Help (advice) needed with French freewheel
Old 11-12-22, 05:34 PM
mgopack42
Bikes: 2020 Argon 18 Krypton Pro, 1985 Masi 3V Volumetrica, 3Rensho Super Record Aero, 2022 Trek District 4.
Quoted: 343 Post(s)
Liked 423 Times in 206 Posts
I am trying to get an 8 speed Sachs Maillard freewheel off. I am thinking the smallest cog(s) act as a lock ring? I remember in the bike shop, we always had 2 chain whips, but I have gotten by with one for the last 30 some years. Also the cogs have an interesting tooth profile. (This is mated to 1990 era Huret-Sachs Rival 8 speed indexed shifters and derailleurs). See pics.
Cool vee shaped tooth profile , on the outer edge
Not what I am used to freewheel wise!
mgopack42 is offline
Old 11-12-22, 05:53 PM
oneclick
Quoted: 1105 Post(s)
Liked 1,324 Times in 781 Posts
If it's a freewheel you need a tool that fits over the axle and engages what appear to be splines within.
There's this new fad called cassettes and they are different, I don't know, maybe they come off with whips.
oneclick is offline
Old 11-12-22, 06:20 PM
Classtime
Classtime's Avatar
Quoted: 1946 Post(s)
Liked 2,004 Times in 1,105 Posts
I’m a fan of the 6 and 7 speed freewheels and its fun to pair them with a Sachs/SRAM chain. Maybe that tooth top treatment helps them run quieter? That could be a UG cassette.
Classtime is offline
Likes For Classtime:
Old 11-12-22, 06:25 PM
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Quoted: 2924 Post(s)
Liked 2,916 Times in 1,488 Posts
All I know about them is they usually don’t put up much of a fight when you want to remove them.
Sugar "Kane" Kowalczyk
Bianchigirll is offline
Old 11-12-22, 06:31 PM
Jeff Wills
Insane Bicycle Mechanic
Jeff Wills's Avatar
Quoted: 797 Post(s)
Liked 694 Times in 371 Posts
It's definitely a freewheel- you can see the removal splines behind the outer locknut. If that's a later-model freewheel, it takes the same tool as Shimano freewheels.
If you can't get enough engagement on the freewheel splines, remove the outer locknut and spacer.
Jeff Wills
Jeff Wills is offline
Likes For Jeff Wills:
Old 11-12-22, 06:36 PM
seypat
Quoted: 3240 Post(s)
Liked 2,512 Times in 1,510 Posts
I see notches in there. Here's the Velobase page that might help.
https://velobase.com/ListComponents....3-3cad77fcf335
seypat is online now
Likes For seypat:
Old 11-12-22, 06:52 PM
mgopack42
Quoted: 343 Post(s)
You are right. This is the one that it is...Sachs-Maillard Aris
you can see the funky teeth very clearly there.
Likes For mgopack42:
Old 11-12-22, 07:36 PM
Chombi1
Chombi1's Avatar
Quoted: 1635 Post(s)
Liked 823 Times in 532 Posts
Yes, the Maillard/Sachs FWs definely usually comes off the hubs quite easily.
The worst ones to take out are the Reginas. I had a few that were so tight on the hubs that I felt like I busted my ribs when I took them off. A couple of my chain whips actually broke on me when removing Regina FWs.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
Chombi1 is offline
Old 11-13-22, 03:55 AM
oneclick
What technique did you use to get freewheels off with chain whips?
oneclick is offline
Likes For oneclick:
Old 11-13-22, 04:16 AM
1989Pre
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1293 Post(s)
Liked 929 Times in 485 Posts
A.R.I.S. takes standard Maillard tool, Park FR-4. The Shimano free-wheel tool, as noted above, is the FR-1.
1989Pre is offline
Old 11-13-22, 07:39 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,393 Times in 1,927 Posts
Yes, but seating the FR-4 will likely require removing the locknut from the axle. A Phil or Zeus tool is thin enough to fit over the locknut.
JohnDThompson is online now
Old 11-13-22, 08:13 AM
1989Pre
Standard Member
You are right about the A.R.I.S. needing the FR-1. It had been so long since I have removed my 6-speed A.R.I.S, that I thought it required the standard Maillard tool, FR-4.
1989Pre is offline
Old 11-13-22, 08:59 AM
Bianchigirll
Bianchi Goddess
I was actually trying to make a joke. Years ago there was a military surplus dealer who used to advertise WWII French rifles as “like new condition only dropped once”. LOL.
Old 11-13-22, 09:18 AM
pastorbobnlnh
Freewheel Medic
pastorbobnlnh's Avatar
Quoted: 1451 Post(s)
Liked 2,183 Times in 960 Posts
I've used (and serviced many) Sachs Aris freewheels, and a modern Shimano tool has always worked for me.
While the Sachs Aris is one of my favorite freewheels to run on a wheel spaced for 126mm rear dropouts, the eight-speed models are intended for 130mm spacing, which does run the risk the hub axle bending since the the bearing cone on the drive side is far inside from the locknut.
The other concern with this model has to do with the type of grease and the method used by Sachs to apply the grease. The bearings are held in red plastic cages which double as seals to keep contaminates from penetrating the interior.
Since no grease is needed to keep the bearings in place during assembly, an injector hole was added to the outer body. Sachs then flooded the interior with grease through this hole. Thus, the bearings and the pawls were embedded in grease. Fast forward three decades and in most cases the original Sachs grease has spoiled into a sticky peanut butter mess.
The Drip and Dribble method of freewheel service will never work on an Aris. It needs to be disassembled, cleaned and new grease added to the races only. I use a few drops of quality machine oil on the pawl pivots.
Bob
pastorbobnlnh is offline
Likes For pastorbobnlnh:
Old 11-14-22, 05:19 AM
mgopack42
Quoted: 343 Post(s)
pastorbobnlnh YOU were right. I used my Park FR 1.3 long reach tool to get it off. Fortunately it spins nice with good pawl engaement, so no peanut butter grease in this one. Thanks for the help!
Old 06-19-23, 07:14 PM
bikemig
bikemig's Avatar
Quoted: 5885 Post(s)
Liked 3,468 Times in 2,078 Posts
snip . . .
This is great info. I was a big fan of Sachs Maillard 7 speed freewheels when they came out and I still have a few of them. By and large, they still operate fine except for one that is stuck. I had no idea why; now I know. Looks like I'll need to send it to the spa treatment especially since it's a very useful 13-32.
bikemig is offline
Likes For bikemig:
