11 speed crank with 9 speed drivetrain or other workarounds to accommodate powermeter
Old 09-19-21, 11:41 AM
MontrealCyclist
Hi everyone,
I got an old bike, a 2x9 speed which came with a mix of 105 and Tiagra (but mostly Tiagra).
The thing is I just bought a 4iiii power meter because it was a good deal. It comes on a Shimano 105 FC-5800 left-side crank arm. Now I only need to buy a fitting crankset so that I can use it on the bike. But obviously, the FC-5800 is 11 speed, which from what I understand is not optimal in combination with a 9 speed drivetrain. So what are my options really ? Can I buy a 105 right side crank arm (available on ebay) and pair it with the 9 speed chainrings that I already got on the bike (FSA) or Shimano 9 speed chainrings that I can find on ebay ? Should I try to stick to an old 9 speed Tiagra crank (hard to find) ?
From what I understand, the crank arm on which the power meter is located can be used on any Shimano crank that is Hollowtech II.
The reason I bought the power meter is that I will eventually get a new bike with a brand new 105 groupset, and so I could just bring the power meter on the new bike. But in the meantime... I would be glad to hear from you guys.
Cheers
MontrealCyclist is offline
Old 09-19-21, 03:15 PM
squirtdad
squirtdad's Avatar
Quoted: 1679 Post(s)
Liked 1,221 Times in 764 Posts
this is one of these times that saving money is probably going to end up costing you money. 5800 105 is out of production for 2-3 years now., so it is getting hard to find them new. Newer bikes are going to have 105 7000 series. so unless you find a bike with 105 5800 fast, you will not have matching crank arms.
My best advice would be to return it if you can (willing to bet clever training closeout ?) and then get the power meter you need to match the group you end up with when you finally get your new bike
I have no experience running 11speed cranks with 9 speed everything else, so won't guess there
squirtdad is offline
Old 09-19-21, 03:25 PM
Viich
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), 90's Giant Innova (now with drop bars), FMF Race BMX, Redline Proline Pro24 Cruiser
Quoted: 292 Post(s)
Liked 104 Times in 77 Posts
Originally Posted by MontrealCyclist View Post
Hi everyone,
Cheers
Any HT2 cranks you can fit the crank arms fine. Just have them the same length and it'll work fine. I haven't tried to mix 9sp with 11sp, but 10sp with 11sp rings works absolutely fine.
Viich is offline
Old 09-19-21, 04:01 PM
blamester
Blamester
Bikes: Peugeot teamline
Quoted: 243 Post(s)
Liked 99 Times in 83 Posts
Hi everyone,
Cheers
Just wait till you get the new bike.
blamester is online now
Old 09-20-21, 06:14 PM
icemilkcoffee
icemilkcoffee's Avatar
Quoted: 654 Post(s)
Liked 502 Times in 306 Posts
That left side crank arm should be compatible with any Shimano Hollowtech II road cranks. So you can run a 105 5600 or 105 5700 crankset. These are 10 speed cranksets and they should work fine with your 9 speed drivetrain.
icemilkcoffee is offline
Old 09-20-21, 06:25 PM
caloso
caloso's Avatar
Quoted: 2865 Post(s)
Liked 2,843 Times in 1,310 Posts
I have a 105 left side powermeter crank and it works perfectly with my first gen DA 7800 crankset, which works perfectly with 9 and 10 speed. I wouldn't even bother changing the chainrings.
caloso is offline
Old 09-21-21, 07:07 PM
MontrealCyclist
Thx everyone for the advices ! I decided to return the power meter (luckily I can) and instead invest in a pedal based power meter so that I save myself any hassle.
