Suspension seatpost
Suspension seatpost
Quick question about suspension seatposts on tandems... bc i see them a lot. Is it standard on tandems? Maybe i am missing something, but it seems like it is not needed on a road tandem. And it seems to add unnecessary weight. I have never ridden as a stoker, so I am assuming it is rough back there and needed, maybe?
Keep in mind, I am new to tandems... if this is a silly question, forgive me.
Quoted: 383 Post(s)
Liked 245 Times
The rear seat of your Tandem can be a very harsh to the stoker. Even more so than the seat on a single. There are more road specific suspension seats on the market.
Likes For Rick:
Not a silly question. The primary reasons cited for a suspension seatpost for the stoker are 1) the fact that the stoker can’t see a bump coming and so is unable to prepare instinctively as would the captain or rider of a single bike. And 2) that the stoker saddle is positioned very close to directly above the rear axle and so will feel the full force of any bump encountered by the rear wheel, whereas the captain is roughly equidistant between the wheels and thus experiences roughly half the bump force encountered by either wheel.
Reason #1 can and should be mitigated by a diligent captain announcing bumps just before hitting them, but no captain is perfect in this regard, so many stokers, including mine, value the extra comfort gained by a suspension seatpost. Of the available designs, the parallelogram approach is usually more supple with less stiction, although telescopic designs can be useful in situations where there is not much exposed seatpost room available. Some designs also are more prone to activation from pedaling motion than others, and so may suffer some relative inefficiency. You will find some strong opinions on the internet about which particular seatpost is "the best" for stokers, although interestingly almost all of these endorsements are made by captains, not stokers.
Likes For reburns:
Quoted: 411 Post(s)
Liked 505 Times
even small bumps can be a pain. my wife has a kineck post and it helps a lot. iahve to remove it the nI pull the granddaughters trailer and she sure feels it then. Now I tired mine that was all setup for my commuter on the tandem with the same seat and I was bouncing around like a pogo stick.
Likes For fooferdoggie:
Bikes: Indeed!
Quoted: 1138 Post(s)
Liked 1,796 Times
Here are two previous discussions of the same topic that you may find useful:
https://www.bikeforums.net/tandem-cy...endations.html
https://www.bikeforums.net/tandem-cy...hat-works.html
Brent
Brent
Likes For obrentharris:
Try it as is with your stoker and then decide. My one stoker uses the kinekt and it was the best thing we could have done to improve ride quality (hence: distance). The other stoker uses a fixed seat post on the same tandem and is perfectly happy.
Disco Infiltrator
Quoted: 2680 Post(s)
Liked 1,490 Times
Ever ride in the back of the school bus?
Genesis 49:16-17
Genesis 49:16-17
meh
Bikes: 21 CoMotion Java; 21 Bianchi Infinito; 17 Breezer Radar Pro; 15 Surly Pugsley; 13 Felt Z85; 11 Globe Daily; 09 Kona Dew Drop; 96 Mondonico
Quoted: 1046 Post(s)
Liked 857 Times
Bikes: 2000 Santana Sovereign SE; 2005 Co-Motion Speedster; Kona Kilauea with various dorky commuter accouterments; Mercier Kilo TT fixie; Burley Fladbed trailer for groceries, bags of cement and the like.
Quoted: 64 Post(s)
Liked 56 Times
Our Santana and Co-Mo, bought used, both came with rear Tamer posts, and my stoker won't ride without them. The Tamer is less bouncy,I think, than some, because it acts more like a shock absorber: It's firm--almost locked at the top of its range--until you hit a certain threshold of bump, then it kind of "breaks," for lack of a better word, and goes into spring mode, then goes back up to firm when the bumping is done.
One seems to be wearing out, though, and I'm tempted to buy a Kinekt for stoker.
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 144 Post(s)
Liked 73 Times
Our stoker started with a suspension seatpost. After a while she decided is was not useful. I am careful to call out bumps. After a couple 100K miles and we are much older now, it is still that way. Perhaps for some it is ok.
