non-disc brake purchase options?
Old 07-27-21, 02:58 AM
Fentuz
Bikes: Dahon jetstream p8, customized helios & Plant X Free Ranger (modded of course)
Quoted: 76 Post(s)
Liked 56 Times in 48 Posts
I have both: Hydraulic Disc on the "big" gravel bike and mini V brakes on the folding gravel bike. the rim brake does not offer good braking performance and frankly, when you go down a twisty steep hill over 40kph on loose surface,you need to be confident in you brakes... V brakes/cantilevers do not cut it.
Now, the issue about hydraulic, I can understand that some people can get a little worry about the maintenance of the hydraulic and there is a argument that if it fails in a remote area, it will be a pickle however, it is not a reason to rule out brake discs. if the issue is the hydraulic system maintenance, then, there is always the next best option: mechanical brake discs. a bike setup with spyre calipers, good disc and very good pads will be better the crappy rim brakes and the setup/maintenance is as simple if not simpler than rim brakes.
if you look at the "beginner " gravel bike like cinelli Zydeco lala, canondale topstone 3 etc. they tend to be fitted with shimano Sora groupset and mechnical road disc brake 160mm front/rear or SRam Apex or microshift mechanical disc.
These bikes work well and brake better than V brake/cantilever stuff.
Fentuz is offline
Likes For Fentuz:
Old 07-27-21, 03:49 AM
Badger6
Obsessed with Eddington
Badger6's Avatar
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 348 Post(s)
Liked 351 Times in 234 Posts
The only valid argument to refuse adopting disc brakes probably stems from the steep cost if one already owns a bike with sub-optimally performing rimmers: new frame, new hubs/wheels, and (if installing hydro) new levers along with the calipers...can get pricey. But, buying a new build? It is borderline absurd to eschew a superior performing brake system, ESPECIALLY when their inclusion in the build is by now built in...both in terms of weight savings in other places, and costs.
Badger6 is offline
Likes For Badger6:
Old 07-27-21, 07:30 AM
unterhausen
Randomhead
Liked 1,636 Times in 1,173 Posts
I used to be one of those, "rims are just a big disc" people. Then I got some disc brake bikes. I have often wondered how many people who don't like disc brakes really have given them a chance. I'm not saying it will revolutionize your riding, but it's certainly at least a little better and not worth spending too much energy on. The bottom line is if the industry makes a wholesale change like this, it's not worth fighting. Just look at 26" wheeled MTB, there is just no point in holding out now unless you already have a bike that you like. But buying new, I'll just take what's on offer and ride new my bike.
It's really skewed right now that there are shortages, rim brake parts just evaporated. And it's really hard to find rims. Last time I needed one, I was lucky that someone I know had a stash.
unterhausen is offline
Likes For unterhausen:
Old 07-27-21, 11:38 AM
msu2001la
msu2001la's Avatar
Quoted: 623 Post(s)
Liked 523 Times in 318 Posts
If "stranded in remote area due to brake failure" is high on your list of concerns, maybe gravel biking in remote areas just isn't your thing?
msu2001la is offline
Likes For msu2001la:
Old 07-27-21, 12:12 PM
Fentuz
Quoted: 76 Post(s)
Personally, i don t care there are bike shops within a few miles but as “path less pedaled” mentioned on there channel it s always the case in north America and for some people it might be a negative point regardless.
there are some brand of car I would not touch because of the dealer network and the fact that general mechanics don t have the correct tools or know out. Is it the same for some bike systems? (i don t know, i do most things myself but i ask the question)
Fentuz is offline
Old 07-27-21, 01:53 PM
msu2001la
msu2001la's Avatar
Quoted: 623 Post(s)
I was being a bit facetious.
The likelihood of anyone experiencing a brake failure while out riding (regardless of type) is fairly low. That this would also happen in a situation where someone would be stranded, rather than being able to ride it home on one brake seems impossibly rare.
As for your second comment - hydraulic disc brakes do not require any skills or tools that are beyond the reach of any shop mechanic or inclined DIYer. The same cannot be said for properly adjusting a cantilever brake.
Old 07-27-21, 02:18 PM
Rolla
Gyro Captain
Rolla's Avatar
Bikes: 4 Singlespeeds, 2 Gearies
Quoted: 457 Post(s)
Liked 1,108 Times in 489 Posts
Speak for yourself.
Rolla is online now
Likes For Rolla:
Old 07-27-21, 02:23 PM
Fentuz
Quoted: 76 Post(s)
not sure about that, hydraulic is not easy to bleed. Definitely harder than bleeding car or race car brakes. All that syringes malarkey with specific sram fittings… i don’t like it despite not minding it for cars.
Fentuz is offline
Likes For Fentuz:
Old 07-27-21, 02:29 PM
msu2001la
msu2001la's Avatar
Quoted: 623 Post(s)
Originally Posted by Rolla View Post
Speak for yourself.
Care to elaborate? I've never found hydro disc brakes to be particularly difficult to work on. I've had systems from Avid and Shimano, both were very simple to adjust and replace pads. I bled the Shimano brakes with a $25 bleed kit I bought on Amazon. The bike mechanics I know can do this stuff in their sleep and I've never heard of hydro disc brake service being a specialized thing that only certain shops or mechanics can do.
Old 07-27-21, 02:43 PM
Badger6
Badger6's Avatar
Quoted: 348 Post(s)
...hydraulic is not easy to bleed...sram...
I guess you don't have any experience with Shimano "one-way" bleed?
Mineral oil, bleed cup, syringe with hose, 7 or 8 mm box end wrench, and >2 minutes and perfect every time ... not counting the removal of wheel and pads and installation of bleed block, then reverse after bleed (or flush).
Badger6 is offline
Old 07-27-21, 03:19 PM
Rolla
Gyro Captain
Rolla's Avatar
Quoted: 457 Post(s)
Care to elaborate? I've never found hydro disc brakes to be particularly difficult to work on. .
Me neither. Nor have I found that properly adjusting a cantilever brake "requires skills or tools that are beyond the reach of any shop mechanic or inclined DIYer," as you evidently have.
Rolla is online now
Likes For Rolla:
Old 07-27-21, 07:44 PM
dwmckee
dwmckee's Avatar
Quoted: 327 Post(s)
Liked 234 Times in 155 Posts
Interestingly, I have had a brake bridge shear/twist out of a steel frame on a ride, rendering the rear caliper brake unusable. I have never had a ride spoilde by a disc brake failure.
dwmckee is offline
Old 07-27-21, 08:42 PM
chaadster
Thread Killer
Bikes: '15 Kinesis Racelight 4S, '76 Motebecane Gran Jubilée, '17 Dedacciai Gladiatore2, '12 Breezer Venturi, '09 Dahon Mariner, '12 Mercier Nano, '95 DeKerf Team SL, '19 Tern Rally, ‘21 Breezer Doppler Cafe+, ‘19 T Lab X3
Quoted: 1701 Post(s)
Liked 737 Times in 457 Posts
Man, setting up cantis used to be like an art form, and lots of folks did not have the skills to do it right. In order to get the pads to hit the rim cleanly with max leverage involved rectifying so many bits and angles against each other— pad height and angle, arm spring tension, straddle cable length and centering, cable length at the barrel adjusters, yoke angle, caliper angle— that they’re literally at least one order of magnitude more complex than hydro disc setup. The sheer number of parts in canti brakes is staggering, from cable pinch plates, to cable pinch bolts, concave washers, flat washers on both the calipers and on the studs…each of the 4 canti arms of the venerable DiaCompe 986 had 13 parts, a typical amount. Then on top of that, you had to manually adjust cantis for pad wear, something which happens automatically with hydro disc.
**** cantis.
chaadster is offline
Likes For chaadster:
Old 07-27-21, 11:03 PM
Rolla
Gyro Captain
Rolla's Avatar
Quoted: 457 Post(s)
Concave washers and barrel adjusters?! Oh, the complexity!
Just to be clear, I'm not arguing against hydraulic brakes. But to describe setting up cantilevers as though it's some kind of Gordian knot is either a vast overstatement or an unflattering glimpse of your mechanical abilities.
At any rate, just like hydros, it's certainly not "beyond the reach" of a shop mechanic, or "a specialized thing that only certain shops or mechanics can do."
Rolla is online now
Old 07-28-21, 12:26 AM
Badger6
Badger6's Avatar
Quoted: 348 Post(s)
We shouldn't confuse complexity with difficulty. Cantis are complex, not difficult. Shimano hydraulic discs are simple and not difficult. See?
Badger6 is offline
Old 07-28-21, 12:45 AM
Fentuz
Quoted: 76 Post(s)
no, you are correct, I have Sram with the double system and fluid degasing procedure…
like i said not as simple as filling up the tank and pushing fluid through and getting the excess via the caliper nipple (I like AP racing calipers and alcon ones )
edit: i looked at the shimano procedure; it is pretty much what I used to do on my race car. Nice and Simple!
Fentuz is offline
Likes For Fentuz:
Old 07-28-21, 05:02 AM
chaadster
Thread Killer
Spoken like a true noob.
Let’s celebrate when you hit your 1 year anniversary.
Old 07-28-21, 05:19 AM
Warbird21
Warbird21's Avatar
Bikes: Salsa Warbird
Quoted: 35 Post(s)
Liked 44 Times in 29 Posts
I was a disc brake skeptic, when I bought my Raleigh Redux3 (Hydraulic). I ride mostly road/gravel and not many down hills. The pads squealed and the QR front wheel was a major PITA to reinstall. I bought new pads, which solved the squeal problem. That bike was sold and replaced by a Salsa Warbird, with mechanical disc brakes, thru axle a breeze, no noise and they seem to stop just as well as the hydraulic brakes. I've had to make a few panic stops and they do stop NOW.
Warbird21 is offline
Old 07-28-21, 05:27 AM
chaadster
Thread Killer
The complexity is in the system design, and the difficulty is in the setup process.
If we accept that anything on a bike is hard to do— something I think we must— then I’d say that canti setup is probably the hardest. They can be more finicky and sensitive than front derailleurs….and there are four of them to **** with.
Seat height adjustment is easy. Perfect canti adjustment is difficult.
And to be clear, not all cantis are same; some are more complex or more difficult than others. Good riddance to them all, though.
Old 07-28-21, 08:57 AM
Rolla
Gyro Captain
Rolla's Avatar
Quoted: 457 Post(s)
LOL. Well, you gave it your best shot, I guess.
Rolla is online now
Old 07-28-21, 09:25 AM
epnnf
epnnf's Avatar
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 174 Post(s)
Liked 41 Times in 27 Posts
I was pondering this not too long ago but dithered around until the BMC Monstercross was sold out. I came upon a Bianchi Volpe that I think might work. It came with really nice Cane Creek cantis. They stop well and don't squeal. The negative is that I have to deflate the tires to remove, even if the cable is disengaged. I'm think of switching to bar end shifters so I can use some Cane Creek brake levers with an additional brake release. The brakes and headset were all I kept. I bought a GRX crank and the rest is from the parts hoard. Ultegra 10 speed shifters, Pacenti wheels and (the horror) mismatched GKs.
Sorry, what is a GK?
epnnf is offline
Old 07-28-21, 09:41 AM
Elvo
Quoted: 586 Post(s)
Liked 310 Times in 172 Posts
Gravel King
Elvo is offline
Likes For Elvo:
Old 07-28-21, 05:43 PM
epnnf
epnnf's Avatar
Quoted: 174 Post(s)
Originally Posted by Elvo View Post
Gravel King
Look like great tires ty
epnnf is offline
Old 07-28-21, 08:12 PM
shelbyfv
shelbyfv's Avatar
Quoted: 2604 Post(s)
Liked 2,917 Times in 1,547 Posts
They look better when they match.
shelbyfv is offline
Old 07-29-21, 06:20 AM
cs1
cs1's Avatar
Bikes: Specialized, Schwinn
Quoted: 211 Post(s)
Liked 14 Times in 13 Posts
OMG, if I never have to touch another canti again, it’ll be too soon.
Any rim brake I’m happy to see go, if only because those ***** make a filthy mess, but cantis suck worst of all.
Cantis are so easy to adjust and set up. I've been running them since the seventies with no problem. I prefer them to most rim brakes.
cs1 is offline
