On the go repair of tire flats
Old 08-21-21, 12:02 PM
oleg232000
Bikes: Litepseed Catalyst Neutral Support Bike, La Pierre Spicy Team, Mercier Kilo TT, Cannondale Multisport2000, Goffa BMX, Haro Dave Mirra Freestyle
Quoted: 82 Post(s)
Liked 21 Times in 12 Posts
So my gatorskin finally got a puncture after 1200 miles of rough roads. Pulled over and tried to repair it, but my self adhesive patches didnt stick for *****, and thus i was out of luck. Can anyone recommend a kit that actually works? Should I be using a tubed glue instead of the self adhesive patches?
Also, I just discovered sealant filled tubes (yes laugh if you must). Do these work? Are they worth the investment? I was looking at the Slime brand. Just bought the sealant alone to experiment with.
Thanks
oleg232000 is offline
Old 08-21-21, 12:04 PM
10 Wheels
Galveston County Texas
10 Wheels's Avatar
Bikes: 02 GTO, 2011 Magnum
Quoted: 1187 Post(s)
Liked 852 Times in 414 Posts
I carry 3 to 5 spare tubes. Always patch at home.
Fred "The Real Fred"
10 Wheels is offline
Old 08-21-21, 01:23 PM
Warbird21
Warbird21's Avatar
Bikes: Salsa Warbird
Quoted: 63 Post(s)
Liked 91 Times in 58 Posts
I have the small, Park patch kits. Patched two tubes, neither held. Do you peel off the clear plastic film over the patch, or just leave it? I did it both ways, neither held air...
Warbird21 is offline
Old 08-21-21, 01:33 PM
zandoval
zandoval's Avatar
Quoted: 413 Post(s)
Liked 589 Times in 404 Posts
Looks like you got your moneys worth out of that Gator Skin. I carry around a cheap little patch kit that has an unopened 5 gram tube of vulcanizing cement. In that little box I also put in a razor blade, tooth pick, some alcohol wipes, and an unopened tube of Super Glue in-case the vulcanizing cement dries out. I gave up on the stick on patches long ago. Some people use them, but I have never been able to get mine to work.
zandoval is offline
Likes For zandoval:
Old 08-21-21, 02:32 PM
datlas
Beyond Bogus
datlas's Avatar
Quoted: 17481 Post(s)
Liked 4,807 Times in 2,332 Posts
This. Plan B is self-adhesive patch.
But did you rough up the tube before applying the patch?
Addiction is all about class.
datlas is offline
Old 08-21-21, 03:30 PM
RiceAWay
Quoted: 293 Post(s)
Liked 110 Times in 79 Posts
The Park Self adhesive Quick Patches work well. The Chinese cheapies still work but you have to be very careful sanding down the entire area you want the patch to stick on. The Park patches aren't quite so picky.
RiceAWay is offline
Old 08-21-21, 03:35 PM
RiceAWay
Quoted: 293 Post(s)
I generally like the vulcanizing patches as well but quick patches take up less room and the only thing to remember is to carefully sand the area where you have to stick the quick patch. You have to do this with the vulcanizing patches as well so you simply skip the glue step. Most of the wheels I have are those idiotic "two way" wheels which make it so difficult to get tires on and off of so I often pinch tubes trying to get the tires on.
RiceAWay is offline
Old 08-21-21, 03:36 PM
jaxgtr
jaxgtr's Avatar
Bikes: Trek Domane SLR 7, Trek Emonda ALR 6, Trek FX 5 Sport
Quoted: 413 Post(s)
Liked 821 Times in 500 Posts
like 10 wheels, I do not patch on the road, I replace the tube and patch at home if patch-able.
Brian | 2021 Trek Domane SLR 7 | 2016 Trek Emonda ALR 6 | 2022 Trek FX Sport 5 (On Order)
Originally Posted by AEO View Post
you should learn to embrace change, and mock it's failings every step of the way.
jaxgtr is offline
Likes For jaxgtr:
Old 08-21-21, 03:40 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4176 Post(s)
Liked 1,171 Times in 768 Posts
You do know that the patches have to go on the tube inside the tire, right?
Sy Reene is offline
Old 08-21-21, 03:43 PM
N2deep
N2deep's Avatar
Quoted: 64 Post(s)
Liked 76 Times in 48 Posts
Although i carry a small park brand patch kit, I also carry a spare tube and only patch on the road if absolutely necessary. Patch or replace at home.
N2deep is offline
Old 08-21-21, 03:53 PM
jaxgtr
jaxgtr's Avatar
Quoted: 413 Post(s)
I personally would not use Slime.....If you were to head down that road, I would go tubeless if your rims are tubeless ready
jaxgtr is offline
Old 08-21-21, 04:05 PM
bargo68
Dedicated Detritus Dodger
bargo68's Avatar
Bikes: Some mighty fine ones at that!
Quoted: 152 Post(s)
Liked 420 Times in 200 Posts
Rema
Tip
Top
Learn how to properly patch a tube on YouTube:
bargo68 is offline
Likes For bargo68:
Old 08-22-21, 01:10 AM
tempocyclist
tempocyclist's Avatar
Quoted: 130 Post(s)
Liked 284 Times in 146 Posts
Carry and pop in a new tube at the roadside, it's quicker than patching. The self-adhesive patches can be a little hit and miss (I find Park Tools ones good) so I only use them as a last resort. Carrying one or even two spare tubes hardly takes up any room on a saddle bag, bottle cage storage or even jersey pocket if you must. The superlight style tubes pack down incredibly small.
The old school glue-on patches are the best. I've never once had an issue with those, but I always patch later in the comfort of home.
Now that's being properly prepared! 😁
tempocyclist is offline
Old 08-22-21, 08:59 AM
Racing Dan
Racing Dan's Avatar
Quoted: 1191 Post(s)
Liked 248 Times in 165 Posts
Finding a hole in a tube at the roadside is next to impossible. > Carry one or two spare tubes. Patch at home. Use proper patches, like in the post above.
Thats how I do it. That's how Dad did it. That's how America does it.
Racing Dan is offline
Likes For Racing Dan:
Old 08-22-21, 09:40 AM
caloso
caloso's Avatar
Quoted: 2865 Post(s)
Liked 2,843 Times in 1,310 Posts
I carry a spare tube and a Rema patch kit. First flat gets a new tube, second and subsequent get patched.
caloso is online now
Old 08-22-21, 10:06 AM
Quoted: 15367 Post(s)
Liked 9,147 Times in 4,520 Posts
Hes done some unsupported touring.
I take three tubes on tours in more remote areas along with a patch kit. Closer to home, where I know the roads and there shops on or near the route, usually only two and the patch kit.
indyfabz is online now
Old 08-22-21, 05:11 PM
Bolo Grubb
Bolo Grubb's Avatar
Bikes: 1984 Trek 720 with a Nexus hub, 2016 Cannondale Synapse
Quoted: 31 Post(s)
Liked 17 Times in 10 Posts
I do the same.
Bolo Grubb is offline
Old 08-22-21, 06:41 PM
MinnMan
MinnMan's Avatar
Bikes: 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 3423 Post(s)
Liked 2,378 Times in 1,444 Posts
Never had much luck with patches. Spare tubes. If I run out of those, I'm out of luck.
MinnMan is online now
Likes For MinnMan:
Old 08-22-21, 06:44 PM
MinnMan
MinnMan's Avatar
Originally Posted by bargo68 View Post
Rema
Tip
Top
https://youtu.be/T0F_hibWHlU
Park Tool is local to Minnesota. I was doing support for a road race earlier this year. Park Tool was a sponsor and sent a mechanic for on-the-fly repairs. Lo and behold, it was Calvin Jones. I felt like I was meeting a celebrity.
Likes For MinnMan:
Old 08-22-21, 10:45 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3500 Post(s)
Liked 1,827 Times in 1,175 Posts
At the risk of jinxing myself, it's been a long time since I've patched a tube on the road. On the rare occasion I get a flat, I use the spare tube I have with me, and the Rema patch kit just waits for my luck to worsen. Saving up punctured tubes and patching them as a bunch of 6+ at home lets me get a lot of use out of a fresh tube of glue, and then I'm set for a while.
Also, bringing a spare tube is good karma if it can help someone else. My 650B bike carries a spare 700C tube as well since there's often someone who'll need it.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 08-24-21, 12:24 PM
oleg232000
Quoted: 82 Post(s)
BWAHAHA....good one
So to be more precise, I actually did make it home and tried to repair it. The tube had a tiny puncture from a thorn so that is why I decided to patch instead of replace right away. But I like the whole crazy glue tube idea.
But def agree with the whole replace with a new tube prior to patching. Follow up question, are you guys carrying pumps or Co2? I usually carry a pump on longer rides, but those cartridges look real tempting. Any thoughts on using CO2 cartridges?
Old 08-24-21, 12:38 PM
Not2Bright
Quoted: 10 Post(s)
Liked 3 Times in 3 Posts
Thanks
I have a slime tube in my rear 700x35 Schwalbe marathon plus for just over 1,000 miles now. It is my first time trying pre-filled slime tubes. The information that came with the tube said it is good for 2 years, whatever that means. As a cheapskate I'll run it till it fails. If it punctures and doesn't self seal I doubt it can be patched with all that slime contaminating the site.
I always cary a spare tube to save the frustration of seeing a patch fail.
Not2Bright is offline
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 17100 Post(s)
Liked 9,010 Times in 5,059 Posts
I pretty much stopped getting flats when I went tubeless.
Patches are great, they have you money and keep useable goods out of the landfill! But they're a pain in the ass too. As you learned. Carry a* spare tube, use it in times of crisis, patch the old one in the comfort of your home with a cup of comfort and some good music playing. That should be your plan, one day you'll get caught out in the rain and flat.
* Note: "carry a spare tube" means at least one, but depending on your circumstances you might want more. Long ride, thorny route, anything that means more chance of flats means at least think about taking another tube so you don't have to walk home in your road shoes.
Seattle Forrest is offline
Old 08-24-21, 01:28 PM
MinnMan
MinnMan's Avatar
have I got a thread for you....
Old 08-24-21, 01:41 PM
Racing Dan
Racing Dan's Avatar
BWAHAHA....good one
Just so you know. Reaping pinholes with "crazy glue" is a perfectly viable option. Just make sure to stretch the tube a bit to make let the glue into the hole, and make sure to Not to glue the tube flat. Ive done it a few times and it holds air no problem, just like a normal patch.
