Xt Is this Crank fully seated?
Old 01-16-22, 08:55 PM
AJW2W11E
Quoted: 104 Post(s)
Liked 26 Times in 20 Posts
I was trying to remove this craink on my Giant hybrid with the Park tool and it wouldnt budge. I noticed the bracket cartridge male shaft square key had a gap of 1/8 inch in the crank female square shaft. I checjec th druve side and it was the same way, So I guess thats thd way it is, or is it?
Jusf seems the crank is flush with the bracket on m uhh other bikes.
Funny thjng is I have had this bike 3 years and never noticed this.
uh
AJW2W11E is offline
Old 01-16-22, 09:06 PM
AJW2W11E
Quoted: 104 Post(s)
Here is a better pictute.
AJW2W11E is offline
Old 01-16-22, 09:36 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 3376 Post(s)
Liked 2,026 Times in 1,325 Posts
How far into the crank arm tapered hole does the axle go? What's the torque you used for the retaining bolt? Andy
AndrewRStewart
Andrew R Stewart is offline
Old 01-16-22, 10:03 PM
AJW2W11E
Quoted: 104 Post(s)
Thanks for your help. I will post a picture tomorrow showing what's underneath the edge bolt on both the drive side and non drive side. They actually match!
Insofar as torque is concerned you're talking to a guy who shears automotive bolts. Recognizing I an working on bikes now, I tried a bit hard, but I knew when to stop.
AJW2W11E is offline
Old 01-16-22, 10:15 PM
AJW2W11E
Quoted: 104 Post(s)
I googled my bike -- a Toughroad- and I found a picture showing there is a gap.
AJW2W11E is offline
Likes For AJW2W11E:
Old 01-17-22, 07:25 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2921 Post(s)
Liked 1,873 Times in 1,135 Posts
The important issue isn't how much of the taper is visible, but rather how the arm is seated on the spindle:
File Type: jpg
JohnDThompson is offline
Likes For JohnDThompson:
Old 01-17-22, 08:46 AM
AJW2W11E
Quoted: 104 Post(s)
I am still wondeing.Trouble is I cant even budge it so I can inspect the inside geometry to see if its fully seated. Its on there tight and the Park tool wont budge it.
AJW2W11E is offline
Old 01-17-22, 08:52 AM
HillRider
Quoted: 1821 Post(s)
Liked 760 Times in 553 Posts
Check carefully to be sure there isn't a washer at the bottom of the crank's extractor opening. If there is it will prevent the extractor from working.
HillRider is offline
Old 01-17-22, 05:53 PM
AJW2W11E
Quoted: 104 Post(s)
no there isn"r one, but thats the kind of mistsle i would make
AJW2W11E is offline
Old 01-17-22, 08:11 PM
Andrew R Stewart
The classic trick with a too tight cotterless arm is to leave the retaining bolt a tad loose and go ride the bike. In time the arm will migrate off the axle and the still there bolt will prevent real damage. Andy
AndrewRStewart
