Spray Degreasers
Spray Degreasers
Old 12-20-08, 07:07 PM
bcarter6
bcarter6's Avatar
Spray Degreasers
So I went into the bike shop today to pick up some degreaser to clean my girlfriend's bike (I had used the last of my citrus degreaser doing mine the day before). The guy at the shop said that they didn't carry citrus degreaser because it would damage the bike, they only had the spray foam stuff. Rather than go to another store I thought I would try the foam, just spray it on, wait a bit and rinse it off... sounds easy.
However, it was a real PITA compared to citrus degreaser and my parks chain cleaning machine, so I don't think I want to use it much. But I am wondering about what he said about it hurting my bike... he just feeding me a line?
bcarter6 is offline
Old 12-20-08, 07:58 PM
gerv
In the right lane
gerv's Avatar
Bikes: 1974 Huffy 3 speed
Quoted: 43 Post(s)
Liked 6 Times in 5 Posts
I use Simple Green to clean just about everything on a bike. Not sure if it destroys the paint, but I seem to be able to manage that pretty well myself. I figure by simply riding every day, I will destroy a paint job quicker than Simple Green could.
BTW, regular dish detergent has some pretty good degreasing capability. Cheap too.
gerv is offline
Likes For gerv:
Old 12-20-08, 08:40 PM
CCrew
Older than dirt
CCrew's Avatar
Bikes: Too darn many.. latest count is 11
Same here. Key is you have to rinse it well. Simple Green will etch aluminum if it's left on. It also strips wax (as does dish detergent) so if you get it on paint it's adviseable to re-wax it.
WD-40 also functions well as a cleaner.
-Roger
CCrew is offline
Old 12-20-08, 08:50 PM
GV27
Light Makes Right
GV27's Avatar
Bikes: Gianni Motta Criterium, Dean Hardtail
All of them will strip wax. The best cleaner and also the safest is automotive brake cleaner. It's designed to not attack rubber brake hoses, etc. and leaves behind no residue. You don't want to get it into bearings, however. It'll wash the grease right out. They all will, but the more effective as a cleaner it is, the faster it'll take grease out of bearings.
GV27 is offline
Old 12-20-08, 09:30 PM
crhilton
Bikes: '07 Trek 1500, '08 Surly Cross Check, '09 Masi Speciale Sprint custom build
I use the spray citrus stuff. It works. Dish detergent is worthless. I once ran the cleaning machine with dish detergent three times to get murky water. Then I sprayed citrus degreaser on the chain and ran the cleaning machine with water. The water was black when I finished.
I've never heard of this foam stuff. I imagine anything that works will strip paint, eat rubber, and corrode metal.
crhilton is offline
Old 12-20-08, 10:09 PM
Yan
BeaverTerror
Yan's Avatar
Quoted: 382 Post(s)
I use mineral spirits.
Yan
Yan is online now
Old 12-20-08, 10:49 PM
pwdeegan
smitten by саша
pwdeegan's Avatar
Bikes: Salsa La Cruz with Rohloff; mutt parts
i find that Shout, that stuff for removing laundry stains, works really well, smells nice, and leaves my hands feeling silky smooth.
pwdeegan is offline
Old 12-21-08, 01:06 AM
SSSTANG
SSSTANG's Avatar
Originally Posted by yan View Post
i use mineral spirits.
+1
SSSTANG is offline
Old 12-21-08, 09:26 PM
jcm
Gemutlichkeit
+1 mineral spirits, which is exactly what WD-40 is, except it's cheaper by the gallon.
+100 on the spray brake cleaner. Absolutely the best gunk remover there is. Evaporates to completely dry in seconds. Expensive, though. Caution: it also is very tough on your hands, so use gloves.
Simple Green is good, but really should be water rinsed, which might make it inconvenient. Buy it by the gallon and mix up a stronger solution in your sprayer.
jcm is offline
Old 12-22-08, 12:14 AM
Hirohsima
Just cleaned my chain tonight w/ mineral spirits. It dries clean, is not a cleaner so once is dried, if water gets back into the chain, it will not re-activate and turn back into a degreaser like Simple Green can if you don't get it all out by rinsing.
The bike degreasers out there are pretty weak and really just shift the dirt around. I think those chain cleaners are a crock as they don't really remove all that much dirt and the most harmfull stuff (the stuff in the bushings) stays there. With a glass jar of mineral spirits and a chain, you can have a dirt free-chain in < 2 min.
Plus mineral spirits can be reused. Once you clean you chain, if you leave the jar un-touched for a few days all the particulate matter and grime sinks to the bottom. You can pour out the clean fluid into a second jar and re-use it.
Brake Cleaner is toxic but it works. I use it for REALLY old caked on grease , but mineral spirits works from 90% of everything else.
Hirohsima is offline
Old 12-22-08, 10:47 AM
Nightshade
Humvee of bikes =Worksman
Nightshade's Avatar
Quoted: 10 Post(s)
Liked 6 Times in 6 Posts
simple green or Formula 409 will do a great job of de-greasing anything with NO damage
to the item whatsoever. I used both for decades with not one problem with them where I've
had other cleaning product wrinkle and damage the paint badly or stain the plastic.
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Nightshade is offline
Old 12-22-08, 11:31 AM
bikecopXXX
Bikes: steel ones
i used spray degreaser on the whole bike when i started out...i am convinced it stripped the grease out of all my bearings and caused free-hub failures and other issues. if you use it keep it away from bearings/seals. it is thin and can pass right thru seals. now i wash with water only and not that often.
bikecopXXX is offline
Likes For bikecopXXX:
Old 12-22-08, 09:07 PM
jcm
Gemutlichkeit
Very good point. It can definitely wash out your bearings. I limit its use to the chain. However, because it is fairly costly, I keep a couple gallon cans of mineral spirits in the shop and go at it with a couple brushes. Mineral spirits can also wash out the bearings. It is a powerful cleaner/solvent.
Those one-gallon detergent jugs, with the spout pried out make great containers for chain cleaning. Pour in about three cups and drop in your chain. Screw on the top and shake for about three minutes and presto - super clean. I use a second one with a fresher rinse in it to finish off. I found out that a magnet is helpful to retrieve the roller that might come out with the shaking.
I know the chain is clean when I can twist it and not hear the grit in the rollers.
jcm is offline
Old 12-23-08, 10:44 AM
Nightshade
Nightshade's Avatar
Quoted: 10 Post(s)
This is why I prefer a household spray bottle of Formula 409. It can be "targeted" to the dirt and
works so quickly that you wipe it away before the drips get into bearings. I take care around the
derailer/gears then soap & water. (I spray lube them right after I clean that area)
Old 12-23-08, 01:12 PM
bikepeddler
bikepeddler's Avatar
Bikes: Surly Pacer, Trek Hybrid
i find dish detergent very messy. Like some others here I use mineral spirits, but only on cogs and severe messes. It's very good for cleaning a tooth brush or whatever else you may be using. For most applications, I've found the tri-flow citrus degreaser very useful and not too abrasive (apply to rag first).
https://www.triflowlubricants.com/Cit...er/citrus.html
bikepeddler is offline
Old 12-23-08, 01:14 PM
ItsJustMe
Seńior Member
ItsJustMe's Avatar
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times in 7 Posts
I've never found dish detergent to do a darn thing about really bad grease. Honestly, nothing short of a fairly powerful, nicely flammable solvent really works. Mineral spirits or kerosene.
I don't clean my bike much though. I don't even really clean my chain anymore; I tried it and it doesn't improve its lifetime at all, so now I just lube and wipe down.
Work: the 8 hours that separates bike rides.
ItsJustMe is offline
Old 12-23-08, 01:27 PM
bikepeddler
Chain Cleaner
Rock and Roll is the best lube all in one cleaner I've found so far.
https://www.rocklube.com/
Old 12-23-08, 01:42 PM
CastIron
Sensible shoes.
CastIron's Avatar
Bikes: A few.
My degreaser: One gallon can of WD-40 and a 99 cent spray bottle in lieu of a parts washer (which is better than anything).
Mike
Originally Posted by cedricbosch View Post
It looks silly when you have quotes from other forum members in your signature. Nobody on this forum is that funny.
Why am I in your signature.
CastIron is offline
Old 12-23-08, 05:59 PM
riddei
Needing more power Scotty
riddei's Avatar
Bikes: 2006 Trek T-80 (commuter) 1982 Bianchi SS (classic 12 speed)
If you are talking about your chain, this is what I do in the winter Winter Chain Cleaning/Lube.
If you are talking about the rest of you bike, I wipe it down with a rag, and that's about it...
riddei is offline
Old 12-24-08, 04:54 AM
mike
mike's Avatar
Ya ya. I have been full circle - citrus degreasers, Simple Green, and then foam engine degreaser.
The best is the foam engine degreaser.
HOWEVER, I found the most economical solution was to fill up an old spray bottle with kerosene. This works EXCELLENT and is cheap enough that you don't have to think about it. Just keep squirting until the parts are clean.
PS; don't waste your money buying degreasers at a bike shop. That's crazy. Go down the street and get stuff like that at a hardware store. Use the money you save to buy a latte at Starbucks.
mike is offline
Old 12-24-08, 04:50 PM
3bikes
VeloFellow
3bikes's Avatar
Bikes: Commuter(Specialized Globe 6,IG8), Mountain (Specialized FSR), Road (Felt F55-2006)
One product I've used for years is "Pedro's" Biodegradable De-Greaser. It's a pump-spray bottle, works pretty good and I haven't noticed any problems on my paint or aluminum finishes. (Note: This is a spray on-hose off sort of cleaner, but I use a soft cloth afterwards to prevent splotches and haze)
Just a suggestion.
-3Bikes
P.S. Don't forget to use chain lubricant and rust protecter on brake calipers, axles, gears..... that sort of thing.
3bikes is offline
Old 12-25-08, 08:51 AM
jcm
Gemutlichkeit
"PS; don't waste your money buying degreasers at a bike shop. That's crazy. Go down the street and get stuff like that at a hardware store. Use the money you save to buy a latte at Starbucks."
+1 on the de-grease, but I'd just go get a couple 3lb cans of Folgers at the grocery store instead of Tarbucks.
jcm is offline
Old 12-25-08, 01:14 PM
mike
mike's Avatar
In fact, I agree with you about the coffee. I was being a little sarcastic about going to Starbucks for a latte. Frankly, I find Starbucks to be just ghastly coffee. Folgers made at home has a lot less tannins and better flavor - but it is all what you get used to. I remember having a breakfast coffee at home. My son asked me to stop by Starbucks on the way to drop him off at work. The coffee cost him nearly $7.00 for his foo-foo coffee = that is one hour's work for him. 13% of his total day's wage for a cup of coffee. Latte... that means "Milk" doesn't it? I have that in the fridge too. If nobody's looking, I MIGHT even use the left-over milk from my Captain Crunch cereal in my coffee. Would that make it a Le Cap'n and Latte Mocha?
mike is offline
Likes For mike:
Old 12-25-08, 02:01 PM
CCrew
Older than dirt
CCrew's Avatar
Sorry, can't get used to Folgers no matter how cheap it is. Reminds me of ground pencil shavings.
Dunkin Donuts ground made at home here
CCrew is offline
Old 12-25-08, 07:11 PM
mike
mike's Avatar
Oops, I think this thread has been hijacked. Anyway, I will have to try the Dunkin Doughnuts coffee. Sounds promising.
mike is offline
