cycletorch Shark 300 disassembly
Old 07-29-21, 08:03 PM
RichSPK
Bikes: Dawes Lightning DLX, 1988 Klein Performance, 1991 Peugeot Safari, 1985 Raleigh Alyeska, Carrera Phantom, 1973 Raleigh Record
Quoted: 282 Post(s)
Liked 129 Times in 92 Posts
Remove (2) flat-head socket screws with a 1.5mm hex wrench.
The screws have an o-ring or gasket under the head.
L to R: Lens assembly (there's an oval o-ring inside), reflector, electronics (mounted on battery holder), body.
Battery is a Samsung ICR18650-22F. + is on the left, LED end. - is on the right, charging port end.
Positive (+) end of battery. The contact is a slightly smaller diameter than on the negative end.
Negative (-) end of battery.
Note that the poles aren't marked on the battery or on the battery holder. I put the battery back in backwards and immediately fried an IC on the board. I figured out which end was which the hard way, so please learn from my mistake.
https://cycletorch.com/collections/a...ble-bike-light
RichSPK is offline
