Weld in bottom bracket?
Hello!
I bought this track frameset recently, and it has a weird weld in the bottom bracket. To me it doesn't make sense - was this done on some BBs or is this just an attempt at a repair job?
Another picture attached shows crimping on the right chainstay which seems relatively normal (for large chainring clearace in this small frame), but I guess could also have been a home job?
Cheers.
Cheers.
(rhymes with spook)
Quoted: 914 Post(s)
Liked 733 Times
1) That looks like factory paint. That in mind, the paint doesn't look to be disturbed or redone in order to make a repair weld or to crimp the stay
2) It also looks to be a "low end" frame. (I don't care to use that term, but it's the best I can do for the moment) and a factory weld like that isn't inconceivable as a way to join the tube. Tubing is either drawn in one piece or rolled and then welded at the seam. You usually find the latter to be the case for more cheaply made frames. Incidentally, a common moniker for cheap frames is "gas pipe" tubing
SE Wis
Quoted: 2055 Post(s)
Liked 1,999 Times
MotuekaCascadeChinook
Bikes: '20 Tarmac Disc Comp '78 Raleigh Competition GS
Quoted: 4188 Post(s)
Liked 2,712 Times
Not weird at all. You'll see more welds like that the further back in time you go with bikes. They just didn't worry about cleaning up welds as much as they do today.
Many bottom brackets were made from a flat piece of steel. Though it might have been sold to the bike builder as a round piece already.
Many will be surprised at how much tubing and piping is made from flat sheets welded up into a round and then the weld removed by grinding and other processes.
Likes For Iride01:
(rhymes with spook)
Quoted: 914 Post(s)
Liked 733 Times
i believe the vast majority of bike frames are made from rolled tubes, are they not? even top of the line stuff. seamless tubes are expensive
Quoted: 1015 Post(s)
Liked 582 Times
There's a seam on the BB of my 1963 electro-forged Schwinn. They started with sheet metal and formed it into that shape. I'd say that it was a great idea when it was invented, but succumbed to higher precision and lighter weight techniques.
To make it cheaper, you could eliminate the weld and hope for the best. One of my kids bikes was that way. Fortunately it was outgrown before anything went wrong.
SE Wis
Liked 1,999 Times
Bottom bracket at 3:38
Likes For dedhed:
Who came out with investment cast lugs first, was it Cinelli?
"Traditional stamped lugs (aka pressed lugs) are formed by pressing sheet steel over a mandrel, bending them to shape, and then welding the seams. These lugs are of constant thickness resulting in stress risers, if large amounts of file work are not done to alter the thickness of the lug. They are easily identified by the visible seam.[6]
Lugs used today on higher performance bicycles are investment cast (aka lost wax process). Copies of the lugs are made in wax, and they are attached together into a "tree". The tree is surrounded by ceramic and fired in a kiln, thereby melting the wax and setting the ceramic. Finally, molten steel is poured in to produce the lug. Cast lugs have many advantages over stamped lugs: they allow much finer detail, tighter tolerances (and correspondingly less manipulation and file work), and more accurate angles, and they can be made from superior materials (chromoly or stainless steel). The disadvantages of cast lugs are few: casting doesn't allow for long points or cutouts (done for aesthetic appeal), it is difficult to bend the lug to change the angle (requiring framebuilders to order lug sets that precisely match the desired frame geometry), and they are more expensive."
Old fart
Quoted: 2919 Post(s)
Liked 1,867 Times
That's a bulge-formed bottom bracket shell. It starts out as a piece of sheet metal. Spigots for the various tubes are pressed into the sheet. then the sheet is rolled circular to form the bottom bracket shell and the seam welded closed. The ends of the tube spigots are milled off, and the shell tapped for the bottom bracket cups. On a low-end frame, little or no effort may be spent making the weld seam attractive.
Likes For JohnDThompson:
Bikes: '79 Gios, '80 Masi, '06 Felt, early '60s Frejus
Quoted: 163 Post(s)
Liked 123 Times
Hardly anybody makes mass-market steel frames anymore. It's all aluminum.
Randomhead
Liked 2,101 Times
It's hard to see from the pictures if this is a low-end frame or not. Most factories didn't grind that weld off, and many European BB shells had a prominent weld there. The lug companies would do a decent job of cleaning up the inside of lugs/bb shells, but left the outside to bike manufacturers. I was impressed by how bad the finish was on Nervex Pro lugs, they were just horrible.
