeping the weekly average calories in at what would maintain my goal weight - and NOT logging exercise for anything less than a 2 hour ride. I've maintained most of that loss for over 10 years now, only have to go back to logging everything a few times like after particular food-filled holiday season or when I had rotator cuff surgery and my exercise went to near zero for a while.
Loads of generalizations but that works for me - just adding exercise did not work. To answer your other question, I think the exercise (biking plus some weights) was key - resting muscle requires more calories for you body to maintain that resting non-muscle. Just one of the other probably can be done but much harder and definitely didn't work for me.
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,896 Times
BTW, I've also tried just riding a lot and NOT paying attention to what I eat. I got fitter, but never got below 220. Now I'm right around 200, +/-2 lbs, and have been for 7 months. I've also had years where I hardly lost weight at all, because I more than compensated at the dinner table for what I burned on the bike.
Likes For genejockey:
Quoted: 229 Post(s)
Liked 119 Times
Really great post. I specifically avoid giving people detailed advice because, as I say, I am expert only in what works for me. The one piece of advice I do give freely, however, is "stop listening to other people's advice." It's all conflicting and, as you suggest, it's often a manifestation of someone dealing with their own demons.
Quoted: 229 Post(s)
Liked 119 Times
It's entirely possible, but maybe not without paying attention to both sides of the Calorie equation. I say this because I lost 30 lbs last year. I was only able to do so by counting Calories rigorously and riding 3000 miles. It doesn't require a huge sacrifice in what you eat, just fewer snacks, smaller snacks, not going back for seconds quite as often, having a glass of water instead of yet another Coke or a beer. Those little things add up, and combined with Calorie-burning exercise, will take weight off.
Likes For pgjackson:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Okay, let's start with that working premise. Please write down everything you eat and drink for the next 48 hours. Everything. With as much specificity as possible (portion size, origin/brand, time of day). This will inform you as you move toward your 30-pound goal. Exercise is good and necessary, but not sufficient. Don't complain or poo-poo this idea of a detailed audit of your eating and drinking habits.. It's important.
A proper diet will be a lifelong tool for you to maintain a correct weight and body composition for you. 30 lbs overweight belies some other issue relative to your diet. Let's look at this first.
Liked 11,896 Times
Biggest problem for me is what I call 'defensive eating'. When you're competing with a couple 20-something boys, you sometimes eat seconds you wouldn't otherwise eat just to make sure you actually get to eat them, because otherwise they'll be gone. I can't count the number of times I made what I thought would be enough for dinner two nights and lunch the next day only to find that instead of dinner the next night, it's all been consumed as midnight snacks and their lunch.
Quoted: 4399 Post(s)
Liked 4,844 Times
The problem with this approach is that your body is much better at counting calories than you are - add a work load and your appetite will adjust to compensate and you're left hovering in the same weight range. I'm intimately aware of this because I've gone through it myself. Sure, I'd go through the annual cycle of taking off 15 pounds or so during the summer, but it was never long before it was back. The only thing that changed that was close tracking of my input (eating) and output (activity) and maintaining a daily deficit; I did this with a calorie counting app (it's actually not as tedious as it may seem and it's enlightening to do, even if you only keep it up for two weeks or so), an activity tracker and a power meter.
Until you do it, people seem to think of tracking input/output as an exercise in self-denial. It was quite the opposite for me and I found it much easier to maintain than "just watch what you eat."
"Just watch what you eat," *is* an exercise in constant self-denial and I think that the vast majority of people will fall off that wagon sooner rather than later. Maintaining a deficit, though, allows even daily treats, as long as you're not completely sedentary and as long as you're not too indulgent. Some ice cream at the end of the night? Sure. A beer? Yup, no problem, even on days where walking is my only exercise. On a day when I ride three or more hours? ****, I can eat just about anything I want and not come close to threatening my 750 cal deficit.
But this is only what works for me. If something else works for you, kudos, but if you're not seeing the results that you want, give the above a try.
I find that exercise helps a lot for me simply because it allows more food intake while still maintaining that deficit. I typically train around 10-12 hours per week consistently. It burns a lot of calories and I'm fortunate that my appetite doesn't tend to over-compensate. If anything exercise tends to suppress my appetite.
Quoted: 6193 Post(s)
Liked 4,808 Times
You have to burn upwards of 3500 Calories to lose 1 lb of fat. Of course that's only if fat is supplying all your Calories expended on the ride which typically it isn't.
Any weight loss you see after even a two or three hour ride is going to be mostly water loss from sweat.
So my advice if cycling is for weight loss it to ride long and ride low effort rides. When I ride hard, I tend to want to eat more.
Weight is still Calories in vs Calories out. Don't get too wrapped up in what your device says you burned. If the scale is going the wrong way then consume less Calories or burn more Calories. But don't worry about the device accuracy for Calories burned. Worry about the trends.
If you track your food, do you really think those Calorie figures are accurate for every item every time? Calorie content widely varies among those food items and the charts and stuff are just averages. If we had a Calorie meter we could stick in them, then we'd have a whole new set of threads wondering why they got this reading from this apple and another reading from another apple and someone else will be answering about plums.
Quoted: 18411 Post(s)
Liked 15,531 Times
Quoted: 2333 Post(s)
Liked 2,097 Times
It is possible to outride a bad diet but it ain't easy.
Somewhere around 400 miles or so per week is what it takes for me, I can throw whatever down the pie hole and it will burn w/o me gaining.
From my experience, diet is more important than the synergistic exercise component.
I lost a little over 60 pounds in just under 4 months once. It can be done.
Likes For ChamoisDavisJr:
Tragically Ignorant
Liked 9,098 Times
Bodybuilders who have to get bodyfat down to absurd levels think of food as simply fuel, not entertainment. I was kind of into that stuff in my younger days (but never got anywhere close to the results I expected)....a common theme from the pro guys is that mentality. You eat to fuel your body. Food is fuel. T-Nation is a pretty good forum if you are seriously into total fitness. Most of it is weightlifting and bodybuilding, but there are forums for pretty much everyone there.
I'm good with eating for pleasure, I have no desire to make eating into a chore, but I also don't need some chef going on and on about needing to make every meal special in some way. Lots of meals are just going to be a matter of fuel.
I'm seriously not into any kind of fitness "program". Probably a forum like that would just be bad for my morale. What I like about bicycling is it's both play and exercise.
Tragically Ignorant
Liked 9,098 Times
There's absolutely no way I can go to a buffet and not overeat (I will let myself do this sometimes when I know I have and am about to do some unreasonably huge amount of riding). The big thing for me is similar to what you're describing--I feel a need to try everything and make sure I get plenty of the things I really like. It's a weird internal pressure to massively overeat.
Likes For livedarklions:
Quoted: 229 Post(s)
Liked 119 Times
Quoted: 229 Post(s)
Liked 119 Times
Liked 2,097 Times
Drunks are told stay away from bars. Nothing good is going to happen at a buffet......just sayin
Likes For GhostRider62:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
As a reminder, dietary calories are measured in units of energy. The dietary “calorie” is actually a kilocalorie for use in comparison with SI units of work, such as joules or kilojoules. one calorie = 4.184 Joules so one dietary calorie = one kilocalorie = 4.184 kJ.
As you will see in examples below, riders tend to be about 25% efficient at turning dietary calories consumed into useful pedaling work which would be measured again in units of energy. Most of the rest is ultimately dissipated as heat though there is also internal work done just moving the mass of legs, pedals and cranks at a particular cadence.
Power meters measure the instantaneous rate at which external work is being done on the pedals and is measured in Watts= Joules/sec.
For those interested, that internal power load and resulting internal work is strongly dependent on cadence, so at a given speed on the road (and external power load) the total load your body must power will be a higher level that is an increasing function of cadence.
So I presume that’s looking at pedaling at 200W for one hour. Total external work would be 200 J/ sec times 3600 sec = 720,000 J or 720 kJ. At 25% efficiency, that requires 4 x 720 kJ = 2,880 kJ of dietary energy consumed which is 2.880 kJ/ 4.184 kJ/kcal = 688 kcal = 688 dietary calories. The 25% figure is rough and varies a bit with individuals so don’t read more than two figures at most. Figure 700 dietary calories roughly.
Power is actually the rate at which work is being done, measured in watts or kW. Coincidentally, the factor of 4 from the 25% metabolic efficiency roughly cancels the 4.184 conversion factor of dietary calories or kcal to kJ. So, yes, one kJ of cycling work is roughly one dietary calorie consumed.
Probably more than folks wanted to see but there it is for folks who might wonder.
Otto
When calculating calories based on power meter data, no - conventional wisdom has it that cyclists don't actually differ all that much (the range last I looked at studies - admittedly with trained cyclists - was about is +- 10%) when it comes to turning calories into watts. Of course your basal metabolic rate differs based on age, sex, weight, height and so on but taking that into account is a bit iffy - you'd have expended (a good part of) that anyway just being alive.
Generally, 200W (which on a road bike on flat terrain with no wind is good for about 31-35 km/hr depending on how aerodynamic you are and how efficient the bike is) requires about 720 kcal plus whatever your basic metabolic rate is (which depends on weight, sex, etc) comes out to let's say about 800 to get a nice round number, so 430 kcal for going hard for half a hour is entirely feasible (or more, or less).
As long as you're watchful what and how much of it you put in your mouth, cycling is going to help.
Otto
Quoted: 1364 Post(s)
Liked 1,677 Times
I didn't understand all of this podcast, but it came out on the 28th...
https://omny.fm/shows/clear-vivid-wi...ories-better-1
Tragically Ignorant
Liked 9,098 Times
That's just a shade over 3 pounds a week, which I understand from some reading is probably about the maximum healthy steady weight loss. Any faster, and it starts to wreak havoc with your gall bladder,
