Wheels with triplet lacing?
Old 04-01-21, 05:59 PM
avhed
Quoted: 112 Post(s)
Liked 8 Times in 7 Posts
Alloy:Campagnolo/Fulcrum, Token, Shimano, Vittoria(discontinued)
Carbon: Deer Cycles, Caden & Hunt
Any other?
avhed is offline
Old 04-01-21, 09:16 PM
Dean V
Quoted: 1067 Post(s)
Liked 259 Times in 153 Posts
"Triplet"?
As in a traditional 3 cross lacing?
Dean V is offline
Old 04-01-21, 10:30 PM
HTupolev
Quoted: 1974 Post(s)
Liked 1,298 Times in 630 Posts
Originally Posted by Dean V
"Triplet"?
"Triplet" is a lacing pattern in which there are twice as many spokes on one side of the wheel as the other. The main reason for doing this is to reduce the DS/NDS tension difference: cross-laced rear wheels often require around double the tension on the DS as the NDS, and since you can only use so much DS tension, the NDS tension is forced to be pretty low (and is therefore a fatigue risk). By using double the spokes on the DS, the necessary NDS tension can be very similar to the DS tension, so nothing ends up undertensioned.
Obviously you need very specific combinations of rim and hub to make this work: the rim's hole count must be a multiple of 3, and you're using a standard hub, you basically need a hub drilled for 4/3rds as many holes as the rim. With commonly-available parts, this pretty much means that you're using a 24H rim on a 32H hub. Or, if you're particularly adventurous, you might use a 36H rim on a 48H hub.
Triplet-specific hubs - with twice as many holes on one flange as the other - are a thing that has occasionally been made, as well.
HTupolev is offline
Likes For HTupolev:
Old 04-02-21, 03:19 AM
rubiksoval
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times in 711 Posts
Bitex makes a triplet hub. You can build your own wheels using that.
I'm rebuilding my triplet wheel and am having a carbon rim made with 16:8 angled spoke holes. I haven't had any issues with the 24 vertical holes I have now, but the wheel manufacturer recommended the angled holes, so I'll give it a shot. Only downside is that this rim must now forever be laced with a 16:8 pattern.
rubiksoval is offline
Old 04-02-21, 06:24 AM
DaveSSS
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 1097 Post(s)
Liked 559 Times in 446 Posts
Campy/Fulcrum has triplet on carbon and aluminum rimmed wheels. The Campy wheels have a more obvious grouping of 7 sets of 3 spokes.
https://www.campagnolo.com/US/en/Whe...acing_bicycles
DaveSSS is offline
Old 04-02-21, 07:42 AM
Litespud
Quoted: 645 Post(s)
Liked 797 Times in 446 Posts
Carbon: Deer Cycles & Hunt
Any other?
Campag refers to it as “G3” lacing
Litespud is offline
Old 04-02-21, 10:14 AM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
I love the idea of triplet wheels, but wonder if they'll go extinct due to disc brakes.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 04-02-21, 11:39 AM
noodle soup
noodle soup's Avatar
Quoted: 4717 Post(s)
Liked 1,882 Times in 998 Posts
I’ve seen it used on disc front wheels
noodle soup is offline
Old 04-02-21, 11:49 AM
abshipp
abshipp's Avatar
Quoted: 3357 Post(s)
Liked 3,636 Times in 1,242 Posts
Every rim I've ever built in to a wheel has alternating holes offset to either side of the rim centerline, is that difference just not a big deal with this lacing pattern or am I misinterpreting something?
abshipp is online now
Steamer
Zircon Encrusted Tweezers
Steamer's Avatar
Quoted: 260 Post(s)
Liked 128 Times in 82 Posts
27 spokes on 36 hole hubs and rims. That should work too, no?
Steamer is offline
Old 04-02-21, 12:05 PM
BradH
Catching Smallmouth
BradH's Avatar
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times in 79 Posts
I've built two sets of triplet laced wheels and have a third on the back burner. My first triplet rear was a H Sons sl42. The spoke holes were ever so slightly offset. Much less than other rims I've seen. It laced up fine and rides without any issues but I'd have preferred the spoke holes be drilled straight or drilled for triplet lacing. My second was a Kinlin 380. It's drilled straight. It worked out perfectly. I have a third in the works for my wife. A Kinlin XR19W. It's also drilled straight.
The DS/NDS spoke tensions come out at less than 10% difference. It really works well.
BradH is offline
Likes For BradH:
Old 04-02-21, 01:08 PM
ThermionicScott
Ah, I could see that. Hub shells are no longer so delicate that twisting would be a problem.
RUSA #7498
Old 04-02-21, 02:01 PM
rubiksoval
Bikes: bikes
Significant offset and/or angled spoke holes won't work. You either need the drilling to match or vertical, centerline holes as already mentioned.
Old 04-02-21, 02:17 PM
DaveSSS
Triplet is still used front and rear on Campy/Fulcrum front and rear disc brake wheels. The front then must have crossed spoke lacing. On rim brake front wheels, radial lacing is used.
DaveSSS is offline
Old 04-03-21, 08:30 PM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 1526 Post(s)
Liked 718 Times in 510 Posts
Any other?
Shimano does it on their deeper rims, they call it OptBal or something.
These wheels I bought are 16/21 too.
Kimmo is offline
Old 04-05-21, 12:51 PM
mercator
In the wind
mercator's Avatar
Bikes: Giant TCR Advanced Team, Lemond Buenos Aires, Giant TCX, Miyata 1000LT
Quoted: 172 Post(s)
Liked 120 Times in 54 Posts
I think Shimano has been doing it for quite a while. I've got some old 7800 and R560 models that are 21 spoke 2:1 lacing on the rear.
mercator is offline
Old 04-05-21, 09:42 PM
smashndash
Quoted: 850 Post(s)
Liked 344 Times in 247 Posts
DT Swiss and Swisside do it on their ARC/Hadron rim brake wheels for the rear.
You could also get this hub: https://www.blackcatwheels.ch/p/shop...p188889980&m=1
The geometry is optimized for triplet, unlike with Bitex's 8:16 hub. Pretty light too. I'm curious as to whether this guy is still active lol.
For rims, afaik any 24H rim with sufficient spoke angle tolerance will probably suffice? I bet Light Bicycle could do something special if you asked.
smashndash is offline
Old 04-05-21, 09:44 PM
smashndash
Quoted: 850 Post(s)
Looks like they use Bitex hubs. What is your NDS flange distance? Is it the same as standard hubs?
Old 04-06-21, 01:23 AM
Kimmo
bike whisperer
Kimmo's Avatar
I'm pretty sure these aren't Bitex hubs.
Ben, the bloke who runs Caden, told me they're made to his design, I think he said by a German mob.
Kimmo is offline
Likes For Kimmo:
Old 04-07-21, 01:24 PM
smashndash
Quoted: 850 Post(s)
Those look solid. Great option. I just saw bitex hubs on their website
Old 08-20-21, 06:39 PM
avhed
Quoted: 112 Post(s)
A problem with these triplet laced rims is that you would not be able to replace a failed rim? Interested in Fulcrum or Shimano aluminum ones.
avhed is offline
Old 08-20-21, 09:05 PM
tomato coupe
Quoted: 3948 Post(s)
Liked 7,291 Times in 2,945 Posts
Why not?
tomato coupe is offline
Old 08-20-21, 09:43 PM
avhed
Quoted: 112 Post(s)
Originally Posted by tomato coupe
Why not?
Availability
avhed is offline
Old 08-21-21, 07:44 AM
DaveSSS
Campy/Fulcrum both sell replacement rims. Unless the need is due to crash damage, I'd just buy a new wheelset, many years later.
The only time I ever ruined rims was due to a car hitting me. I and another rider got T-boned by a car. Both of my wheels got tacoed. The driver's car insurance paid me many times the cost of new wheels.
DaveSSS is offline
Old 08-21-21, 11:31 AM
ThermionicScott
Availability
That's not a problem of triplet wheels specifically, lots of things are harder to come by these days.
P.S. Especially in the world of rim-brake 650B, rims have come and gone out of production before you know it, so I learned to buy spares long before I need them. It's also good to be flexible on the make/model if you can match the ERD to something else.
RUSA #7498
