B Screw question
B Screw question
Old 08-02-22, 04:48 PM
sknhgy
sknhgy's Avatar
Quoted: 4514 Post(s)
Liked 178 Times in 148 Posts
B Screw question
All the B Screw adjustment on my Shimano derailler is taken up and the pully JUST BARELY clears the largest cog. It might even be rubbing a little.
Since all the adjustment is taken up --- Should I remove a few links from the chain in order to get a little more clearance?
Thanks in advance.
sknhgy is offline
Likes For sknhgy:
Old 08-02-22, 05:01 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1546 Post(s)
Liked 848 Times in 610 Posts
How many extra links can you SAFELY remove?
This is a quickie method to determine how much extra chain you have. No sense getting your hands dirty if you don't need to.
Put it in BIG:BIG Cog/chainring.
You want 1-2" excess. More than that can exacerbate your problem to some degree, depending on "how much"
Does the RDER have adequate chain wrap & cog size capacity.
IOW, what's different then before?
Bill Kapaun is offline
Old 08-02-22, 05:02 PM
Polaris OBark
ignominious poltroon
Polaris OBark's Avatar
Quoted: 1129 Post(s)
Liked 1,655 Times in 918 Posts
I don't think shortening the chain would help. Buy a longer bolt (I think they are M4) at the hardware store -- strongest steel you can find, as you don't want it to start to bend.
Polaris OBark is offline
Old 08-02-22, 05:24 PM
70sSanO
70sSanO's Avatar
Quoted: 1812 Post(s)
Liked 1,950 Times in 1,196 Posts
Sometimes if a chain is too long, shortening it might help.
A longer bolt might help. The problem with longer bolts is keeping them on the hanger tab.
Some RD’s just have weak b springs. I found that with a couple of Shimano RD’s rated for 34t and 32t had an issue. On one bike I used a locknut on the end of the b screw to gain enough contact with the hanger tab. Not pretty, but it works.
John
70sSanO is offline
Likes For 70sSanO:
Old 08-02-22, 05:47 PM
andrewclaus
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 594 Post(s)
Liked 475 Times in 312 Posts
Another hack is to turn the B screw around and have the head sit on the hanger.
andrewclaus is offline
Likes For andrewclaus:
Old 08-03-22, 12:59 AM
irtazasheikj
Buy a long chain, if you can. Otherwise, removing chains would not help.
irtazasheikj is offline
Old 08-03-22, 04:52 AM
hokiefyd
hokiefyd's Avatar
Bikes: '18 Redline Zander, '14 Surly Pugsley, '97 GT Vantara, '97 Trek MultiTrack 750, '70 Peugeot UO-18 Mixte
Quoted: 1363 Post(s)
Liked 646 Times in 488 Posts
With most traditional style derailers, where the upper pulley is on a different axis than the top of the cage (and swings up vertically as the cage rotates rearward), shortening the chain can absolutely buy you some room here.
As Bill Kapaun suggested, put the drivetrain in the big-big configuration to see if you can shorten it some. If you determine that you can indeed remove one inner and outer link pair, then put the drivetrain back in the low gear combination and use a small piece of wire or two small screwdrivers as pictured above to mock up what your derailleur cage and upper pulley will do with that one link pair removed. It may rotate that cage just forward enough to sneak that upper pulley down out of the largest sprocket.
A longer chain will not help in this case -- it will generally make the problem worse. A longer chain allows the cage to pull further rearward, which will cause the upper pulley to ride even higher.
And all of the above, again, assumes a traditional style derailer. This does not apply to some of the Shimano Shadows or SRAMs where the upper pulley is mounted coincident with the upper cage pivot. In that case, the upper pulley does NOT move vertically as the cage swings, and chain length should not have an effect on upper pulley position.
hokiefyd is offline
Old 08-03-22, 06:02 AM
sknhgy
sknhgy's Avatar
Thanks. I'm gonna try a longer bolt and see if that works. This is a fairly old bike. At one time or another I might have replaced the chain without comparing it to the one I was replacing.
Or I might have changed cassette/cog size and not adjusted chain length accordingly. But I'm just guessing here.
sknhgy is offline
Old 08-03-22, 09:31 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1928 Post(s)
Liked 2,846 Times in 1,456 Posts
What are you trying to say here?
cxwrench is offline
Likes For cxwrench:
Old 08-03-22, 09:47 PM
easyupbug
Quoted: 450 Post(s)
Liked 387 Times in 287 Posts
You can try as some have said:
reversing the B screw but that makes adjustment messy
add a nut to the end of the screw for more surface area
get a longer screw
do check you hanger and derailleur incase they are bent
shorten the chain don't buy a longer chain!
easyupbug is offline
Old 08-03-22, 09:55 PM
Leisesturm
Quoted: 2003 Post(s)
Liked 450 Times in 326 Posts
What about those Wolf Tooth things that let the RD ride lower to clear a big cog?
Leisesturm is offline
Old 08-04-22, 06:46 AM
sknhgy
sknhgy's Avatar
I ended up taking a few links out of the chain. Don't know if its my imagination, but would that make it so my shift levers require more effort to push?
The longer screw didn't work. Hard to explain but it didn't line up.
sknhgy is offline
Old 08-04-22, 07:07 AM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Bikes: Bob Jackson, Wizard, Pegoretti Duende, Merckx ProSLX, Pelizzoli, Cannondale ST, Schwinn Tempo, Schwinn Voyageur, Canyon Endurace, Richard Sachs, Davidson Discovery
Quoted: 1844 Post(s)
Liked 2,062 Times in 799 Posts
If the bike has horizontal rear dropouts you can unscrew or remove the setscrews and pull the wheel back as far as it will go.
Will require adjusting rear brake shoes.
Usually gives you that extra little bit of clearance between the upper pulley and largest cog when in small/big.
rccardr is offline
Old 08-04-22, 08:19 AM
andrewclaus
Quoted: 594 Post(s)
In post #4 you got some warning about a longer screw not hitting the hanger tab. That was the reason for the suggestion to turn the screw around.
If you made the chain too short, it could be very hard to shift into the large-large combination at least. It shouldn't make a noticeable change in small-small. Be sure you didn't put any crimps in the cable or housing.
Old 08-05-22, 04:02 PM
bikeme
Quoted: 134 Post(s)
Liked 54 Times in 30 Posts
Almost touching is way too close. I was misled by Shimano instructions of having it very close for years. I've found that 5mm between the largest cog's and pulley's teeth is great. Yields plenty of chain wrap on big cog and quieter drivetrain. Per the attached video, also check the b-tension with the chain in big ring and highest cog so there's no belly in the chain (provided chain is proper length). Kyle is does a great job of explaining what b-tension actually does and how to adjust it! FYI, he's a mtb guy but info applies to road bikes too. EDIT: additional thought--if this is a mtb with an after-market extra big gear, you might need a longer (like 25mm) b-tension screw that the RD originally came with.
bikeme is offline
Old 08-06-22, 12:33 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 24266 Post(s)
Liked 7,957 Times in 5,579 Posts
...if it's a "fairly old bike" there are some limitations on the largest cog many of the older rear derailleurs will accept.
Sometimes, you can push that another dog or two, but it's generally a bad idea. They still work then, but not well.
You can look up a lot of the capacity numbers for older derailleurs on VeloBase: link
3alarmer is offline
Old 08-06-22, 01:16 PM
Bill Kapaun
Do you have the proper amount of slack as shown in POST #2?
Old 08-06-22, 01:49 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 3712 Post(s)
Liked 2,549 Times in 1,668 Posts
Question - is this a place where a Wolf Tooth hanger extender can be used? I thought that was what they were for. (But what do I know. I'm still at 28 teeth and downsizing chainrings.)
79pmooney is offline
Old 08-06-22, 03:02 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Wolf Tooth hanger extenders do only 1 of the 2 things a derailleur needs to do and they don't even do that well. I cannot stand those things. They move the derailleur down, that's all. That will allow a larger cog than the derailleur is spec'd to work with...BUT...they make the upper pulley further from the cogs and shifting suffers. The other thing they can't do is magically make the pulley cage longer so it won't wrap the extra chain you'll need for the bigger cogs/longer cage. People blindly suggest them but don't have the basic knowledge to know why they don't work. It even says that right on the WT site.
d
cxwrench is offline
Likes For cxwrench:
Old 08-06-22, 04:38 PM
Iride01
Plz hurry Dec 22!
Iride01's Avatar
Quoted: 4894 Post(s)
Liked 3,413 Times in 2,366 Posts
Shimano says they should be as close as possible without touching. You only said they might be rubbing. Did you ever find out? Here is what Shimano said for my rear DR on a past bike...
Adjusting the B-tension adjust bolt
Mount the chain on the smallest chainring and the largest sprocket, and turn the crank arm backward. Turn the B-tension adjust bolt to adjust the guide pulley to be as close to the sprocket as possible but not so close that it touches. Next, set the chain to the smallest sprocket and repeat the above to make sure that the pulley does not touch the sprocket.
page 14 https://si.shimano.com/en/pdfs/dm/RD...003-09-ENG.pdf
Iride01 is offline
Likes For Iride01:
Old 08-06-22, 05:09 PM
sknhgy
sknhgy's Avatar
Actually, I wasn't clear what to look for using that test.
I took the bike out for a couple hours today. The levers did seem a bit stiffer than normal. But it shifted good.
sknhgy is offline
Old 08-06-22, 05:28 PM
Bill Kapaun
What was difficult to understand about "You want 1-2" excess..."?
Old 08-07-22, 07:50 PM
cxwrench
cxwrench's Avatar
Bikes: lots
You're kidding, right? Bill explained it WITH a photo. Put the bike in big/big. Use the screwdriver/whatever to see if you can pull any extra slack.
cxwrench is offline
Old 08-08-22, 09:41 AM
sknhgy
sknhgy's Avatar
You guys aren't explaining yourselves well. All you are saying is to pinch the chain. Then you get snippy when a person doesn't understand what to be looking for. Here's a couple other threads where the same thing went down:
https://www.bikeforums.net/bicycle-m...ut-pedals.html
https://www.bikeforums.net/bicycle-m...-new-gear.html
But it's OK. There's always Youtube to help us.
sknhgy is offline
Old 08-08-22, 09:51 AM
cxwrench
cxwrench's Avatar
Bikes: lots
I can't imagine it being explained any better. If you don't understand what is being done in Bill's photo I don't know what to say. One more time...shift the bike into big/big (carefully in case there isn't enough chain) then put the screwdrivers in the chain as shown in the photo. If there's enough slack to do that you're good to go. I just twist the chain w/ my fingers but if you don't want to get dirty use the 2 small screwdrivers. If you need a video to make that more easily understood then watch a video. At that point it should be crystal clear.
cxwrench is offline
