First bike: Same priced bike which offers best value for money please help for choice
Old 08-08-21, 10:49 AM
Zentral13
Hi guys and girls I need help for my choice buying first mountain bike I will use mostly for commuting and stuff like uber eats. First of all I must tell that I feel comfortable in both so that is not issue here. I am new to bike world so I want to detail 2 bikes I will call A and B here please let me choose. Both are same prices. In regards of specs which has better value ? I have 5.4 height. I tried both I felt comfortable in both. I have smaller torso so both frames are small and good for me.
Bike A: 27.5 inch wheels, Casette, shimano Altus transmission, much better seat, Old type V brakes (I think this is the reason this deal is so cheap), metallic pedals !, older design (cables outside the frame which is not a big deal perhaps) 15.5 inch frame (slightly lighter)
Bike B: 26 inch wheels, freewheel, lowest end shimano tourney transmission, worse seat(hurts bottom), mechanical disc brakes, better design (cables going inside the frame) 16 inch frame (slightyly heavier) and plastic bike pedals.
My country is very flat but we get a lot of mud rain and snow... I feel bike A has everything better than bike B except brakes. But since my country is flat I don't know.... Please help me choose..
Excuse English I am not native
Zentral13 is offline
Old 08-08-21, 11:01 AM
Welshboy
PBP Ancien (2007)
Welshboy's Avatar
Bikes: Cannondale CAADX (for commuting), Cannondale CAAD12, Cannondale CAAD12 Team CNCPT, Giant Contend 2
Quoted: 63 Post(s)
Liked 121 Times in 78 Posts
If the fit is right for you then I'd go Bike A as well.
Welshboy is offline
Old 08-08-21, 11:19 AM
70sSanO
70sSanO's Avatar
Quoted: 1535 Post(s)
Liked 1,490 Times in 940 Posts
Easy choice... Bike A. Cheap mechanical discs might be worse than decent linear/V brakes with Kool Stop pads.
John
70sSanO is offline
Old 08-08-21, 11:33 AM
Zentral13
John
Thanks this information is crucial for my choice. I am assuming the disc brakes are cheaper versions most probably !
Old 08-08-21, 12:49 PM
shelbyfv
shelbyfv's Avatar
Quoted: 2970 Post(s)
Liked 3,754 Times in 1,931 Posts
Choose Bike A. For Bike B, either the 26" wheels or the freewheel would be enough to eliminate it.
shelbyfv is offline
Likes For shelbyfv:
Old 08-08-21, 02:24 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1567 Post(s)
Liked 627 Times in 352 Posts
That's what I think too but don't underestimate the value of the better seat. Actually, for me the decision isn't even close.
Retro Grouch is offline
Old 08-08-21, 02:48 PM
freeranger
freeranger's Avatar
Quoted: 298 Post(s)
Liked 462 Times in 289 Posts
Another vote for bike A. For all of the reasons mentioned above. And externally routed cables are easier to replace, whenever you may find it necessary. And when your tires wear out, you should find a better selection in 27.5" tires. Pedals and saddle are not a consideration, as those are things most often replaced anyway.
freeranger is offline
Old 08-09-21, 12:53 PM
Feelgood1
Bikes: Ridley Noah SL
Quoted: 19 Post(s)
27.5 wheels.
Feelgood1 is offline
Old 08-09-21, 01:44 PM
VegasTriker
Quoted: 458 Post(s)
Liked 159 Times in 123 Posts
Both bikes seem to be entry level but the one with internal cables may be newer. Only the cheapest newer bikes have a freewheel. Manufacturers stopped using freewheels on better bikes years ago. I would go with bike A. Since you are going to use this bike as a substitute for a road bike, you might use slick or semi-slick tires rather than knobby mountain bike tires. It will give you a faster, quieter, more comfortable ride. This type of tire in the size you need is easily found in the US online.
BTW, congratulations on your ability to translate. It was easy to understand.
VegasTriker is offline
