your "go-to" thermal layer
Quoted: 4497 Post(s)
Liked 2,101 Times
what is your "go-to" thermal layer? not your base & not your top layer. what is your old reliable middle, thermal layer?
mine is a henley styled fleece shirt. have two actually. they're not bulky, provide a real boost in core body temp. protection, wick moisture & are durable. they were not cheap 10 years ago, when I bought them. but they've held up. actually my Dad bought the first one & I got the second as soon as I confirmed how useful it would be
apologies if this is a redundant thread to another recent one I didn't see
Quoted: 417 Post(s)
Liked 510 Times
Likes For fooferdoggie:
Liked 2,101 Times
I am a woodworker and it does not get super cold in my shop but I wear a base layer then a poly/cotton sweatshirt over that then my goretex rain jacket. that did me down a bit below 32 degrees on my ebike as long as I got my heart rate up. then I would just take the jacket off and I am ready to work. my jeans are fine down to about 32. but if I am just a joyride then I use thremal bibs.
Bikes: Cannondale '92 T600 '95 H600 '01 RT1000
Quoted: 60 Post(s)
Liked 45 Times
For 0-60F, I mix and match my base and mid layers, which consist of four polypro shirts: short sleeve, and light-, mid-, heavy-weight long sleeves. Over the top is a hooded double layer wind breaker from 0-30F, and a "cycling specific" lighter, non-hooded wind breaker from 30-60F.
Going below 0F, I have an old freebie (thanks, Microsoft!
) XL cotton t-shirt I throw over the polypro.
The light- and mid-weight shirts were acquired back in '89 for a Cascades backpacking adventure with my brother. I imagine they aren't as heavy as they once were, but they still work. The washing machine is harder on them than my bike rides.
Likes For MNBikeCommuter:
Quoted: 588 Post(s)
Liked 443 Times
If I'm wearing my Gore Phantom jacket with windstopper tech, it's so good at blocking the heat-removing wind that I rarely wear a base layer (from 40 - 55 F). Below that (25 - 40 F) just a thin tight fitting poly base layer. And below that (5 - 25 F), another of the same thin poly base layer, slightly looser, and/or slightly thicker if insulation is needed because I won't be hammering and generating tons of heat.
Likes For Riveting:
Bikes: 2009 Trek 520
Quoted: 124 Post(s)
Liked 91 Times
My shells aren't big enough for a middle layer, though I have a wide scarf I wrap around my stomach. Last year I had the scarf shortened and added velcro so I don't need to knot it anymore. An extra stomach layer makes a huge difference, its the one part of the body that doesn't generate heat.
Likes For gecho:
Liked 2,101 Times
had our local tailor replace the zipper on a modest Lands End fleece vest. so versatile
Quoted: 714 Post(s)
Liked 355 Times
A 260 weight Icebreaker base layer does a good job of keeping me warm. Plus it never stinks! Gotta love merino wool. Expensive as all get out though. Look for sales if you can.
Likes For NoWhammies:
