need grease recommendation
Hi,
I just ordered a Shimano UN55 BB for a singlespeed bike, and need a recommendation for what to use to lube the threads. Got some chain lube, but that probably isn't heavy enough. Is automotive wheel bearing grease ok, or is it better to go with something bike specific?
Dave
Dave
Bikes: AristoNYC's PedalRoom
Quoted: 130 Post(s)
Liked 6 Times
I use marine grease from home depot, comes in a tube, but a bearing specific grease will work as well (i.e. phil wood or equivalent https://www.retro-gression.com/colle...erproof-grease)
Lucas Oil 14.5 oz. Marine Grease-10320 - The Home Depot
Bikes: Cannondale Synapse, Focus Izalco, Focus Mares CX, BMC GF02, Giant VT3 MTB (upgraded), Felt Brougham SS
Quoted: 56 Post(s)
I've had good luck with Park Tools grease but I'm sure there are cheaper options. I find these tubes on Amazon last quite awhile for me:
Park Tool Grease in tube
Bikes: steel track
Quoted: 235 Post(s)
Right, don't use chain lube.
You don't need something bike-specific, especially for threads. I'd recommend something waterproof, and you can't beat the price and functionality of some good old marine grease.
Fresh Garbage
+1 for a tub of marine grease, cheaper than Park grease and it will last a long time. Marine grease seems suitable for bicycle bearings as well.
Clark W. Griswold
Quoted: 4253 Post(s)
Liked 3,866 Times
You can be a peasant and go with cheap crappy grease that may not even hold up or you can use the right grease:
Krytox 240 AB Grease, 2 oz. tube
Bikes: steel track
Quoted: 235 Post(s)
Inexpensive marine grease is not actually "cheap" or "crappy". It's excellent for use on bikes, and the only real drawbacks are that 1) it's messier, and makes contamination harder to spot, than something like this, and 2) it's probably thicker than you would want if you're racing and want to squeeze every last bit of performance out of high precision bearings in bottom brackets and hubs. Otherwise, I'm not aware of any genuine reason not to use it on bikes, and, in fact, it's not only inexpensive but probably better than most bike-specific greases in terms of sealing power and hardiness.
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times
I just wish I knew what WI uses on their freewheel pawls. They say specifically to NOT use grease, but they totally do.
Real cyclists use a mix of tallow and paraffin...
any lithium based grease should work fine. Marine grease is usually waterproof, so that sounds like a winner.
You don't want water in those threads, especially the BB.
Calamari Marionette Ph.D
+37 for thick marine grease on all threaded applications. It just sits there, so why not use something thick and waterproof? And if it is rated #2, then it's perfectly fine for all ball bearing applications as well.
Jedi Master
I pack bel-ray into a handy little Dualco grease dispenser. Highly recommend both the grease and dispenser.
Clark W. Griswold
Liked 3,866 Times
The Krytox grease is obviously a joke, but, for less perspicacious readers who might take the other part of the comment seriously:
No one is paying $200 for 2 oz of grease unless the grease cooks you dinner, picks the right movie off Netflix (without two hours of looking) and kisses you sweetly on the taint.
Likes For Carcosa:
Bikes: Mercier Kilo TT - (48/17) / 2004 Schwinn Fastback Comp
Marine Grease from Walmart. You can get RJ the Bike Guys same grease gun from Amazon (I can't link yet)
I always just use the Phil Wood grease for everything. The smaller tube always lasts me a really long time so I never questioned the price. But maybe I'll try that Marine stuff next time I need to buy some.
Quoted: 1332 Post(s)
Liked 398 Times
I bought a tube of Park Tools grease 5+ years ago and I've barely made a dent in it.
Location: Traveling through time, will return last week.
Bikes: Bare Rum Sword Knuckle Runner
Quoted: 278 Post(s)
Liked 122 Times
I used to use the Park PPL1 grease on bottom brackets but now use the Park ASC1 anti-seize. It's not that messy and seems like it doesn't get washed out as easy over time, plus it helps prevent any galvanic corrosion. I also use it on pedal threads as well.
Might have to check this stuff out for my coaster hubs.
For use from -20°F (-29°C) to 560°F (293°C).
Quoted: 94 Post(s)
Liked 72 Times
On a totally unrelated note, is it tacky to start a gofundme to cover your rent? Asking for a friend.
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
Nevertheless, it's going to be applied to the nether regions of a bike anyhow.
Hey don't roll your eyes at me. It might be hidden while in use, but I still have to look at it while I work with it. I was looking into Mobil One full synthetic because it's a rad Jolly Rancher Cherry Red, but the reviews say it sucks. I guess the lube separates from the carrier just sitting in the tub or gun on the shelf at room temperature after only a few months. Many many bad reviews.
Bikes: steel track
Quoted: 235 Post(s)
