TWO rear mech housing stops?
Quoted: 1103 Post(s)
Liked 1,309 Times
A while ago I rebuilt a frame that came to me with aftermarket Mercier stickers on it. It has a fork crown engraved mercier, but on removing the paint I found LeJeune original decals on the downtube, plus it has the willow seat-stay cap. (My decision to put Mercier on it after re-painting, sue me.)
Anyway, it also had a pair of housing stops on the chainstay, one above, one below:
Which I thought must have been a bit of re-work, perhaps when the fork was swapped. However, last night I saw nice touring bike with the same thing. I don't have a picture of that one, but it seems there were others. The bike I saw was a "Mikado Cyclotourer", and there's a pic of another Mikado with the very thing right here on BF:
SO - any other examples?
Quoted: 1601 Post(s)
Liked 2,187 Times
A mount for spare spokes?
Bikes: More bikes than riders
Quoted: 1438 Post(s)
Liked 749 Times
I guess this is done to afford the bike builder (whether it's mass produced or custom) as much flexibility as possible. The lower stop would be used if the shift cable passed under the bottom bracket shell and the upper stop would be used if the bike had a cable guide clamped to the seat tube which passed the shift cable over the bottom bracket shell.
Likes For hokiefyd:
Quoted: 3780 Post(s)
Liked 3,284 Times
frame appears to have begun life as an early 1970's Lejeune and has been the recipient of a good deal of reworking in addition to a fork replacement
the under bottom bracket cable routing, water bottle mounts, braze-on front mech, shift lever braze-ons are all additions
in the first image we can see it shows the Lejeune cable housing guide on the drive side chainstay for the rear mech
Lejuene made extensive use of the Prugnat 62/d lug pattern at this epoch
original fork would have worn a Vagner flat top crown and Simplex forged ends
appears to have been manufactured as model Ref. 101
mfr catalogue page dated 1971-72:
note that it yet wears its original Stronglight model 93 chainset, Lyotard model 45CA pedals and MAFAC Racer brakeset
Likes For tyrion:
Quoted: 18319 Post(s)
Liked 4,487 Times
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,445 Times
Quoted: 4719 Post(s)
Liked 3,034 Times
On the pictured Mikado, it is a spare spoke holder., as suggested by SJX426. The Mikado brand consisted primarily of grand touring models and this was a common feature on them. The front braze-on isn't visible in the above photo but here are some photos of another Mikado showing both spoke holder braze-ons.
There have been a number of twin cable rear derailleurs over the years. In the mid to late 1950s both Huret and Simplex offered dual cable versions of their top models. The 2nd cable controlled the cage tension which, at the time, was considered important by professional and avid cyclists, to reduce unneccessary chain friction. Huret used a special duplex cable housing though you could run separate housing.
While Shimano's 1st generation Positron system typically used full length housing, it was possible to run mostly bare cables. This actually improved the accuracy of shifting (as does using modern compressionless cable housing). However, it was technically a single, tandem length cable that was routed from the rear deralleur, then looped around the shift lever spool and back to the rear derailler, to provide a pull-pull system. Cable slippage at the shift lever spool was prevented by a set screw.
On the Mercier, I don't see a 2nd braze-on for spokes, unless it is hidden behind the chainring. While it could be for a 2 cable rear derailleur, the top braze-on is mounted atypically far forward on the top of the chain stay for this function. Normally, the twin cable derailleurs used housings that terminated side by side, both on top of the chainstay, or they ran full length cable housing.
