Replacing my rear wheel freehub
All I'm new to this forum and very new to work on my own 2016 Felt z5. I've been riding this bike now, (weekend rider) for the past 4 years and one thing I noticed was that - when I coast, my rear wheel hub is much quieter than other bikes. I wanted to get a louder noise. I watched some youtube videos and did some reading and found out that some people pull the hub out and clean up the grease with WD40 and the sound goes louder. However, I also learned that - that is really bad. I want to replace my rear wheel hub, with a louder one. I am not sure how to buy one that will fit on my bike. What I have now is Felt R3, sealed cartridge bearing, 32H, 11-speed. Can I just purchase the inside part of the hub or I must replace the whole thing where the spokes connect to the 32 holes. I'm lost - help.
Really Old Senior Member
I smell a troll.
Ignore List!
Ignore List!
Not sure why you got such a cold response. People on here are usually quite helpful.
The lack of useful responses may be because not many members probably have knowledge of your specific hub, me included. With a freehub that is OEM labeled, we often have limited information of what it really is and who made it. Some companies also may use different suppliers for different years. Freehubs also has many different ways that they work and how the freehub body attaches to the hub shell (the part where the spokes attach). Unless someone is really familiar with your specific rear hub, it is impossible to make a recommendation of a replacement freehub body only.
As for rebuilding the rim onto another hub, if the wheel uses standard J bend spokes, a standard hub from a parts supplier (Shimano, SRAM) can be used. Have your local bike shop check your wheel and make a recommendation of your best options.
Likes For KCT1986:
Hi KCT1986,
Hey thanks much for replying back to me. After i actually posted this - I did call the local bike shop where I got my bike from. The owner of the shop actually recommended that I better - or easier for me to get a set of new wheels - starting at around $650.00 and up - rather than rebuilding the free hub. I was hoping to not spend that kind of money. Seems to me that, there should be a way to just replace the hub. Apparently parts are very hard to find these days according to him, and I do believe that somewhat, but..... I will be taking my bike to another maybe local shop to get looked at based on your recommendation - as I am very new to this. Again - I really appreciate your help. The Bill guy really caught me off guard - I was actually trying to upload a pic of my bike to prove I was real and not trolling - but since I'm very new to this forum - I was unable to -
Quoted: 1323 Post(s)
Liked 848 Times
This can be done, but the process is time consuming. First, you have to find a replacement hub whose flanges are the same diameter and have the same number of holes as your current hub. Next, you have to completely disassemble your wheel into its component parts taking care not to mix up the drive side and non drive side spokes. After that you rebuild the wheel using your new hub. I have done this myself, but most shops would not consider reusing spokes so they would want to sell you new ones. The cost of the hub, spokes and labour might be more than you are willing to spend. I would urge you to live with your current setup, sometimes hubs become louder over time. You may at some time wish to upgrade to better and louder wheels. Having spare wheels can be useful if you have unexpected last minute flats or other problems just before a ride
Freehubs are specific to the brand of hub you have and a replacement will be the same as yours, you can't just use any old freehub
Likes For alcjphil:
Freehubs aren't interchangeable between brands. Replacing the hub requires a new hub (high end hubs range from about $120-$600), and will probably require new spokes. Basically you're only saving on the rim, which isn't even the most expensive component, and it's over an hour of skilled labor. A prebuilt wheel is in fact probably the most economical solution. I think part of your cold response is that a lot of people would find your fixation on the noise of your hub a little silly and showoffish.
I'd recommend you first have a shop look at your hubs to see if they have a serviceable freehub mechanism. If so, they might be able to make it a little louder by changing the type and quantity of lubricant, although straying far from the intended lubricant can cause problems.
SE Wis
Quoted: 2055 Post(s)
Liked 1,999 Times
Personally I don't get the whole freehub/freewheel too loud or too quiet thing. So much other noise on the road I never pay attention to it.
Old Bill has a ignore list a mile long, so don't sweat that, maybe even wear it as a badge of honor that you accomplished it on your first day.
cycles per second
Bikes: Early 1980's Ishiwata 022 steel sport/touring, 1986 Vitus 979, 1988 DiamondBack Apex, 1997 Softride PowerWing 700, 2001 Trek OCLV 110
Quoted: 44 Post(s)
Liked 70 Times
Replacing the entire rear hub is one possibility but it seems like a lot of hassle to get a louder freehub. You may be able to replace just the freehub. What brand/model of hub is it? You would need a freehub compatible with that. Most of my cassette hubs are Shimano and I've swapped between different Shimano models, but I've never investigated whether other brands would work. I have a pair of Nimble Crosswinds and that freehub is really, really loud (too loud for me), but I don't know if it would fit a Shimano hub, or if I could put a Shimano freehub on it.
Likes For Gonzo Bob:
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata drop bar conv(Poprad), '79 AcerMex Windsor Carrera Professional(purchased new), '88 GT Tequesta(purchased new), '01 Bianchi Grizzly, 1993 Trek 970 drop bar conv
Quoted: 546 Post(s)
Liked 471 Times
Obnoxious sounding hubs certainly are the trendy thing to do..one does want to be be trendy, that's for sure. You'll need to some sufficiently flashy "kit" next and then maybe break new ground by converting your crankset to 1x.
When we wanted noise as a kid we used a clothes pin and a playing card in the spokes. It was awesome. Maybe someone is selling a pricey carbon version of this setup? Other trendy hipsters would be so jealous.
Likes For fishboat:
Quoted: 586 Post(s)
Liked 511 Times
Hi KCT1986,
Likes For Crankycrank:
Victimless Criminal
Quoted: 952 Post(s)
Liked 2,217 Times
Likes For Rolla:
Maybe you should swap wheels with the OP of this thread;
https://www.bikeforums.net/bicycle-m...reduction.html
Likes For gearbasher:
Bikes: 2017 Surly Cross-Check. 2020 Specialized Turbo Vado 3.0, 2002 GT Dyno Roadster, 2002 Rans Stratus, 2020 Giant Fathom 2, 2011 Trek Pure Sport
Quoted: 170 Post(s)
Liked 83 Times
I want a free hub that sounds like a motorcycle. A V-twin sound, How do I go about this? Will some expensive Harley part bolt on?
Method to My Madness
Bikes: Cannondale Synapse, Trek FX 2
Quoted: 722 Post(s)
Liked 450 Times
For sure the cheapest way is to get a Bluetooth speaker to playback a loud freehub recording.
Hi KCT1986,
Hopefully your local shop has seen this specific hub before or will recognize its origin.
And yes, Bill is one of a few posters here that seems to post on many threads, some times with good info, but many times with bad info and poor biased opinions. These few guys seem to have a "know it all" attitude and hate to be corrected. When proven wrong or their opinion debunked, they stubbornly refuse to admit defeat.
Welcome aboard.
Quoted: 1203 Post(s)
Liked 1,166 Times
@Sam2021 - How about a picture of the hub with the name showing, both from the drive and non drive side.
Likes For SJX426:
Well it looks like you're getting some responses from other members, some slightly useful and others... Unfortunately, unless someone has opened up a hub exactly like yours, its hard for anyone to know what's compatible.
Welcome aboard.
Welcome aboard.
I guess that's why I don't have any LIKES?
Join the list with the other's that can't back up their mouth.
Quite being so combative. We are trying to be informative here, and provide accurate & useful assistance to each other.
I've learned a lot about bikes on here and I'm sure other have as well.
All - I thank you soooo much. Amazing amount of support and information. Bill maybe lacks some attention/love in his life. That is ok - there are tons of amazing people on this forum to give you some of that - all you'll need to do is just be real, go meditate or see some doc. I also love the humor from installing Bluetooth device to make loud sound to attaching playing cards to wheel. I'm actually enjoying reading all. Most importantly though thank you to all who took their time and responded to my question - supported me and didn't brush off my question.
