What did I do to my tubeless tire?
Old 01-22-22, 05:54 PM
urbanknight
Over the hill
urbanknight's Avatar
Bikes: Giant Defy, Specialized Allez, Raleigh Pursuit tandem
Quoted: 353 Post(s)
Liked 384 Times in 241 Posts
I recently went tubeless and felt that the valves were getting clogged. Let the air out of the tire to remove the valve core and sealant started leaking out of the sides at various points on the tire. When I went to put air back in the tire, it wouldn't seat/seal. How do I fix this? And how do I avoid it in the future?
It's like riding a bicycle
urbanknight is offline
Old 01-23-22, 05:51 PM
urbanknight
Over the hill
Quoted: 353 Post(s)
No responses in 24 hours? Must have stumped you all. Well, I took it to the shop and they were having a hack of a time seating it as well. It was a very loose tire (stock, 3 years old) so I just had them upgrade with new tires. Still not sure how competent I will be at seating tubeless tires myself.
Old 01-23-22, 06:01 PM
tyrion
tyrion's Avatar
Bikes: Breezer Radar
Quoted: 1985 Post(s)
Liked 1,477 Times in 715 Posts
This technique works for me:
tyrion is offline
Likes For tyrion:
Old 01-24-22, 10:03 AM
KerryIrons
Quoted: 89 Post(s)
Liked 122 Times in 69 Posts
Another testimonial as to why tubeless road tires are a tremendous improvement. Or maybe an explanation why a whole lot of experienced riders are staying with inner tubes.
KerryIrons is offline
Likes For KerryIrons:
Old 01-24-22, 10:12 AM
Troul
:D
Troul's Avatar
Liked 1,586 Times in 1,097 Posts
you might've made it into a tube required tire?
-Oh Hey!
Troul is offline
Old 01-24-22, 10:30 AM
veganbikes
Clark W. Griswold
Quoted: 2796 Post(s)
Liked 1,956 Times in 1,295 Posts
I would clean everything really really well and then dry fit which you should do with any tubeless set up and if it holds air you are good if not you might try a different combination. In your case it sounds like you are using a worn out tire that is too old and stretched to be of use for tubeless.
veganbikes is offline
Likes For veganbikes:
Old 01-24-22, 02:05 PM
urbanknight
Over the hill
Quoted: 353 Post(s)
Yeah I'm not totally sold on tubeless yet.
Likes For urbanknight:
urbanknight
Over the hill
Quoted: 353 Post(s)
Guess so.
Old 01-25-22, 12:21 AM
Leisesturm
Quoted: 1883 Post(s)
Liked 389 Times in 279 Posts
Oh man, I couldn't resist ...
Leisesturm is offline
Likes For Leisesturm:
Old 01-25-22, 11:55 AM
Chilepines
Bikes: 1984 homemade 531SL road bike; 1988 Ritchey TimberComp; 1997 Nashbar tandem; 1998 Kona Explosive; Specialized Epic, Scott CR1 Pro; Salsa Beargrease; Curtlo custom Tandem.
Quoted: 57 Post(s)
Liked 38 Times in 28 Posts
I'll make my usual plug for Skinny Strippers FattyStripper Tubeless Fat Bike Solution and SkinnyStripper Tubeless CX & DH Solution <link rel="image_src" href="https://fattystripper.com/media/FattyStripper_Logo_320.jpg" / ><link rel="image_src" href="https://fattystripper.com/media/FattyStripper_L
These make it easy to seat tubeless tires so that they seal right up.
Chilepines is offline
Likes For Chilepines:
Old 01-25-22, 02:02 PM
Riveting
Quoted: 588 Post(s)
Liked 443 Times in 260 Posts
Tubeless on my 25psi mtb has been flawless for the past 4-5 years. Tires seat easy (using an Airshot pressure canister between the floor pump and tube valve), and the 20-30 small punctures I've had all sealed almost immediately after pulling out the thorns (using Stan's sealant).
But I still see/hear so many road bikes with tubeless issues, either not being able to seat the beads (on the side of the road, without the air canister mentioned above) or not getting the sealant to work on punctures, which is why I still haven't made the switch to tubeless on the road bike. Although I do like the idea of not getting a front flat while going downhill at 40+ mph.
Riveting is offline
Likes For Riveting:
