Show us your Vintage Touring bikes
#2602
Friendship is Magic
Bikes: old ones
Quoted: 26245 Post(s)
Liked 10,229 Times
...I might have posted this one before, but it has some functional updates and a new (used) set of panniers.
For what it is, a pleasant, unassuming, Japanese made Schwinn, with only the three main tubes butted, it's remarkable as a sport tourer.
Likes For 3alarmer:
#2603
Friendship is Magic
Bikes: old ones
Liked 10,229 Times
Likes For 3alarmer:
#2604
Friendship is Magic
Bikes: old ones
Liked 10,229 Times
Likes For 3alarmer:
#2605
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
3alarmer all really nice classy looking bikes is that where all the white fenders have gotten off to? you have a stock pile of'em in your garage? don't lie now....
interesting how that huret FD curvature doesn't match at all with the rings. never been a problem for me, but some claim it makes for poor shifting. i don't imagine you have that problem, either
#2606
Extraordinary Magnitude
Quoted: 2597 Post(s)
Liked 1,678 Times
You're not supposed to spin the granny- the idea is that you throw all your power at it on your power stroke- which is why you're using the granny- "voot voot voot voot" instead of "rrrrrrrrrrrrr."
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
#2607
Friendship is Magic
Bikes: old ones
Liked 10,229 Times
...it pisses me off that SKS stopped making white fenders. When I wanted white fenders for this Follis project, I had to buy some aluminum ones that were anodized black, rough the surface, and paint them myself. Yeah, I cannot explain the cage angle on that Jubilee front mechanism, but it shifts fine that way. I ended up regrinding the flat on the front mechanism for this one, where the cage bolts on, to get a better line for the front cage.
Likes For 3alarmer:
#2608
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
no offense, but that's "better"? what did it look like before? simplex?
i was miffed, too, over the disappearance of the white fenders. nlerner has a build with some on it (though more "off" white) and really wanted some for a light grey schwinn. SOL. i'd rattled can some fenders in the past and never liked the end result, so likely won't try it, again
#2609
Likes For daka:
#2610
Quoted: 195 Post(s)
Liked 206 Times
I have a Biopace triple with 50/45/28 and one that's 48/38/28. I don't notice it on any of the "big" rings unless I'm looking down at them.
Likes For Cycle Tourist:
#2611
Quoted: 535 Post(s)
Liked 344 Times
Ready for an unnecessarily long post? I blame it on the fact that I never put a thread together showing the rebuild of the '76 Limited Touring. So if you're game, here goes...
I shared my Eisentraut to this thread before, but that was a couple of years ago, and it's recently been torn down and rebuilt since then. Quite a different bike really. A bit sportier. Noticably lighter. And more pleasing to my eye. Which all said and done, makes for an extraordinarily fun bike. More so than it was prior to the rebuild.
It's a franken build, but nothing is random, and I guess it's a compilation of little group sets. So there is some notable theme running through the build list.
One of the smartest upgrades this time around are the SR SP-11 pedals. Best fitting, most comfortable pedal for my feet that I've ever found. And they flip on command. I'm using them with Bruce Gordon clips, and couldn't be happier with the pairing. Super easy in and out. Solid. Secure.
The Rene Herse 32c extra light tires have also proved to be a big step up from Gravel Kings for the kind of riding I do. Their suppleness really compliments the frame's ride feel.
Last real noteworthy change was the "step down" from the proverbial Brooks B-17 to a San Marcos Rolls titanium. The weight savings is huge. No comfort lost. I actually like the feel better. And I don't worry about someone stealing off with it as much.
I went with half step plus granny gearing over the previous alpine set up. And I replaced Shimano Deerhead mechs for 1st gen Cyclone. Much snappier and lighter with the Suntour. Went with down tube levers this time in place of the barcons I previously installed. Superbe calipers and levers replaced Modolo units.
I've kept the Nuovo Record hubs and M-40 rims. But the Mavics are running thin along their brake tracks. I have a pair of Wolber Alpines which I'll lace the hubs to eventually.
Bottom bracket is a floating unit from White Industries. Gives me a good chainline but it's not the best design. Still hunting for a better substitute.
Campy Pista head set. 3ttt post, stem, and bars. Jim Blackburn rack in back, and Vetta up front. Jim Blackburn bottle cage, and Honjo fenders. Still need to dial in the perfect fender line and clip the struts at their mounting points, but I'm riding dry, which is good enough for now.
Yep, I think that about does it.
I plan on making a set of custom panniers and a saddle bag this winter in preparation for next spring's adventures.
In the meantime, I've been enjoying it as much as the weather will allow, which is not enough.
Likes For deux jambes:
#2612
Friendship is Magic
Bikes: old ones
Liked 10,229 Times
#2613
Friendship is Magic
Bikes: old ones
Liked 10,229 Times
...that is the "before" photo. Here is "after".
...I had to use two coats of white enamel and a third urethane clear coat, on aluminum, to get something I liked. Curse you SKS !!!
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
3alarmer oh!!! that's infinitely better!! weird how it was so messed up before
i tried painting chromoplast fenders. and, i used a semi gloss for plastics (acrylic?), so that probably has something to do with it. i did not try a clear coat, though. maybe i'll try to salvage them with sanding, a gloss enamel, and then the clear. i even have some some already for some paint repair on my car.
#2615
my 51 year old Claude Butler.I did a rebuild for it's 50th year .I've had this bike since I was 14 years old.Still ride daily,it's like my right hand....Scott
Likes For Ger482:
#2616
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
Likes For DQRider:
#2617
thanks DQRider it was great doing the rebuild, that bike has gone thousands of miles with me.,,,, yes ride for the fun
#2618
German Touring Bicycle Guylaine
Recently I built a "new" bicycle for me.
Bought as an unpainted NOS 1998 frame from a dear friend, got it and the rack slightly modified by Norwid Fahrradbau, than had it powder coated in RAL 1028 melon yellow to have a partner look with my wifes bicycle and finally completed it with new, NOS and used parts, most of them in my drawers for years.
Most special part of this bicycle (apart from its uncommon colour) ist the saddle! In 1997 I had taken that off my Bio-Racer bike after it had spent a night in the sleet, uncovered. It was the night of the 22nd to the 23rd of March 1997, in which I met my wife. Since then the saddle was never used again and spent its hard existence on various shelves.
It is a German „Reiserad“ (touring bicycle), quite popular from 1985 to about 1995. It where 700c bicycles with drop bars, tires from 25 to max. 32mm wide, sturdy rear racks, front lowrider attachments (following Jim Blackburns suggestions), but no front bag support as usual in France and no saddle bag as in UK but of course fully equipped with fenders and dynamo lights as per German traffic regulations, had usually cantilever brakes, often dynamo under die bottom bracket, sometimes with remote control, geometry close to racing bikes, angles often 72-73 degree.
So nothing new under the sun, but the German approach for this topic, being a little late as it started around 1983 becoming popular.
Guylaine was the top brand of such bicycles in that age, offering complete bicycles in a modular concept regarding braze ons and components.
Click on image name to get full size resultion on Flickr.
On my Flickr there also is a complete set of all Guylaine catalog photos ever published.
Guylaine Randonneur by Heiko, auf Flickr
Guylaine Gelb 2 by Heiko, auf Flickr
Guylaine Gelb 4 by Heiko, auf Flickr
Likes For HeikoS69:
#2620
Quoted: 150 Post(s)
Liked 231 Times
Wow, there are a lot of gorgeous bikes in this thread.
I have to go now and get something to clean the drool off my keyboard
#2622
[QUOTE=HeikoS69;22326696]Recently I built a "new" bicycle for me.
It is a German „Reiserad“ (touring bicycle), quite popular from 1985 to about 1995. It where 700c bicycles with drop bars, tires from 25 to max. 32mm wide, sturdy rear racks, front lowrider attachments (following Jim Blackburns suggestions), but no front bag support as usual in France and no saddle bag as in UK but of course fully equipped fenders and light as per German traffic regulations, had usually cantilever brakes, often dynamo under die bottom bracket, sometimes with remote control, geometry close to racing bikes, angles often 72-73 degree.
Hello mein gesperrt friend, that is a fine fine looking bike. I have never heard of the brand name before. Was or is it fairly well known in Germany? It appears to have all the functionality of a nice sport tourer.
#2623
Company was founded 1983, own framebuilding started Summer 1986.
I scanned a complete set of catalogs from their first catalog with selfmade frames 1986 to their last paper-catalog at all 1996/97. Files are uploaded in a German bicycle forum, from post no. 3 onwards, filesize 4-6 mb each, 12 catalogs in total. All catalogphotos are also uploaded in that place in 150 dpi quality and can also be found in 600 dpi "high quality" on Flickr.
Files are posted with permission of the rights owner.
Language is German everywhere.
Catalogues: https://www.rennrad-news.de/forum/th...lfaden.177271/
600 dpi catalog photo scans: https://www.flickr.com/photos/414206...57720074617283
The 1992 catalog is the most beautiful one imho, nice front and rear covers, nice model photos, full geometry data anyway, pdf-file below the following forum post:
https://www.rennrad-news.de/forum/th...1/post-5136252
#2624
Google image search of "Reiserad" produces a whole new world of touring bikes, of which I was completely ignorant.
#2625
2Flit
Location: Orcas Washington and currently Circumnavigating in a Farrier F36 Trimaran
Bikes: 1968 Rene Herse Gentleman's Bike; 1974/5 Jim Merz Custom-built; 1984 Rodriquez tandem; 2012 Bilenky Tandem; 1967 Cinelli SC; 1984 Specialized Exp. 68cm; 1971 Holdsworth 63cm(my first bike ever and owned since new!); 1994 Bridgestone MB5; 86'Trek420
Quoted: 38 Post(s)
Liked 170 Times
Specialized Expedition circa 1984 on a 14 day trip out of Calgary.
14 day trip out of Calgary, shot above Banff on way to Jasper
Departing Calgary
Typical Camp site
Departing Calgary
Typical Camp site
Likes For 2flit:
