I want to like Wippermann and Campy chains for my Shimano 9 and 10 speed bikes
Old 09-18-21, 02:52 PM
masi61
masi61's Avatar
Quoted: 1163 Post(s)
Liked 441 Times in 314 Posts
I have been using a 2 or 3 chain systems on my 2 road bikes. I wax my chains and run a clean waxed chain for as long as I can and change it out to the next clean one as soon as it gets too noisy. I have Taya, SRAM, KNC, Campagnolo and Wippermann Connex that I have been running. I do use the Park chain checker tool to just see if there is any significant wear showing up. The SRAM and KNC chains always seem to run really quiet but reach the point of 1.0% wear on my gauge pretty quickly. The Campy c-9 nine speed chain and the Wippermann Connex stainless 10 speed chain are the opposite. They show almost no wear after 1,000 miles or more each but both are kind of tight and noisy. After waxing they quiet down for a while but both have gearing combinations where they sound coarse and "gnash-y". I have decided to ignore this sound as normal since they seem to run great and be super slow to wear.
Just wondering what others would say about Campy and Wippermann chains for Shimano. BTW, I am installing the master links with the correct orientation. I wasn't sure if either of these chains are directional though. They don't appear to be,.
masi61 is offline
Old 09-18-21, 04:19 PM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3646 Post(s)
Liked 5,377 Times in 2,729 Posts
Just to get the obvious out of the way, what's your objection to Shimano chains?
shelbyfv is offline
Likes For shelbyfv:
Old 09-18-21, 06:06 PM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 1523 Post(s)
Liked 716 Times in 508 Posts
I recommend a Shimano 11s chain for a 10s drivetrain.
Kimmo is offline
Old 09-18-21, 07:33 PM
masi61
masi61's Avatar
No objection. I think I just enjoyed trying out some other brands. I have a few 6600 chains for 10 speed, maybe one 7700 9-speed chain in my parts stash.
masi61 is offline
Old 09-18-21, 07:35 PM
masi61
masi61's Avatar
Interesting. What about this set up makes an 11 speed chain run well w/ 10 speed cassettes?
masi61 is offline
Old 09-19-21, 01:15 AM
Kimmo
bike whisperer
Kimmo's Avatar
Same internal width and narrower outer width, yet more bushing area because 11s uses separate bushings instead of them being formed from the inner plates. So less chain rub and longer life.
Kimmo is offline
Old 09-19-21, 06:39 AM
alcjphil
alcjphil's Avatar
Quoted: 1813 Post(s)
Liked 1,691 Times in 972 Posts
Can't say much about Campagnolo or Wipperman chains with Shimano drivetrains, but I recently installed a Wipperman chain on my 10 speed Campagnolo drivetrain and it is by far the quietest running chain I have ever had on that bike. Previously I had Campagnolo or KMC chains. I am told that the Wipperman chain is more durable than a KMC, good thing because it was quite a bit more expensive
alcjphil is offline
Old 09-19-21, 06:44 AM
canklecat
canklecat's Avatar
Quoted: 4559 Post(s)
Liked 2,802 Times in 1,800 Posts
Jangly chain noise is pretty common with dry waxed chains. Just the compromise we make for using wax rather than wet lubes. They're quiet for the first ride after a fresh waxing, but quickly sound jangly in any gear combo other than the middle cogs.
canklecat is offline
Old 09-19-21, 06:47 AM
masi61
masi61's Avatar
yeah, this has pretty much been my experience. As far as I can tell a slightly jangly chain can still be ridden fine for a few more rides.
masi61 is offline
Old 09-19-21, 07:03 AM
canklecat
canklecat's Avatar
Happens with Rock 'n' Roll Absolute Dry too. It appear to be just PTFE powder in naphtha. When the naphtha clears out the original chain lube and evaporates, it just leaves the PTFE powder. Still slick, but jangly.
To compare I've also used Rock 'n' Roll Gold, which seems to add a little oil. It does run quieter. I just got some Rock 'n' Roll Extreme, the blue stuff intended for mountain bikes. Haven't ridden it yet, no idea whether it's quieter.
None of the Rock 'n' Roll lubes run as clean as dry wax. They're good and handy, but not nearly as clean as wax. Cleaner than wet lubes though.
I should go back to dry wax. It worked great. I misplaced my chain waxing kit last year while rearranging my apartment, can't find that crock pot, Gulf wax and container of dry PTFE powder I ordered from China, waited weeks for, and promptly forgot.
Ditto, the quicker wear of the mid-priced KMC chains, whether wet lubed or waxed. I like 'em and use 'em, the Missing Links are handy, but they don't last as long. I get about a year or a few thousand miles with my older 7 and 8-speed bikes. Can't really complain for the price. I haven't tried the KMC premium chains.
Likes For canklecat:
Old 09-19-21, 05:31 PM
Hondo6
Bikes: Yes
Quoted: 549 Post(s)
Liked 665 Times in 462 Posts
Interesting. I wasn't aware of that.
Do you happen to know if the same is true of SRAM 11s chains?
Hondo6 is offline
