Shimano organic brake pad mileage on road
Old 09-03-21, 09:19 PM
azza_333
azza_333's Avatar
Bikes: A few
Quoted: 122 Post(s)
Liked 3 Times in 3 Posts
I am curious to know how how many miles/kilometers everyone gets out of a set of Shimano organic brake pads on road, and what kind of weather/road/terrain conditions were experienced that you got those miles/kilometers with.
azza_333 is offline
Old 09-03-21, 09:48 PM
fooferdoggie
Quoted: 409 Post(s)
Liked 504 Times in 305 Posts
maybe 1500 to 200 miles thats in the city lots of stoping and slowing on hills. our tandem goes through them like crazy. n the metallic only Give a little over 2000 miles on the tandem.
fooferdoggie is offline
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1386 Post(s)
Liked 1,923 Times in 1,023 Posts
They can wear out in as little as an hour at a muddy cx race or they can last a year in dry on flat-ish terrain.
cxwrench is offline
Old 09-03-21, 10:22 PM
AdkMtnMonster
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 397 Post(s)
Liked 787 Times in 338 Posts
I’m looking at about two full srasond on a set, but I don’t brake much on my rides, until I get back to my garage. Looong miles without having to stop, no traffic lights, no stop signs. Ride all day, rarely ever see another cyclist. I can see how a more populated area would wear them out fast. Logged 7300 miles last year, over 5000 this year. Not a champion, but not a typical couchcowboy, either.
AdkMtnMonster is offline
Old 09-04-21, 12:18 AM
nathand
Bikes: 2018 Jamis Renegade Exploit, 1996 Trek 930, mid-90's Dean El Diente, 2010 Scott Addict SL, 1998 Trek 730, Xtracycle EdgeRunner 30D
Quoted: 54 Post(s)
Liked 58 Times in 40 Posts
I have Shimano organic pads on my gravel bike, which has seen a lot of road use (even on "gravel" rides I usually do more distance on roads getting to and from the trails, than miles on actual gravel). I think I only got about 1000 miles from my the front pads and a bit more from the rear; I was disappointed at how quickly they wore compared to rim brake pads. I was so certain they couldn't have worn that quickly that I spent much too long trying to adjust the caliper position to reduce noisy breaking. I finally pulled the pads and discovered that the noise was because pads had worn to where the thin metal springs were thicker than the remaining pad material and those springs make a horrible squeak when they touch the rotor. Those were the Shimano L02A pads. I replaced them with the newer L03A pads which, according to to https://www.bike-components.de/en/Sh...-Mount-p68530/ (first result on Google) have improved lifetime:
"The durability of the Shimano L03A brake pads has been significantly increased compared to the previous L02A model thanks to a new resin compound."
I look forward to finding out if these pads wear more slowly.
nathand is offline
Old 09-04-21, 09:33 AM
Iride01
MotuekaCascadeChinook
Iride01's Avatar
Bikes: '20 Tarmac Disc Comp '78 Raleigh Competition GS
Quoted: 4146 Post(s)
Liked 2,665 Times in 1,855 Posts
Shimano has several models of "organic" pads for the same brake. And since Shimano claims one lasts longer than the other, wouldn't that be pertinent info that one might need to relate here with their experience?
I've got 3500 miles so far on my L03A pads. And they still have a .5 millimeter of life left in them. The rear a little less since I drag the back brake more while doing twisty downhills.
Iride01 is offline
Old 09-04-21, 09:50 AM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 5394 Post(s)
Liked 5,651 Times in 2,881 Posts
Mine have gone 1800 miles so far with 2mm of pad left.
genejockey is offline
Old 09-04-21, 09:54 AM
wolfchild
wolfchild's Avatar
Quoted: 2734 Post(s)
Liked 1,515 Times in 737 Posts
It all depends on your riding style, terrain and weather conditions.
wolfchild is offline
Likes For wolfchild:
Old 09-04-21, 04:18 PM
NoWhammies
NoWhammies's Avatar
Quoted: 707 Post(s)
Liked 344 Times in 223 Posts
I get about 5,000km out of my L03A brake pads. I am riding in dry conditions although I do a lot of hill climbing and thus a lot of descending.
NoWhammies is offline
Old 09-05-21, 04:46 PM
epnnf
epnnf's Avatar
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 219 Post(s)
Liked 62 Times in 43 Posts
I use resin pads, almost always dry conditions & keep them clean. I change after 2yrs (4kmiles)?, but could probably go a year or more longer.
epnnf is offline
Old 09-05-21, 05:06 PM
PeteHski
PeteHski's Avatar
Quoted: 1493 Post(s)
Liked 1,587 Times in 1,020 Posts
Mine are lasting a lot longer than I expected. I do a lot of steep hilly rides and they are still going strong after maybe 10,000 km but that's a guess.
PeteHski is offline
