road shifters on MTB compatibility
Hi, I want to make a cheap gravel bike, and I have found a mountain bike frame, but with thicker road wheels, which features a 21 speed Shimano gearing system, and twist shifters. I already have an old road bike which also features a 21 speed Shimano gearing system, albeit with brifters. My thinking is take the drop bars and brifters from my road bike, and put them on the other frame, because they run on the same brand gearing system, and have the same number of gears. Are there any major compatibility issues between the two, or would it be compatible?
Mother Nature's Son
Quoted: 612 Post(s)
Liked 801 Times
I believe the road brifters have a different cable pull and will not operate the mountain bike brakes properly. I think the road has short pull for brakes and the mountain has long pull.
Quoted: 1523 Post(s)
Liked 1,474 Times
If your mtb has linear/v brakes, the brakes are not compatible, as noted above.
There is also a compatibility issue with the mtb FD and the left (front) STI shifter.
John
Edit added: Your work around for the brakes is a travel agent. You “might” be able to run a road FD on the mtb, but chainring diameter (teeth) and chainline might be an issue.
John
Quoted: 2970 Post(s)
Liked 3,752 Times
Your 7 speed brifters will operate your 7 speed mtb RD and will work with your canti brakes. They may or may not work satisfactorily with your mtb FD. If they don't, a bar end or downtube friction shifter might be an option. I would suggest you try riding your "gravel" with the mtb as is. Pursue the drop bar conversion only if your rides become long enough that the flat bar/single hand position becomes a problem.
Dirty Heathen
Bikes: 1997 Cannondale, 1976 Bridgestone, 1998 Softride
Quoted: 650 Post(s)
Liked 476 Times
Old or low-end Shimano 3x7? 'Ought to work' I've found 7-speed is pretty much the last bastion of mix-n-match, especially early 90's stuff.
Not always, but often enough to make it worth the try.
I'm always wary of taking apart a complete, operating bike to get some of the parts for another bike. (unless you got it specifically for a parts donor) Especially if you don't really know what youre doing. The OP may end up with a satisfactory drop-bar MTB, and a flat-bar road bike, or he could end up with a cobbled-up 'gravel grinder' that doesn't quite work, and a pile of parts that won't quite make a complete bike.
Likes For Ironfish653:
SE Wis
Quoted: 2049 Post(s)
Liked 1,990 Times
shimano mountain/road front derailleur issue see #7
Shiftmate Compatibility Charts and Choices - Jtek Engineering
I would be inclined to agree, however the road bike would need a lot of improvements to be regarded as fully operating. My thinking is that I can either spend the money fixing up the road bike that im not particularly attached too, or try and build something im more interested in! (the price of fixing it up would be roughly the same as attempting the gravel build)
At the end of the day, im just excited at the prospect of doing it myself, no matter the outcome, and either way, ill have learnt something! To me personally, the build is worth a try, and if it goes well that'll be fantastic, and if it doesn't, thats on me, but this thread and your comment have been really helpful, thank you!
Likes For theow:
Senior Moment
Bikes: 2014 Surly LHT, 2003 Giant NRS 3, 1991 Trek 700, 2006 Cannondale Six 13 Team, 1985 Miyata 210
Check out RJ The Bike Guy on YouTube. He has tons of videos on how to do the kinds of things you’re asking about. Lots of good instruction there.
Likes For grinningfool:
dingus
I say give it a whirl! You'll know pretty quickly what works and what doesn't. You may need to find a short-ish stem since the reach of those drop bars could make you stretch way out compared to the mtb bars you've got on there.
Likes For SpedFast:
SE Wis
Liked 1,990 Times
Dirty Heathen
Quoted: 650 Post(s)
Liked 476 Times
theow Sounds like you've got a "six of one, half-dozen of the other" situation, so nothing much to loose for trying. Best of luck with your build!
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), 90's Giant Innova (now with drop bars), FMF Race BMX, Redline Proline Pro24 Cruiser
Quoted: 290 Post(s)
Liked 103 Times
I swapped to drop bars for my winter bike - used an early 90's bike with cantilever brakes, drop bar, bar end shifters. 7 speed stuff is mostly compatible - you might have to swap front derailleurs (but you might not)
Bar end shifters are a good way to do this, friction front shifting almost always works. If you really want integrated, I'd go with something like this from Amazon over taking apart your road bike. Drop bars can be had cheap too.
Mad bike riding scientist
Quoted: 4793 Post(s)
Liked 2,347 Times
The only real incompatibility is the front derailer. Mountain and road front derailers have close enough pull ratio that they almost work but not really. A front derailer will work but you may need to move the crank inboard to get enough reach.
Stuart Black
Stuart Black
Just Pedaling
Quoted: 89 Post(s)
Liked 129 Times
Does anyone know if those Micronew 2X7 brifters will work on a 6spd freewheel upgrade? Current vintage road bike with indexed/friction stem shifters.
Liked 1,474 Times
The FD is unknown compatibility. If it is friction now, it might not work. There are work arounds with cable tension to get it to work. Basically with a 2x, if the shifter can pull enough cable it can be made to work.
John
Likes For 70sSanO:
Hack
Quoted: 290 Post(s)
Liked 103 Times
Likes For Viich:
Just Pedaling
Quoted: 89 Post(s)
Liked 129 Times
No, but the RD will work with a 7 speed freewheel, shouldn’t be a dropout width issue, if the RD is SIS.
John
John
Likes For icemilkcoffee:
Likes For SpedFast:
Just Pedaling
Quoted: 89 Post(s)
Liked 129 Times
Thanks for the info
Edit=I just found a hub and freehub with an 8spd cassette on it. I'll have to clean it up and see how it looks. Maybe I can upgrade to 8 gears in the rear.
*maximum 2mm per side adjustability.
Just Pedaling
Quoted: 89 Post(s)
Liked 129 Times
Interoperability arguably began with 7sp. 6sp is still its own spacing in some cases. The 7sp may fit, it may not. A new rear hub may be necessary. What exactly is the rear OLD (locknut to locknut) spacing? If 135mm you are good to go with just about anything with that frame. If less you may have the ... annoyance of having to spread the dropouts* each time the wheel is inserted, or cold setting the frame so the frame submits to the upgrade. Swapping between MTB and Road is made deliberately hard to discourage exactly what the o.p. wants to do, and you as well. The reason is $$$. You are either going to pay in cash or in sweat. Pick your poison.
Thanks for that information. I'm going to clean up the 8spd setup in the parts bin and see about building a wheel around it if, and that's a big if, the hub will fit properly in the frame. I don't have a problem cold setting it wider, but not much. At this point the bike is still rideable so there is no push to make it happen. I might just opt to buy another 'used' bike with the brifters already set up on it and donate the old bike. (Wife only lets me have 2 at a time).
Likes For Leisesturm:
