What do you use for cable rub?
Old 11-15-21, 09:29 AM
jnbrown
jnbrown's Avatar
Quoted: 105 Post(s)
Liked 60 Times in 30 Posts
What do yo use to protect against cable rub on the head tube of steel frames?
There are these clear stickers:
https://www.amazon.com/Lizard-Skins-...1DH219MU&psc=1
I have never been a fan of those. On my carbon bikes I use Jagwire tube tops and they work ok. Still some minor scratching of the paint but not wearing through it.
Another idea I had was to wrap the cable with silicone self fusing tape which I use to finish handlebar taping and works really well. The silicone has a bit of cushion to it.
Thanks
jnbrown is offline
Old 11-15-21, 09:54 AM
Dylansbob
2k miles from the midwest
Dylansbob's Avatar
Quoted: 395 Post(s)
Liked 635 Times in 310 Posts
Not sure it it really helps, when I used to build airbornes they had me slide a piece of heat-shrink tubing (with their logo printed) over the housing at the rub spots. I really doubt it would protect paint, as I was doing this with ti frames; but it does look kinda trick.
Dylansbob is offline
Old 11-15-21, 09:59 AM
panzerwagon
Garage tetris expert
panzerwagon's Avatar
Bikes: Univega Specialissima, Univega Gran Touring
Quoted: 155 Post(s)
Liked 180 Times in 91 Posts
One of my univegas came with a 'clear' silicon tubing placed over the metal Suntour cable sheathing going from the stops to about halfway to the barcons. It had yellowed quite a bit over the past 40 yrs or so.
It's on my list to find a replacement, and I imagine any auto parts store might have something close.
panzerwagon is online now
Old 11-15-21, 12:23 PM
SurferRosa
Señor Member
SurferRosa's Avatar
Quoted: 2286 Post(s)
Liked 2,916 Times in 1,589 Posts
Down tube shifters.
sorry/not sorry. Ok, ok, sorry.
SurferRosa is offline
Likes For SurferRosa:
Old 11-15-21, 12:52 PM
gearbasher
gearbasher's Avatar
Quoted: 294 Post(s)
Liked 252 Times in 154 Posts
I bend a dime with a hose clamp around a piece of pipe. Then I use some 3M double sided tape and stick it to the head tube.
gearbasher is offline
Likes For gearbasher:
Old 11-15-21, 01:38 PM
seypat
Quoted: 2240 Post(s)
Liked 1,295 Times in 847 Posts
O rings/rubber pin retainers on the cable when you install it.
seypat is offline
Old 11-15-21, 01:53 PM
epnnf
epnnf's Avatar
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 219 Post(s)
Liked 62 Times in 43 Posts
You have cable housing that lasts for 40 years???
epnnf is offline
Old 11-15-21, 02:04 PM
panzerwagon
Quoted: 155 Post(s)
Why yes, yes I do. Did I mention I ride 40yr-old bikes? 😂
Friction shifting across 5-7 cogs allows me not to worry about replacing sheathing very often. Lately, I’ve been installing full-length Jagwire teflon liners under original metal sheathing. Works great!
Old 11-15-21, 02:05 PM
icemilkcoffee
icemilkcoffee's Avatar
Quoted: 653 Post(s)
Liked 491 Times in 299 Posts
Are you talking about brifters with external cables? You can cut the cables short enough that they do not touch the head tube in the straight ahead position (where you spend 99% of your time). I tie the right side shift cable to the front brake cable with a zip tie as well to hold it away from the head tube.
For brifters with hidden cables, I have seen people route the shift cable in front of the head tube, and then come back to the opposite side cable stop. In other words, the two shift cables cross each other just behind the head tube, and then go to their respective cable stops.
icemilkcoffee is offline
Old 11-15-21, 02:10 PM
Dfrost
Dfrost's Avatar
Quoted: 454 Post(s)
Liked 317 Times in 195 Posts
On steel frames with brazed-on shifter posts and under-BB cable guides, I run the shift cables to the opposite side housing stop, then cross the bare cables under the down tube. Voila! No head tube rub! (That bare spot just visible in this photo behind the brake barrel adjuster is from the prior owner. This frame is fully chromed under the paint, so no rust worries!) No, there’s no apparent friction or wear because of the crossed cables and shifting is excellent. I do, however, put some clear tape on the DT underside where the cables intersect so that cable slap on bumpy roads doesn’t mar the frame paint.
With over-BB cable guides, the crossed cable trick doesn’t work, but the Jagwire higher end housing set in 2013 had these ribbed rubber barrels that are a snug fit, so don’t slip on the housing. They’re apparent in the photo below on each side of the lower lug, and have stayed in place for 8 years so far.
More recent 4mm shift housing doesn’t work as well with those. Later Jagwire housing sets have had a short rubber hose thingy that I was able stretch over the housing and work into position. Believe I actually cut the thingy into two shorter pieces. (sorry, no photos)
Heat-shrink tubing could also be used on the housing, but there might still be some marring. Decades ago on my Klein, where the DT was too big to accommodate the crossed table trick, I made ovals of helicopter tape or clear CS protector tape and affixed them to the sides of the HT where the housings touched.
Dfrost is offline
Old 11-15-21, 02:28 PM
Classtime
Classtime's Avatar
Quoted: 1261 Post(s)
Liked 729 Times in 462 Posts
3M makes some stuff. I've heard it called helicopter tape. Auto parts places may have it as its used by some to protect the front of their cars. Goes on clear and comes off clean without harming the paint.
I got a 2x3 foot sheet that works well. Maybe the rolls of tape work too.
Classtime is offline
Old 11-15-21, 03:42 PM
repechage
Quoted: 2329 Post(s)
Liked 1,249 Times in 940 Posts
back then it was vinyl tubing, and yes, yellowed
repechage is offline
Old 11-15-21, 03:44 PM
repechage
also called Starshield, or similar products.
auto tint purveyors often take on that work as well- orts from their work would be good.
Old 11-15-21, 04:13 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2917 Post(s)
Liked 1,857 Times in 1,127 Posts
So do I. Stainless SunTour BarCon housing and "Ultraglide" (one of the original lined housings) from the late 70s. Still holding up fine.
JohnDThompson is offline
Likes For JohnDThompson:
Old 11-17-21, 09:07 AM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 7740 Post(s)
Liked 4,723 Times in 2,727 Posts
I have the clear patches on a couple bikes- they work fine. I actually have the patches and some spiral rubber protectors on two of my bikes. The spiral rubber stays in place for a few months and I move it back into place when I happen to see it dropped. Really, this only happens on my gravel bike and I assume its due to vibration.
One of my road bikes has crossed cables, as mentioned earlier in this thread. It keeps the cables off the frame without any protectors and shifts fine. Its on a 2x11 drivetrain and there is no issue.
These are the spiral protectors.
I have used these and they are on a couple of family bikes right now- they work fine. Jagwire, SRAM, and generic Amazon/Ebay brands sell em.
mstateglfr is offline
Likes For mstateglfr:
Old 11-17-21, 09:38 AM
jnbrown
jnbrown's Avatar
Quoted: 105 Post(s)
The problem I have had with those Jagwire ones is that they do not stay in place. Seems like the spiral ones would be better for that.
Also found these but not sure if they stay in place better:
jnbrown is offline
Old 11-17-21, 10:31 AM
BoltBreaker
This wrench fits...
BoltBreaker's Avatar
Bikes: Two Rivs, and a bespoke Gugie
Quoted: 30 Post(s)
Liked 75 Times in 19 Posts
I just accept the worn paint as part of my bike's natural use and aging process. These aren't garage queens...
BoltBreaker is offline
Likes For BoltBreaker:
