Conti 5000 tire pressure
Old 08-01-21, 07:11 AM
nrsmd
Quoted: 29 Post(s)
I just bought these tires (700 X 25C). I wanted these tires to increase my speed for race day due to reduced tire resistance, as advertised, and the tire's popularity. I know it won't make a very large difference, but more speed is still better than less speed given the same degree of wattage I can produce. Based on your experience or knowledge, what tire pressure front and back will optimize milaegage improvement (whatever it may be)?
nrsmd is offline
Old 08-01-21, 07:22 AM
Fahrenheit531
Must. Find. Shade.
Fahrenheit531's Avatar
Quoted: 691 Post(s)
Liked 429 Times in 228 Posts
Google 15% drop pressure, consult chart. Adjust to taste.
Fahrenheit531 is offline
Likes For Fahrenheit531:
Old 08-01-21, 07:26 AM
RGMN
Quoted: 211 Post(s)
Liked 168 Times in 115 Posts
Silca Professional Pressure Calculator
RGMN is offline
Likes For RGMN:
Old 08-01-21, 08:56 AM
Badger6
Obsessed with Eddington
Badger6's Avatar
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 348 Post(s)
Liked 351 Times in 234 Posts
Originally Posted by RGMN View Post
Then go ride the tires and adjust the pressure as necessary after some test rides nrsmd. The outputs are not perfect, but without a lot of fuss will get you very close to a useful pressure from which to start experimenting with the right pressure.
Also, invest in a decent standa lone pressure gauge to make sure you have the pressure where you want it...pump gauges are not reliable. They're good for getting in the ballpark, but are not reliably precise.
Badger6 is offline
Old 08-01-21, 09:20 AM
nrsmd
Quoted: 29 Post(s)
Bike pump recommendation that you found could get pressure up to120 or so?
nrsmd is offline
Old 08-01-21, 09:25 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 951 Post(s)
Liked 1,222 Times in 689 Posts
You haven't posted your weight, no way anyone can advise. And don't think you're going to go faster at 120 than a lower pressure no matter how much you weigh.
As an example...I weigh about 160 and would run 85rr/75frt w/ 25mm tires. Especially Contis as they tend to be a little wider than stated size.
cxwrench is offline
Likes For cxwrench:
Old 08-01-21, 09:30 AM
MrWasabi
MrWasabi's Avatar
Bikes: 2014 Fuji Traverse 1.3, 2020 Electra Cruiser 1, 1995 Giant CFM-4
Quoted: 123 Post(s)
Liked 49 Times in 34 Posts
Even the 5000s?
MrWasabi is offline
Old 08-01-21, 10:32 AM
GhostRider62
Quoted: 534 Post(s)
Liked 406 Times in 251 Posts
Originally Posted by MrWasabi View Post
Even the 5000s?
Slightly but not much.
26 mm vs 25 mm nominal
GhostRider62 is offline
Likes For GhostRider62:
Old 08-01-21, 12:00 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 3933 Post(s)
Liked 971 Times in 651 Posts
If you're going to deviate anyway from what the calculator tells you, the accuracy of your pump doesn't matter too much, as long as your pump is consistent in its inaccuracy.
Sy Reene is offline
Old 08-01-21, 01:28 PM
Badger6
Badger6's Avatar
Quoted: 348 Post(s)
True, however, there are a couple of reasons an accurate pressure gauge are helpful, in my experience.
1) You need to start somewhere.
2) once you know what works fro a given surface with a given tire, it's helpful to know what the actual pressure is, so that you can replicate it without another round of trial and error.
Badger6 is offline
Old 08-01-21, 01:30 PM
Badger6
Badger6's Avatar
Quoted: 348 Post(s)
Unless you weigh a metric ton, I'd be shocked if the recommended pressure was much north of 90. I weigh about 180, ride 27s (that measure 27) and my recommended pressure is 76, but I run them closer to 70. Like cxwrench said, there is no possible way to offer a guess at the recommended pressure without knowing the combined weight of the bike and you.
Badger6 is offline
Old 08-01-21, 02:08 PM
Wildwood
Veteran, Pacifist
Wildwood's Avatar
Quoted: 2840 Post(s)
Liked 1,873 Times in 1,042 Posts
To get the same feel of suppleness (as my Veloflex and Vittoria 25mm) on the 5000s, I have to reduce the pressure from my usual ~100 psi to about 85, thereby increasing the rolling resistance for me. Rider weight =190lbs.
In my opinion, the Conti 5000 may have slightly lower rolling resistance at equal tire pressure and (reportedly) good durability, but has a stiffer the ride quality than the comparable price competitors. If it proves out more durable in my riding conditions, that is a reasonable trade-off.
Wildwood is offline
Old 08-01-21, 03:12 PM
AdkMtnMonster
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a gravel bike…
Quoted: 381 Post(s)
Liked 746 Times in 320 Posts
I ride my 28s @ 60psi rear 54psi front. Great ride at those pressures for that width.
AdkMtnMonster is offline
