Can I put an XDR driver on a MTB Hub?
Old 08-03-22, 08:58 AM
Durian Grey
The hub is a 12x142 DT Swiss 350, j-bend if it matters. Currently has an HG freehub.
It's in a Boost frame with spacers.
I'm moving to 12 speed, and I want to use a specific cassette (Force XG-1271) that is only XDR compatible.
The XDR driver is 1.85 mm longer than the XD, so if I'm understanding correctly I should be able to use this in a boost frame with a narrower spacer. Will it work?
Durian Grey is offline
Old 08-04-22, 04:32 AM
Durian Grey
For anyone else that finds this via search, I'm told it will work by a local mechanic who's tried it.
I'm ditching the idea however since I learned that the cassette I wanted to use (SRAM XPLR gravel) is only compatible with flattop chains.
Likes For Durian Grey:
Old 08-04-22, 09:30 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1928 Post(s)
Liked 2,846 Times in 1,456 Posts
Why do you not want to get the chain as well?
cxwrench is offline
Old 08-05-22, 01:33 AM
Camilo
Quoted: 729 Post(s)
Liked 623 Times in 403 Posts
If you did a web search for DT Swiss 350 hub conversion, the answer would pop right up for you, from DT Swiss itself.
Camilo is offline
Old 08-07-22, 07:44 PM
Durian Grey
In that case I'd need a new chainring also, right? Different roller sizing?
Old 08-07-22, 07:47 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Good point.
cxwrench is offline
