Tires
Likes For Colorado Kid:
Bikes: Cannondale '92 T600 '95 H600 '01 RT1000
Quoted: 92 Post(s)
Liked 109 Times
I've been running Conti Gatorskins for years/decades. Maybe there's better out there, but they've served me very well for commuting and long rides.
Likes For MNBikeCommuter:
Quoted: 2599 Post(s)
Liked 1,924 Times
Panaracer Pacelas, followed closely by Gatorskins. The Pacela has a better ride, but the Gatorskins wear a bit better IME.
Save the lighter weight tires for summer rides in the country where there's not so much tire-puncturing trash on the roads (usually).
Quoted: 357 Post(s)
Liked 136 Times
I some times take a long way home via one of the many "trails" around here. (Off road.) This is about 20% of the time. Can anyone recommend something that is good and can do double duty for mild off road commutes?
Bikes: 2014 Avanti Circa (Rd Dist), 2020 Giant Toughroad (Rd Tour), 2021 Trek Allant+ 8S (eCommute), 2021 Scott Aspect 940 (Mt HT), 2014 Santa Cruz Superlight 29er (Mt FS), 2022 Scott Spark 960 (Mt FS)
Quoted: 35 Post(s)
Liked 52 Times
I use a WTB Byway in a 700x44 - you can get them in a 700x34 as the narrowest size.
Apart from that, I'd brave the 20% on Conti GatorHardshells in a 700x28 - you're not going to have much area for tread for a fast rolling do it all tire, so go fast!
Been running Panaracer Paselas (not PT version) and GravelKing Slicks for two years now with no issues. I think Gatorskins were mentioned - great tire for puncture protection but too slick for my needs. There's always Schwalbe Marathons too.
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I run Rene Herse but I don’t commute through a city
Quoted: 18350 Post(s)
Liked 4,502 Times
I'm a fan of the Gator Hardshells (25mm). Longer wearing than the Gatorskins.
The Schwalbe Marathon Plus (HS 440) is a HEAVY tire, but should give you decent traction and durability. Available in 25mm and 28mm. Are there stocking issues?
Liked 1,924 Times
More information, please? Are the trails close to flat, and the surfaces packed 1/4" gravel? Or are you climbing 15% grades on pot-holed dirt with deep sand patches at the bottom of the hills?
Quoted: 357 Post(s)
Liked 136 Times
Flat trails in Boulder, what's that? They range from semi hilly to mountainous. The trail bed are dirt to fine gravel. It all depends on which route I use.. I don't need something with full blown knobs but also I don't need slicks. Any ideas?
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
I have an affinity for the Panaracer family of tires: Pasela 700x28C on two bikes, Pacenti Pari-Moto 650x38B on another, Compass/Rene Herse 26"x1.8" Naches Pass on another, and Gravelking 650x48B on the newest addition (wife's new bike.) I also have an idle set of 26"x1-3/8" Col de la Vies that I'm considering putting on my old 3-speed, too..
Paselas were one of the few "supple" tanwall tires commonly available about 10-15 years ago before that style came back, but I'm not a big fan of the deeply-grooved tread. It looks as if designed to prevent hydroplaning, which is unnecessary and leads to cracking in the tread as it wears. Whenever feasible, I use the file-tread versions of Panaracer tires. (The "Fairweather for Traveler" is another option along these lines in 700x28C, but I haven't tried it yet.)
Another downside to this family of tires for commuting is that the tan sidewalls age like milk if you park the bike outside in sunlight all day. The sidewall latex dries up and flakes off, leaving the already-fragile sidewalls vulnerable to abrasion. It's rare that I wear through the tread of one of these tires before a sidewall injury takes it out. I get enough miles for the dollar that I can't complain too much.
We haven't put a lot of miles on the Gravelkings yet, but if I needed a durable file-tread commuter tire with decent rolling resistance and classic-ish looks, I'd look into another set of those.
RUSA #7498
Originally Posted by noglider
Quoted: 2493 Post(s)
Liked 738 Times
Always was a Schwalbe Marathon (not Plus!) guy until we bought a Trek tandem. Bontrager Hardcase clinchers come stock on Trek bikes. After living with Bonties in both 26" x 2" and 700C x 25mm for about 5 years now I don't really want anything else. Thing is all our favorite tires are getting really hard to find! I certainly can't find any Bonties anywhere and even most of the Schwalbe line is 'out of stock'. I don't know about Gatorskins but my luck with Conti tires has not been good The only tires I have ever had to boot were Conti somethings. But I may have to hold my nose and try a set of GS's because they, at least, seem to b somewhat attainable.
Quoted: 1946 Post(s)
Liked 2,004 Times
For occasional trail use tires that are not slick, choose one of the Gravel Kings. I used to commute on 25mm Gatorskins which have the toughest sidewalls but not a nice ride. GS in 28 would likely ride better. Currently commuting 40 mile round trip on 28mm GP4000s pumped to 80 psi each Monday and have enjoyed them. (No gravel on my commute--only glass and other crap.)
Miles to Go
If you intend to carry a significant load on your tours or commutes, I would recommend the Schwalbe Marathon Tour.
Liked 738 Times
Actually, I can't seem to find GatorSkins either. This may not have been the best of times to begin a thread about 'recommendations'. If you can find a tire (two?) in the size you want. Buy it (them).
Quoted: 1364 Post(s)
Liked 1,676 Times
I run 700x28 smoothie street tires with tire liners on my old 12-speed road bike and it makes for nice flat-free commutes. It does pretty well on dirt, but not so much on gravel. Those are the fattest tires that will fit at the recommended inflation. I tried 700x32s but couldn't inflate the front past 65psi. Even then it would rub the fork "crotch" if there was any sort of bump in the road.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4335 Post(s)
Liked 2,977 Times
I was in a pinch last summer and got some Bontrager AW1s. They ride nicer than I thought. My commute is mostly on trails with debris rather than gravel but they've held up pretty well too.
But I'm still going back to Challenge for next time.
Likes For grosey:
OwainGyndwr
Been cycle commuting since 1987. Have tried them all over the years. Even airless. Everything is a compromise. All my touring/utility and commuting bikes have 28 or 32mm Schwalbe Marathon Plus. They all have Mr Tuffy liners in the rear tires as well. Since starting to use SMPs in 2000 I've had 3 flats. 2 of them were pinch flats. The other was the tire liner cut into the tube over time. No punctures in over 20 years of using SMPs.
Quoted: 357 Post(s)
Liked 136 Times
Great infor.! Now that cool weather and Snow is around the corner, please tell me I can hold off on buying Studded tires a little longer. (Or maybe I should ask Santa for a pair?) I like my "new" tires and look forward to buying some of the ones many of the members on this list wrote about. Should I have break down and get Studded tires( After mounting some nice Trek All Condition tires on my bike) what is a good studded tire? (26+2.1 )
Liked 2,563 Times
They were heavy, noisy, and slow, but I don't think you can get around that with studded winter tires! They were well-made, with carbide-tipped studs. I only switched to a different brand/tire because I didn't have clearance for fenders with the Kendas.
OwainGyndwr
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 564 Times
Continental Ride Tour -- available in ETRTO 28-622, in BLK/BLK and BLK/reflex -- https://www.continental-tires.com/bi...tour/ride-tour .
