Difference between chains?
Keepin it Wheel
Quoted: 20 Post(s)
Liked 2,054 Times
Just bought a replacement chain, and was surprised how much more a KMC x10 costs than x9. And given the identical stats in this graphic, what makes a 10s chain different than 9s? (and whatever that difference is, why wouldn't they include that in the chart?)
Quoted: 2970 Post(s)
Liked 3,754 Times
Lighter parts almost always cost more.
Keepin it Wheel
Quoted: 20 Post(s)
Liked 2,054 Times
I get that, but what's the smaller dimension that makes it lighter?
Optically Corrected
Same dimensions but the X10 is made of lighter more expensive material.
X9 color = silver/grey vs X10= silver/black
Quoted: 411 Post(s)
Liked 582 Times
OHhhhh... It's Lighter... I get it...
:D
Liked 1,591 Times
after removung some links; I'd almost go with the x11el based on those specs.
-Oh Hey!
-Oh Hey!
Keepin it Wheel
Quoted: 20 Post(s)
Liked 2,054 Times
Keepin it Wheel
Quoted: 20 Post(s)
Liked 2,054 Times
Looks like probably that chart is just somebody's copy/paste error. Here's "widths measured across the rivet" from ParkTool:
- 12 rear cogs — 5.3 mm
- 11 rear cogs — 5.5 mm
- 10 rear cogs — 6 mm
- 9 rear cogs — 6.5 to 7 mm
- 6, 7, and 8 rear cogs — 7 mm
Likes For RubeRad:
Quoted: 631 Post(s)
Liked 579 Times
The X10 has additional chamfering on the outer plates, which requires more machining time and is probably responsible for the lighter weight. Otherwise, its the same as all bicycle components, the newer stuff is higher priced, because people are willing to pay more for it.
Likes For dsaul:
Quoted: 586 Post(s)
Liked 511 Times
Contact "Papa Ado" who is a KMC rep in Taiwan, is a member and visits here occasionally and gives informed and helpful answers. Bike Forums - Send Message
Quoted: 556 Post(s)
Liked 383 Times
Isn't 10 speed chain thinner in the outer width (but not the inner width) to work with the tighter spacing of the 10 speed cassette vs. 9 speed - thinner plates but same inner and longitudinal dimensions? My understanding is that chains are compatible "downward" but not "upward", so a 10 speed chain would work with 9, 8, etc. but not the other way?
As for cost differences, my guess is that given the same "grade" of chain, the 10 speed is more expensive (1) "just because they can", (2) might be more expensive to manufacture and (3) could be finished blingier.
Keepin it Wheel
Quoted: 20 Post(s)
Liked 2,054 Times
That's what I thought, which is why I was confused by the table I pasted in the OP.
My guess is also, in order to make a thinner chain just as strong, it has to be made of better materials.
Likes For Racing Dan:
Quoted: 654 Post(s)
Liked 500 Times
I tried to run a 10sp chain on an 8 speed drive train - the chain gets stuck between the chain rings. The same 10 sp chain worked fine on my son's 9 sp drivetrain though. So there is enough slop factor for you to go one speed up or down but probably not more than that.
Likes For icemilkcoffee:
:D
Liked 1,591 Times
-Oh Hey!
-Oh Hey!
Likes For Troul:
