WTB: Campag. Record Titanium braze-on 9sp front derailleur
Quoted: 106 Post(s)
Liked 150 Times
From around the mid 1990s. User-condition is fine. Here's a Velobase URL to what I think it should look like.
https://velobase.com/ViewComponent.a...=113&AbsPos=44
lurking nightrider
The Velobase description has the titanium derailleur listed at 108 grams. Does that seem a little bloated to anyone?
I have a Record 9-speed front mech FD-21SRE that weighs only 88 grams.
It's available for sale if you don't have any luck scoring the titanium version. PM me if interested.
"If there hadn't been women we'd still be squatting in a cave eating raw meat, because we made civilization in order to impress our girl friends. And they tolerated it and let us go ahead and play with our toys." Orson Welles
Quoted: 1601 Post(s)
Liked 2,187 Times
So many of the FD's are the same with different silk screening. Two things to watch out for, fist is the length of the parallel arms. The long ones are for triples and may not work well on doubles. Second is the ability to swap mounts between clamp on and braze on. Just remove the screw on the left of the d in Record in the above pic .
lurking nightrider
Is this correct? I was under the impression the width of the cage determines triple or double.
Le Crocodile
Quoted: 367 Post(s)
Liked 771 Times
The triple version is really obvious, it has a very "tall" inner plate. I just picked up a Record FD for a build (same as you want) and it ran $145.00- that is kind of the current going rate for Ex-cond.
Liked 2,187 Times
These are two different FD but the same actuation design.
First up is the triple I thought would work on the double. Turned out that the length of the arms, as noted above, were longer and the outer ring was too close to the frame for the cage to clear the outer ring. Note the location of the "D" of RECORD relative to the screw on the right. Also note where the FD is on the braze on mount compared to the double mounting location.
P1030407 on Flickr
This is a double FD. Note the location of the "D" relative to the screw. A double FD was purchased as a clamp on and converted to braze on by removing a screw and swapping the parts.
P1030470 on Flickr
The price of 10v parts in Record are high. The seller of the triple did not state it was for a triple and I doubt he knew the difference.
