Compressionless housings & hydraulic lines on folding bikes?
Old 08-10-21, 08:52 PM
sjanzeir
Keeling over.
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 430 Post(s)
Liked 954 Times in 282 Posts
Hello everyone,
For a possible upgrade to a better mechanical or even a hydraulic disk brake system on a folding bike, how well do compressionless cable housings or hydraulic lines play with tight bends? I do fold the bike in question occasionally, but not often. Thanks!
sjanzeir is offline
Old 08-11-21, 07:36 AM
Geepig
Geepig's Avatar
Quoted: 194 Post(s)
Liked 193 Times in 146 Posts
Not well if they are inside the tube or clamped close to the fold, as they need a certain amount of freedom. If the hinge is on the right, they need to be on the left and allowed to turn through an easy curve. Really it is not a lot different to the situation up on the handlebars, where they need enough free movement to survive turning hard to the left to turning hard to the right.
Geepig is offline
Likes For Geepig:
Old 08-11-21, 09:32 AM
Barry2
LR÷P=HR
Bikes: 79 Holdsworth Special, 93 C-dale MT3000 Tandem, 96 C-dale F700CAD3, 2018 Cervelo R3 & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 496 Post(s)
Liked 527 Times in 331 Posts
Brake upgrade
Given that it is a brake upgrade you are looking for, I'd suggest a brake block replacement.
There are better blocks available and it is a lot less trouble and money.
Take a look at Kool Stop
Barry
Barry2 is offline
Likes For Barry2:
Old 08-11-21, 12:40 PM
sjanzeir
Keeling over.
Quoted: 430 Post(s)
Hi Barry! I was referring to my first and only disk brake bike. The rim brakes on my other bikes still perform just fine on their factory blocks, so no issues there.
Back to Geepig's point, here's what the standard coil housings look like at the frame hinge:
The more sharply looped of the two is the rear brake housing. My hand is there for reference, and I've got tiny hands! And that does not look to me like the kind of bend that a compressionless housing - or a hydraulic line, for that matter - could handle and stay intact for long.
sjanzeir is offline
Old 08-11-21, 12:43 PM
Troul
:D
Troul's Avatar
Liked 1,600 Times in 1,106 Posts
I'd give it a wider radius & make sure any connecting points are far away from the bending area.
-Oh Hey!
Troul is offline
Likes For Troul:
Old 08-11-21, 12:48 PM
Racing Dan
Racing Dan's Avatar
Quoted: 1191 Post(s)
Liked 248 Times in 165 Posts
In my experience they are VERY stiff and tricky to install under bar tape. They are like very thick gear cable. I'm not so sure they would work well in your application.
Racing Dan is offline
Likes For Racing Dan:
Old 08-11-21, 01:05 PM
sjanzeir
Keeling over.
Quoted: 430 Post(s)
Dan, are you talking about compressionless housings or hydraulic lines?
sjanzeir is offline
Old 08-11-21, 11:44 PM
Geepig
Geepig's Avatar
Quoted: 194 Post(s)
Back to Geepig's point, here's what the standard coil housings look like at the bend:
If those are round tubes you might be able to find some cable clamps so that you can run the cables/pipes together down the same side, with the clamps further from the hinge. You could experiment by taping a spare compressionless cable to the frame to find the optimal clamping points to get a good turn without risking damage when the bike is folded (like catching the cable on something in the trunk of your car...).
One of my folders has plastic clamps with the same kind of flexibility as a zip tie to hold the cables, allowing me to run the cables somewhere that they do not get hooked up when folded or eaten by the chainwheel while I am riding.
Geepig is offline
Likes For Geepig:
Old 08-12-21, 01:56 AM
Racing Dan
Racing Dan's Avatar
Compressionless housing. Shimano hydraulic brake hose is more compliant.
Old 08-12-21, 07:52 AM
HillRider
Quoted: 1823 Post(s)
Liked 760 Times in 553 Posts
Compressionless brake housing is quite stiff and doesn't tolerate tight bends very well. TRP recommends using it for their mechanical disc brakes (Spyres) with drop bars but also recommends use of a short section (4-5") of standard spiral wound housing to go from the brake lever or brifter around the tight bend from the lever to the straight section of the bar. Then they recommend adding a double end ferrule and using compressionless housing from there to the brake caliper where the bends are wider.
HillRider is offline
Likes For HillRider:
Old 08-12-21, 08:45 AM
base2
Doesn't brain good.
base2's Avatar
Bikes: 5 good ones, and the occasional project.
Quoted: 1004 Post(s)
Liked 652 Times in 387 Posts
In my experience with compressionless housing, the tight bend such as under the bar tape really only affect how easily the inner cable slides. With the tight bend, the compressionless housing squishes to an oval shape & pinches the inner cable. The coiled shortie sections made by Jagwire are a good solution if this proves itself a problem for your particular installation.
For short sections such as the top tube cable stop to the rear brake, I find that most often it will ovalize & pinch as above, gumming up the release action of the brake spring. But, with a few firm brake applications, the short section of housing can then be removed & the ends of the cable can then be trimmed up square. (The inside & outside of the radius are different lengths. It takes a firm pressure to move & equalize the individual linear strands.) After the additional rework, the housing & brakes work as expected.
For a folding bike, just keep your cable radiuses large at the fold & don't expect the brakes to release well while riding it in the folded configuration.
You'll be fine.
base2 is online now
Likes For base2:
Old 08-12-21, 12:55 PM
veganbikes
Clark W. Griswold
Quoted: 2809 Post(s)
Liked 1,967 Times in 1,305 Posts
Use the Jagwire Elite Link housing and you will do well.
veganbikes is offline
Likes For veganbikes:
Old 08-12-21, 02:10 PM
Crankycrank
Quoted: 588 Post(s)
Liked 515 Times in 397 Posts
There are also screw-together cable splitters. Here are two examples. Cable splitters for S&S Coupled travel bikes (sandsmachine.com) Just install at the bend and no problem folding the bike up. Also for hydraulics I know you can get leakproof splitter couplings for motorcycles but not sure if they're available for bicycle sized tubing.
Crankycrank is offline
Likes For Crankycrank:
Old 08-12-21, 06:58 PM
sjanzeir
Keeling over.
Quoted: 430 Post(s)
You'll be fine.
Touché!
My concern was that given their structure, compressionless housings or hydraulic lines might sustain damage after multiple folding and unfolding cycles.
sjanzeir is offline
Likes For sjanzeir:
Old 08-12-21, 08:28 PM
cpach
Bikes: Too many. Cannondale SuperSix, Trek Remedy 8, Trek Crossrip+ get the most ride time.
Quoted: 489 Post(s)
Liked 262 Times in 201 Posts
From the looks of your picture, hydraulic line will probably be just fine.
cpach is offline
