Polar v650 USB problem
Old 04-15-21, 04:43 PM
  #51
joeypo
Originally Posted by AraNim141
Hi,
How did you Uninstall Bonjour?
I can not locate it.
I try connect my Mac Book Pro running with OS Big Sur 11.2 with no luck.
And with iMac late 2012 running with OS Mojave 10.14.6 with the same result.
I uninstall FlowSync, install newer version 4.0.6 and still can not ad V650 into my devices.
HI, mine was on my Windows computer. On a Mac it would be different. I would recommend emailing Polar support.
joeypo is offline
Old 10-08-21, 06:37 PM
  #52
Estaban PDX
Synch Probs Solved
Solution I've used more than once when credentials change
  1. Close all apps on computer and V650, disconnect all USB ports from computer
  2. Turn off all nearby Bluetooth devices, including other Polar devices and phones
  3. Delete Polar synch app from computer
  4. Delete Bonjour app from computer
  5. Restart computer
  6. Restart V650
  7. Re-load Polar synch app (when it does so, it asks to reload Bonjour, do it)
  8. Plug in V650 to computer directly, no other USB plugged in
  9. Polar flow sych app recognizes V650
  10. Computer signs into Polar Flow App Account
  11. V650 synchs fine
Hope it works for you. Love my V650 except when I cannot synch
Estaban PDX is offline
Old 10-11-21, 08:20 AM
  #53
JosSw
  5. Restart computer
  6. Restart V650
I online had to do step 4 (close apps when asked), 7 (Just restart polar sync) 8 (other usb allowed). Then 9, 10 11 works too.
JosSw is offline
Old 10-16-22, 03:10 AM
  #54
JosSw
Fast Solution
Although I read in other forums that this issue should be solved, but it is not on my computer. But I found a faster solution without uninstalling Bonjour. (And thus no need to close a lot of apps which must be closed while uninstalling Bonjour)
  1. Close Polar FlowSync in system tray (up-arrow lower ricght corner, right-click Polar Flow)
  2. Start services (lsearch program>type Services)
  3. Search for Bonjour-service and stop this service (Do not close window)
  4. Start Polar FlowSync
  5. Start Bonjour-service in the windows of step 3
  6. connect V650
  7. start V650
This only takes less than 1 minute.
JosSw is offline
Old 10-25-22, 02:05 AM
  #55
RachelGomez1619
Tips to fix -
#1) Restart Your Computer.
#2) Update Computer.
Tenorshare 4DDiG.
#3) Change USB Root Hub Settings.
#4) Update USB Driver.
#5) Check And Change Ports.
#6) Change USB Selective Suspended Settings.
#7) Format Your Drive.
Regards,
Rachel Gomez
RachelGomez1619 is offline
Gamma Point
Road Cycling
13
12-18-14 10:08 PM
dkatz1
15
02-01-14 08:27 AM
patsfan12
0
12-11-12 03:26 PM
Robert C
1
07-12-12 01:40 PM
walshconor
1
03-03-12 07:58 PM
