Are people changing their chains way too often?
Old 10-07-21, 11:35 AM
CoogansBluff
Quoted: 136 Post(s)
Liked 40 Times in 22 Posts
Got a road bike about 3-3 1/2 years ago. Was told that first year to replace the chain every 2,000-3,000 miles, something like that. And that if I didn't, it would wear out the sprocket, crank. And since chain is the least expensive, better to sacrifice a decent chain for the long-term good of the more expensive stuff that an older chain will ruin. OK, so started doing that.
Then, sometimes with a new chain, it would skip a little, and so some folks on here who work in bike shops say whenever you buy a new chain, buy a new sprocket too. I didn't follow that advice. Found that the new chain would slowly take the shape of the old sprocket, or for whatever reason, it would start working better.
Now, I can't get a new sprocket because of global supply issues. Was told by bike shop just to stay with old chain and sprocket as long as I could hold out. Now, whole drive chain is working as well as ever. Except for the chain coming off every 10 rides or so, everything seems fine. No skipping, no problems. I don't know how many miles I'm into this chain, but it's probably 6,000.
And finally, I've had a hybrid bike for probably 8 years now. I've never gotten a new chain. I don't know how many miles it has on it. Not as much as my road bike because the old hybrid is in semi-retirement.
So why should I buy so many new chains?
CoogansBluff is offline
Old 10-07-21, 11:44 AM
Koyote
Quoted: 4920 Post(s)
Liked 7,095 Times in 3,073 Posts
You answered the question in your first paragraph.
Koyote is offline
Old 10-07-21, 11:55 AM
Racing Dan
Racing Dan's Avatar
Quoted: 1191 Post(s)
Liked 247 Times in 164 Posts
There is no One right solution, but, the longer you wait, the more likely "new chain skip" is. I betting it is true a worn chain wears more on the cogs. Reason being a worn chain develops uneven distance between the rollers, gradually shifting the load to only half the rollers/teeth.
Racing Dan is offline
Likes For Racing Dan:
Old 10-07-21, 12:19 PM
c_m_shooter
c_m_shooter's Avatar
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 156 Post(s)
Liked 204 Times in 146 Posts
Once there is any measurable wear they need to be changed as a set, just run them til gone. Chains are cheap unless you have a new high end bike, I find a $10-$20 dollar chain once a year makes the rest of the driveline last indefinately.
c_m_shooter is offline
Likes For c_m_shooter:
Old 10-07-21, 12:21 PM
shelbyfv
shelbyfv's Avatar
Quoted: 2970 Post(s)
Liked 3,754 Times in 1,931 Posts
OP, this isn't complicated but you got some incomplete info as to when the chain should be replaced. Change it based on actual wear, rather than mileage or age. You will have to measure it, either with a ruler or a chain checker gadget. Both have their proponents, Google it. Change your cassette when a new chain skips or otherwise acts up. Most people get two or three chains per cassette.
shelbyfv is offline
Old 10-07-21, 12:24 PM
pdlamb
Quoted: 1842 Post(s)
Liked 1,097 Times in 696 Posts
When you've worn the chain and the sprockets down to the point you have to replace the chainrings...
Well, when I did that, I really wished I'd replaced the chain sooner!
pdlamb is offline
Old 10-07-21, 01:06 PM
Barry2
LR÷P=HR
Bikes: 79 Holdsworth Special, 93 C-dale MT3000 Tandem, 96 C-dale F700CAD3, 2018 Cervelo R3, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 493 Post(s)
Liked 521 Times in 326 Posts
I'm betting more chains are cleaned too infrequently, than are changed too soon.
Barry
Barry2 is offline
Old 10-07-21, 01:13 PM
Iride01
MotuekaCascadeChinook
Iride01's Avatar
Bikes: '20 Tarmac Disc Comp '78 Raleigh Competition GS
Quoted: 4184 Post(s)
Liked 2,708 Times in 1,887 Posts
Measure your chain for wear and you'll know. When I first started coming here a dozen years or so ago, I didn't understand all the chain wearing out controversy I saw in the threads. But I was riding stuff from antiquity and maybe the old beefier chains for a five and six speed rear just lasted forever. Or at least as long as I ever kept any one bike.
Once I got into somewhat more modern times by putting the latest and greatest edition of 105 5800 on my '91 Paramount, I found that my chain wore out in only 5000 miles. So now I'm anxiously awaiting to see if the chain on my Tarmac does the same. But so far at 4K it isn't showing any wear yet. Maybe I baby this one and lube it more or something.
You do know how to check your chain for wear don't you? Either with a metal scale or tape or a chain checker tool.
Iride01 is online now
Likes For Iride01:
Old 10-07-21, 03:48 PM
smashndash
Quoted: 845 Post(s)
Liked 336 Times in 241 Posts
Barry
I'll also add that many people are using unnecessarily sticky lubes for their bikes. I initially used basic Finish Line Dry Teflon tube and that gunked up like crazy. Probably also because I never wiped down after lubing. I also literally never cleaned my chain. Mechanic said my chain was gone after 1800 miles.
I've since switched to MSW and chains basically last indefinitely. I've got a CC-4 to confirm. https://zerofrictioncycling.com.au/wax-instructions/ ZFC says 10,000 to 40,000km is the expected range. That's upto 24,000 miles. Twice as many as I've ridden on this bike, ever.
The muc-off oil I use for my outdoor commuter in rainy wisconsin is also super sticky - great for storing in the rain. horrible for a "nice" bike.
smashndash is offline
Likes For smashndash:
Old 10-07-21, 03:55 PM
msu2001la
msu2001la's Avatar
Quoted: 905 Post(s)
Liked 877 Times in 504 Posts
A Park Tools CC-4 is a $15 solution to this question.
msu2001la is offline
Likes For msu2001la:
Old 10-07-21, 07:16 PM
wolfchild
wolfchild's Avatar
Quoted: 2741 Post(s)
Liked 1,520 Times in 740 Posts
Chain wear depends on your riding style and the weather condition that you're riding in.
wolfchild is offline
Old 10-07-21, 07:40 PM
Random11
Quoted: 168 Post(s)
Liked 213 Times in 115 Posts
The OP raises a good question. I replace my chain when my chain gauge shows it's worn, and about every third chain, the new chain skips so I get a new cassette to go with the new chain. But... if the old chain worked fine with the old cassette, why replace the cassette? Just keep using the old chain with the old cassette. The only reason I can envision is that the worn chain is also causing wear on the chainrings. Replace the chain to preserve the chainrings. But I've never replaced a chainring and don't know how much wear an old chain puts on chainrings compared to a new chain. I'm sure someone here can answer that.
If the old cassette worked fine with the old chain, but skips with the new chain, why not just keep using the old chain and the old cassette?
Random11 is offline
Likes For Random11:
Old 10-07-21, 07:47 PM
msalvetti
Bikes: 2021 Trek FX Sport 4, ~1996 Mongoose Crossway 4.50
Quoted: 50 Post(s)
Liked 364 Times in 108 Posts
I got one of these last month. My bike is 20+ years old, but there were years I never rode it and I can't even guess how many miles are on it. This year I'm over 1,000 miles and I was sure the chain was probably worn after all this time. Nope, not even 0.5%.
Mark
msalvetti is offline
Old 10-07-21, 07:59 PM
GlennR
On Your Left
GlennR's Avatar
Quoted: 3000 Post(s)
Liked 2,421 Times in 1,183 Posts
I have the $10 version, works like a charm. I get around 3000 miles before the .5 drops in.
GlennR is offline
Likes For GlennR:
Old 10-07-21, 10:31 PM
atnyc
Quoted: 56 Post(s)
Liked 25 Times in 17 Posts
How do you determine when you "have to" replace the chainring?
atnyc is offline
Old 10-07-21, 10:34 PM
smashndash
Quoted: 845 Post(s)
Running a chain past 0.5-0.75% increases the risk of snapping a chain. Not a huge deal if you're a small person putting out small watts. But if you value your safety, it's worth it.
Old 10-07-21, 10:47 PM
Eric S.
Eric S.'s Avatar
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 97 Post(s)
Liked 44 Times in 34 Posts
It has been my perception that the more expensive drivetrain components have become, the more often the recommendation to replace them. I rode an Ultegra 8sp cassette from 1992 to 2010 - replaced it when a new chain absolutely would not run on it.
Eric S. is offline
Old 10-07-21, 10:53 PM
Rolla
Victimless Criminal
Rolla's Avatar
Quoted: 952 Post(s)
Liked 2,215 Times in 1,001 Posts
Based on my shop experience, I would say that most people have never even heard of replacing their chain.
Rolla is offline
Likes For Rolla:
Old 10-08-21, 01:59 AM
Lazyass
Quoted: 2425 Post(s)
Liked 609 Times in 379 Posts
I go by sound. I slowly spin the cranks backwards and listen closely to the sound when the chain links contact the cog teeth. Obviously the chain needs to be clean and lubed and the tune needs to be perfect. If it's quiet and smooth the chain is good and if it's noisy, which it will be if it's worn out, the chain gets replaced. About 3500 miles for me. Cassette gets replaced every other chain unless I break a tooth.
Lazyass is offline
Old 10-08-21, 02:53 AM
GhostRider62
Quoted: 1303 Post(s)
Liked 1,119 Times in 683 Posts
When the " Except for the chain coming off every 10 rides or so" becomes every 5 rides or you get taken by ambulance to the trauma center, whichever comes first.
Chains skipping or coming off is bad and not safe.
If you properly maintain your drivetrain, unlike the OP, you can get 10,000 miles out of a chain, over 30,000 miles from a cassette and over 60,000 miles from a chainring.
When your chainring teeth look like shark's teeth, they are very worn.
GhostRider62 is offline
Likes For GhostRider62:
Old 10-08-21, 04:34 AM
wolfchild
wolfchild's Avatar
I don't clean my chains or follow any complex chain maintenance procedures. It's a waste of time to remove and clean a chain. One ride on salt covered roads is all it takes to mess up a freshly cleaned chain. All I do is lube it with some WD 40 or motor oil. and replace my chain after every winter.
Likes For wolfchild:
Old 10-08-21, 05:33 AM
GhostRider62
I usually replace my chain after winter too. Proper maintenance is hard then. The wear is significantly higher in salty and sandy conditions.
Old 10-08-21, 05:37 AM
shelbyfv
shelbyfv's Avatar
Some folks do this, replace both at the same time. You might get half again the life before the wear impacts the function. When chains were $15 and cassettes $40, maybe there wasn't a huge difference in the economics. With current prices, it's hard to swallow a $90 cassette that often. I don't know at what point a worn chain begins to damage the chainrings.
shelbyfv is offline
Old 10-08-21, 05:51 AM
Quoted: 15344 Post(s)
Liked 9,123 Times in 4,506 Posts
When I consulted a LBS about replacing the rings on my touring bike a mechanic used the term “shark’s teeth” to describe their condition.
indyfabz is online now
Likes For indyfabz:
Old 10-08-21, 05:55 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4175 Post(s)
Liked 1,170 Times in 767 Posts
Maybe cassettes were this way. One study though finds that, perhaps counterintuitively, that narrower, higher-speed chains are longer lasting than the older ones
Sy Reene is offline
