Links to basic bolt on chainring cranks?
Quidam Bike Super Hero
Bikes: 1995 Trek 800 Sport, aka, "CamelTrek"
Quoted: 331 Post(s)
Liked 415 Times
Search fu has repeatedly failed to determine the "entry level" for bolt on chainring cranks. Could more knowledgeable individuals provide links, please. Wondering what the price break is to get away form riveted cranksets?
Thanks
Thanks
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1943 Post(s)
Liked 1,464 Times
You did not specify (a) what bottom bracket the crank arms are supposed to fit onto or (b) how many chain rings you wish to mount, but based on your reference to "entry level" and "riveted crankset" I assume JIS and 3X. As it happens I recently bought and installed such a crank set (for a 1X conversion):
Dimension Cyclocross Crank Arm Sets - Modern Bike
Universal Cycles -- Dimension Cyclocross Crankarms [RSC6-RLH 170 BLK, RSC6-RLH 175 BLK]
Dimension Cross Crank Arm Set 110/74mm BCD | Tree Fort Bikes
These Dimension Cyclocross crank arms are actually Andel RSC6 triple crank arms; the inside of each arm is stamped as such. Please verify that your needs match my assumption before you purchase.
Likes For SoSmellyAir:
SE Wis
Quoted: 2744 Post(s)
Liked 3,390 Times
Road or mountain?
Likes For dedhed:
Quoted: 331 Post(s)
Liked 415 Times
Thanks all. It is an Mtb. Current crank is an FCM-311 (triple). BB is an Altus Square Taper BB73 UN26 LL123.
When this eventually goes out, I would like some options. SoSmellyAir, I will check out those urls
Quoted: 331 Post(s)
Liked 415 Times
So, here comes the ignorant question: Except to customize the chainrings, what advantage is there to spending the bucks?
Liked 1,464 Times
Although the Shimano Altus FC-M311 is indeed a JIS square tapered 3X (42T/32T/22T) crankset, the Dimension Cyclocross crankset I linked above will not work with a 32T middle chain ring. The Dimension Cyclocross crankset has a 110 BCD for the outer and middle chain rings, so a 34T is the smallest chain ring which can be mounted.
Liked 1,464 Times
Converting Trek FX2 to 1x - Bike Forums
Quoted: 331 Post(s)
Liked 415 Times
Also (1) better looks, (2) elimination of potential creaking from the riveted chain rings, and (3) the ability to setup as a 2X or 1X crankset if you do not mind the reduction in gear range and/or gear ratios.
Likes For grizzly59:
Quoted: 331 Post(s)
Liked 415 Times
Likes For Digger Goreman:
Liked 1,464 Times
