Attachment of rear derailleur to hangar
CycleofLife
Bikes: Giant TCR Adv Pro, Caad2, 8, 12 and 13, Giant Revolt, Yasujiro Svelte and Dahon foldie
Quoted: 9 Post(s)
I am a bit puzzled. The rear derailleur has 2 protrusions near the attachment bolt. These protrusions are to "lock" onto the "comma" part of the hanger.
My question ‐ should the "comma" sit between the 2 protusions, or it should rest only on one of them?
If it rests on one of them, the derailleur cage will be raised a bit higher.
What should the right way?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
That's a pretty poor description. You're gonna need to make a few posts and then put a photo up.
Quoted: 1248 Post(s)
Liked 1,323 Times
CycleofLife
Quoted: 9 Post(s)
I was confused because it looks logical to hv the tip of the "comma" of the hanger to be between the 2 protrusions on the rear derailleur.
I am using a new Shimano Ultegra rear derailleur.
Quoted: 18373 Post(s)
Liked 4,507 Times
Many of the new Shimano Derailleurs are "Direct Mount" compatible. Mainly for certain MTBs. So, the mount on the derailleur end has two bars.
You need a derailleur mount to work with standard derailleur hangers.
https://www.universalcycles.com/shop...tribute=249923
I would expect that derailleur mount to come standard with Ultegra derailleurs, but perhaps it is an option.
Liked 4,507 Times
For most bikes with ordinary derailleur hangers, you'll need this part in red.
I'm not quite sure what the direct mount hanger looks like.
Ok, so this is what the direct mount hanger looks like, likely with an offset to match the derailleur.
Liked 1,323 Times
BF have a tendency of making a simple thing rather complicated. Your question was reasonable and very straight forward. Mount it with the 1st protrusion and go for a ride, no need for pictures, derailleur model number, or direct mounts. It will only be going downhill from here.
From the Shimano Rear Derailleur Dealer Manual.
