Stealth Paramount????
Quoted: 339 Post(s)
Liked 632 Times
Cruising the racks at the Bike Exchange I spied this ragamuffin that had just arrived. The stickers and flat pedals couldn't hide the thoroughbred underneath. Barely legible from the side but clear on the front forks the magic words Paramount. No Schwinn markings though. Some kind of knock off? Then I remembered that there was a non Schwinn version , the Waterford Paramount which I think this is.
The serial number is on the head tube and reads 1A 02973. It carries all Campi - front and rear derailleurs, crank, brakes, 8 speed brifters, and seat post. The bars are 3ttt.
I am going to de sticker it and clean everything. The white paint seems to have extensive craquelure but I don't want to repaint it.
The rear wheel is toast, a spoke pulled out of the rim leaving a pretty big hole but I have a selection of wheels to replace it with .
Check out the pics please and give me any additional info that you might have. I would like to know the year and if anyone knows of a catalogue scan that would be great. As is the bike weighs a little under 24 lbs.
I couldn't read the name on the stem . Does anyone know what it is?
Thanks everyone
Thanks everyone
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
It appears to be a Paramount PDG with uni-crown fork and a few upgrades......what does the sticker on the base of the seat tube say?
In any event a very nice riding bicycle and nothing to sneeze at.
T-mar will correct me if I am wrong and most likely help you to cypher the serial numbers.
Best, Ben
T-Mar
Best, Ben
T-Mar
Voltaire
Voltaire
Likes For xiaoman1:
Quoted: 1088 Post(s)
Liked 1,205 Times
Nitto Pearl stem.
Liked 1,205 Times
Looks like a 91? See right-most page eight rows down and the surrounding pages:
https://waterfordbikes.com/SchwinnCa...000/index.html
Forum Moderator
Quoted: 3089 Post(s)
Liked 6,590 Times
It is a 1991 PDG Series 5 Paramount.
Here is mine.
Here is mine.
Likes For cb400bill:
Forum Moderator
Liked 6,590 Times
Here's a closeup of the finish.
Quoted: 3504 Post(s)
Liked 2,922 Times
Likes For Force:
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
That reminds me of my college days at UCLA. Bicycle theft was rampant, and one defense was to uglify or otherwise disguise a good bike.
Bikes: 1st Track bike: 1978 Speedwell titanium 1st Road bike: 2001 Independent Fabrication Crown Jewel
Quoted: 97 Post(s)
Liked 116 Times
Great find and good eye - it's a nice bike. Share pics when you get it set up!
Quoted: 339 Post(s)
Liked 632 Times
Stealth Paramount
I finished up the PDG Paramount today and took some pics . Weight all up just under 24 lbs. I had to change the wheels as the rear has a spoke that tore out of the rim. I used a set of Navic Open Pro's on 105 hubs and found that the Campi 8 spd cassette wouldn't work so used a Shimano Hyperglide 13-25 instead. I wasn't sure if it would index to the Campy brifters but it seems to work fine. Peeling off the old stickers was easy and there was no hidden damage underneath. The Campi rear derailleur cable adjustment screw was broken but instead of trying to fix it I rummaged around in the bins at the shop and found a matching part in good nick. the front brake also gave me trouble. the cable clamp was frozen. I removed the assembly and soaked it in penetrating oil overnight then used a long shank hex wrench to break it loose. Rather than putting the bolt back , which had the recessed hex head damaged, I fitted another one in it's place and now all is right.
I am a little uncertain as to whether I should have stripped off the Campi group to sell separately . I could probably have used all 105 to build it up like it came from the factory. hopefully we will find a buyer that appreciates it as it is and will pay a decent price for the package. It really is a nice bike.
Cap'n Jonny
Bikex.org
Cap'n Jonny
Bikex.org
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
Cap'n Jonny
Bikex.org
Cap'n Jonny
Bikex.org
Be careful with that front tire -- unless that is an optical illusion, it looks like the bead is about to pop off
Liked 2,922 Times
Likes For smd4:
