DT Swiss 240s replacement bearings
Old 08-23-21, 03:40 AM
azza_333
azza_333's Avatar
Bikes: A few
Quoted: 122 Post(s)
Liked 3 Times in 3 Posts
I have been trying to find out what replacement bearings I need for my hubs, but I am finding a lot of conflicting information.
Front Hub: DT Swiss 240s, Centre Lock, 32 hole, 12mm x 100mm through axle
Rear Hub: DT Swiss 240s, Centre Lock, 32 hole, 12mm x 142mm through axle, 11 speed Shimano road free hub (I am replacing it with a steel 10 steel one though, if that makes a difference).
Does any know what bearings I need?
Thanks in advanced.
azza_333 is offline
Old 08-23-21, 04:30 AM
Badger6
Obsessed with Eddington
Badger6's Avatar
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 456 Post(s)
Liked 526 Times in 320 Posts
Thanks in advanced.
https://www.dtswiss.com/en/support/product-support
Try that, first.
Badger6 is offline
Old 08-23-21, 04:37 AM
azza_333
azza_333's Avatar
Bikes: A few
Quoted: 122 Post(s)
Originally Posted by Badger6 View Post
Tanks, but I have already seen that, there year model for the 240 only goes back as far as 2019, I think mine are a 2015 model.
azza_333 is offline
Old 08-23-21, 04:59 AM
Badger6
Badger6's Avatar
Quoted: 456 Post(s)
Did a little more looking, and found this chart, and it is NOT MY specific. https://www.bike24.com/p2124210.html
Have you tried to contact the service center (centre)? I'm guessing they would be able to assist also.
Badger6 is offline
Old 08-23-21, 06:17 AM
gearbasher
gearbasher's Avatar
Quoted: 294 Post(s)
Liked 254 Times in 155 Posts
When all else fails, remove the bearings and look for numbers or measure them.
gearbasher is offline
Likes For gearbasher:
Old 08-23-21, 10:25 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1414 Post(s)
Liked 1,978 Times in 1,051 Posts
If you're going to replace the bearings why don't you just take off the NDS axle cap and look? The info you need is right on the bearing shield.
cxwrench is offline
Likes For cxwrench:
Old 08-24-21, 08:28 AM
easyupbug
Quoted: 384 Post(s)
Liked 272 Times in 198 Posts
You are going to pull the bearings anyway so just take them to Statewide Bearing; I worked in Kalgoorlie and think I remember one in Perth. If not there will be an industrial bearing supply near by.
easyupbug is offline
Old 08-25-21, 04:15 AM
bitpuddle
Bikes: Cinelli Nemo Tig / Battaglin Power Plus / Giant TCR SL
Quoted: 25 Post(s)
Liked 17 Times in 12 Posts
You have to check your specific hub, but I think those are 6902 both front and rear. The freehub bearings would be a different size.
bitpuddle is offline
