Calories and cycling
#126
Quoted: 20810 Post(s)
Liked 9,456 Times
#127
Bikes: Cross over REI City 1.2
Quoted: 13 Post(s)
Map My Ride might help you figure calorie burn out
MapMyRide has a calorie calculator built into it. Don't know if it is accurate but it does take into account changes in elevation and I think your weight as well. I suspect it is as good anything. For my situations riding in mildly hilly terrain I have found about 50 to 70 calories per mile.
#128
to highlight the discrepancy between calorie estimates and using a power meter, the past 3 rides I've done:
7/28 - Strava calorie estimate: 806, kj: 719 (11% difference)
7/27 - Strava calorie estimate:1797, kj: 1661 (8% difference)
7/26 - Strava calorie estimate: 607. kj: 558 (8% difference)
7/24: Strava calorie estimate: 837, kj: 765 (9% difference)
If you're using HR based estimates or whatever, probably safe to assume near 10% error in the estimate.
#129
Quoted: 4395 Post(s)
Liked 4,837 Times
If you have a power meter, Strava will be using that to calculate both your calories (along with human efficiency coefficient) and total work done in kJ. Without a power meter it has to estimate your power from your route, weight and type of bike etc.
Likes For PeteHski:
#130
Liked 9,456 Times
Yup, Strava is taking the kj info from the power meter into account for their calorie estimates; on rides without a PM, Strava's power and calorie estimates can be way, way off.
Likes For WhyFi:
#131
Quoted: 537 Post(s)
Liked 465 Times
If losing weight is a goal calories are important but quality and time are just as important as amount. Anyone interested can look into intermittent fasting. Clinical studies have been done where amount of calories were were exact between 2 groups. The difference being amount of time between consuming. The group who consumed calories over several meals gained weight and the one meal group lost weight. Insulin release is the driving factor.
Likes For RH Clark:
#132
Quoted: 13 Post(s)
#133
Quoted: 576 Post(s)
Liked 1,001 Times
Don't take any calories on your ride. Just water or zero calorie drinks. If your goal is weight loss, you don't need to eat while exercising. Also, exercise on an empty stomach. If you ride in the morning, don't eat breakfast. Don't eat immediately after a ride either. Let your body burn calories that are already there. Intermittent fasting works for a lot of people. Eating 4-5 smaller meals is generally better than eating 3 big meals. Skipping meals is good also. Our bodies have kind of been programmed to eat in the morning, around noon, and then at night. It won't kill you to skip a meal or two. These are just some easy techniques to limit eating that have worked for me in the past. Oh, and as you get older, weight loss gets more difficult.
#134
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
when you were cutting calories did you feel hungry and weak? I’ll give you an example if I cut 200 calories by switching to egg whites for breakfast I get so tired and weak, mind you I eat 3 meals a day and my breakfast is 750 calories , my largest meal (100g oatmeal, 4 whole eggs and banana ), and I have 1 snack between bf and lunch and lunch and dinner
I'm wondering if your issue isn't what the calories are as opposed to the quantity. I think people tend to vary somewhat on what makes them feel full and/or energetic. For me, that breakfast sounds too carb-heavy, and I think I would get much hungrier mid-morning and possibly a bit shaky on it. My breakfast is about half as many calories as yours, but very low carb outside of the orange I eat every morning. I eat an apple about two hours later, and that gets me to lunch without feeling tired. Also, just under a quart of coffee. I have no idea whether any of that would work for you, but maybe experiment with keeping the calories constant for breakfast, but trying some different foods.
It might not be coincidence that it's the fat in the yolk you're cutting out that makes you feel weak, because it makes the proportion of carbs to other macronutrients even higher.
#135
Quoted: 13 Post(s)
#136
Quoted: 537 Post(s)
Liked 465 Times
I'm not an expert on this but my understanding is that your body is going to burn readily available energy sources when you spike your activity...like biking. It WILL pull calories from protein instead of fat because it needs those calories rapidly. If you have not eaten anything then you have no available protein source. except your muscles. Bottom line is you are going to burn muscle mass instead of fat. I might be wrong but I would research further before skipping eating and going riding.
The body's cells actually change over time to use fat as a source of energy. It won't happen though if the body has a source of carbs to use. Carbs cause insulin release, which isn't necessarily a bad thing, but constant exposure to insulin because of very quickly absorbed processed foods can cause excess insulin and a rollercoaster of high and low blood sugar. Too much insulin causes a blood sugar drop which causes you to get weak and hungry. Then you grab a candy bar and spike sugar again which causes more insulin than should be necessary. It's a constant up and down cycle. If consuming carbs it is much better to use slowly absorbed sources for slower absorption without insulin spikes.
Likes For RH Clark:
#137
Liked 9,456 Times
#138
Quoted: 537 Post(s)
Liked 465 Times
Yes, which is why fasted exercise is particularly helpful to lose weight. There is no need for the body to use fat if there is plenty of glycogen in the muscle and fast absorbing carbs in the stomach. I think I read somewhere that there can be as much a 3-5 pounds of glycogen stored in muscle. I could be mistaken on the amount though.
#139
Quoted: 2333 Post(s)
Liked 2,097 Times
For an endurance rider, a low VLa max is a good thing and frequently riding at high intensity often is counterproductive towards that end. Someone who can burn a lot of fat and pyruvate, will have an FTP much closer to VO2 max percentage-wise than a typical time crunched rider. The changes to type IIA and enzymes take careful training.
I suppose it depends on one's objective. The maximum fat burning power is somewhere just above VT1, maybe low tempo.
#140
Liked 9,456 Times
#141
Liked 2,097 Times
#142
Bikes: Rossetti Vertigo
Quoted: 229 Post(s)
Liked 119 Times
Trust me, you don't need to eat before a workout. Hydrate, yes. Eat a bunch of calores, no. The problem is most people have either never tried, or did it once and didn't like it. Fasting is something that takes time to get used to. Most people go into a mini panic at the first signs of hunger. If the goal is fat loss, you are going to have to make your body uncomfortable. The only way you are in any danger of destroying muscle is due to EXTREME workouts...like how crossfit athletes sometimes experience Rabdo. Look that up if you aren't familiar with it. Sure, you might feel kind of weak and not hit a PR on an empty stomach...but that's not the point. We are talking about weight loss, not maximum performance.
#143
Tragically Ignorant
Liked 9,098 Times
You have to be a bit careful with some qualifiers when you post something like that. There are generally a lot of people with eating disorders who come on to sites like this looking for reinforcements on how what they're doing is actually healthy. If there is a gross imbalance between your calorie intake and your level of activity (y'know, like doing a lot of biking while not eating for extended periods of time), losing muscle mass is definitely a risk, so much so that anorexics can die of cardiac failure.
I'm not saying that's a risk from fasting per se, just excessive fasting. Better to specify what you mean by fasting.
And as far as rhabdo goes, if your pee is looking weird, it's time to back off a little.
#144
Liked 4,837 Times
You make it sound like goading the body to burn fat is a bad thing?
https://www.trainingpeaks.com/blog/t...-for-cyclists/
I’ve done a couple of seasons now with reduced amounts of low intensity base training and I am stronger for it, especially early season. My goal events are tough 100 mile timed Sportives, so not ultra-endurance. Also I’m not looking to lose any significant weight in my training.
#145
Quoted: 229 Post(s)
Liked 119 Times
Likes For pgjackson:
#146
Liked 4,837 Times
#147
Liked 4,837 Times
#148
Tragically Ignorant
Liked 9,098 Times
All I'm saying is that a couple of qualifiers and adjectives could go a long way to making it clear you're not suggesting anything unhealthy. Your statement that "The only way you are in any danger of destroying muscle is due to EXTREME workouts" is actually quite wrong--extreme non-eating can also cause this. "Fasting" means a lot of different things, not sure why you would resist being clear in explaining what you mean by it.
I don't think people with eating disorders are as rare as you seem to think, and it's well-known that they flock to internet forums. Yes, they shouldn't, but that's no excuse to give them ammo to use against themselves.
#149
Quoted: 6192 Post(s)
Liked 4,808 Times
And fasted has a different meaning to most everyone here.
Is fasted just not eating right before a ride? I do that many times with just breakfast at 6:30am and a 2 to 3 hour ride starting at noon.
Or is it a ride in that 12 to 18 hour window that some say you should go between grazing the 'fridge?
#150
Quoted: 229 Post(s)
Liked 119 Times
What you posted is too poorly formulated to determine whether that last sentence is true.
