Shimano Sora Thumb Shifter
Quoted: 21 Post(s)
I have a 2012 Specialized Dolce with Shimano Sora. Bike has not been ridden in awhile but my wife wants to start using it again.
Its a 9 speed with two chain rings on the drive side. For that year bike shimano designed the shifters with a big lever and a thumb shifter. The thumb shifter does the same thing the smaller shifter would do. On the left side the big lever pulls the chain up to the bigger ring. It takes 2 shifts to do this and I imagine this is because it was also designed to work with a a 3 ring chain.
When I use the thumb shifter to get it back on the smaller ring, you have to press really hard to get it to release and then its two clicks
Any suggestions on how to unfreeze it so you don't have to press so hard? Is it possible to adjust the system from 1 to 2 clicks?
Quoted: 437 Post(s)
Liked 642 Times
It may be set such that the derailleur hits the stop before the shifter has pulled enough cable to hit the final click. This means you have to reach super high cable tension to compress the housing enough to get to the click, and then that tension is pulling against the shift mechanism which makes it difficult to actuate the lever.
A couple thoughts -
1. If you shift to lowest gear (shifter lets out all cable), is the cable completely slack, or is it close to being under tension? In my experience, if using a triple shifter on a double crank, it is best to use the click between the shifter's gear 1 and 2 - the first click rather than between the shifter's click between 2 and 3. If you let all the cable out of the shifter, set the L endpoint screw so the F derailleur is barely touching the chain when the rear derailleur is on the smallest cog, then undo the F derailleur cable bolt and pull all the slack through. Adjusting the point on the cable that is anchored to the derailleur may be the solution to all your problems.
2. Are you sure you have the F derailleur cable routed through the front derailleur properly? A lot of F derailleurs require a specific angle of approach for the cable and it is not necessarily intuitive when putting it together.
3. Is it possible there are 'trim' clicks in your shifter - clicks half way between the gears intended to allow you to move the derailleur slightly to keep the derailleur from rubbing when the chain is at more of an angle? Most indexed road shifters have this feature, but possibly not Sora.
A couple thoughts -
Likes For ClydeClydeson:
Doesn't brain good.
Bikes: 5 good ones, and the occasional project.
Quoted: 1000 Post(s)
Liked 651 Times
The firmness of the thumb clicker release button has to do with how hard the shifter mechanism is jammed against the derailleur limit screw. Try backing off the inline tension adjuster. Or, if you don't have one or if it is as short as it can be made, back off the front derailleur H-screw, but not so much the derailleur overshifts over the big ring. If this helps, but overshifts, reset the cable tension at the fixing bolt.
Sora came in both double & triple versions. Don't confuse the trim position of a double version with the 2nd chain ring position of the 3 ring version. The model number embossed in the shifter under the hood will tell you which one you have. IIRC triple versions of most Shimano things end in "03"
My lights are obscenly bright because drivers are dim.
Likes For base2:
Quoted: 1529 Post(s)
Liked 1,479 Times
I recently found the chart below online, although I think it has been around for a while. I posted it in another thread but so far no one has said it is wrong. I find invaluable for knowing where the trim points are, and what each click is supposed to do for different STI shifters.
The first thing you need to do is figure out what each click does. I've never had an issue with an STI shifter freezing if I used the inner-middle positions, but I understand others have.
It is my understanding that the one thing about the Shimano thumb downshift lever is that is has no trim function. When you press it, it will drop down to the next chainring position. Inner chainring trim to inner, outer chainring to first, outer trim to outer.
I would remove the chain, disconnect the cable go to the inner shifter position, reconnect the cable and see how the derailleur moves each direction for each click (Added: The ST-3400 has an optical display that will move more for a complete shift and less for trim). Cable tension, how slack in the inner chainring, and the high limit stop play a part in forcing the shifter and wedging/freezing against the pawl in the shifter.
John
John
Quoted: 21 Post(s)
These responses are so helpful. I will take a look at the cable tension and limit screws on the front derailleur. Do the shifters need any kind of lubrication?
Quoted: 1407 Post(s)
Liked 976 Times
When I set up a triple shifter to shift a double, I set it up so that the unused position lets the cable go slack when the derailleur is on the small ring, rather than using the high limit to lock out the third shift. This avoids jamming (and potentially damaging) the mechanism against the high limit while accidentally attempting to shift past the big ring.
Likes For dsbrantjr:
Liked 1,479 Times
The only way I can see it getting jammed, using the inner and middle shift positions, is if you set the high limit screw to stop the FD; which you don’t need to do. There is no middle limit screw stop to set on a triple and it doesn’t overshift. Of course you have to set it to prevent another shift.
It can become a bit of an art form getting the right low limit, cable slack, or lack thereof, so that the shift works correctly. Actually, I set the high limit after I’ve got everything setup correctly with an STI. That way there is no pressure or forcing against a hard stop. I just try to get barely backed off.
Running a triple STI shifter with a double crank requires a high limit to stop from shifting to a non-existent 3rd chainring. A double STI shifter with a double crank makes a high limit a bit redundant; but we all set it. Same with a low limit setting on an RD with an STI shifter. And it is just as possible to force a RD shifter pawl with a bad low limit setting.
John
John
Quoted: 3354 Post(s)
Liked 1,995 Times
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 653 Post(s)
Liked 492 Times
Anyways, to the OP: you should definitely take the brifters apart, flush out the old grease and lube with new grease. They all get gunked up with age.
Liked 1,479 Times
John
Edit Added: It appears that there is also a thumb (B lever) trim on the ST-2300 double; not the ST-2303.
