Heliomatic thread repair?
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 428 Times
I was going to replace a chain and chainrings…. One thing leads to another….
Heliomatic hub threads won’t catch the lock nut when the freewheel is installed. The lock nut will run down by hand on the threads without the freewheel. So I think they are ok.
Is there an olde timey trick for repairing the hub? Or do I need to go in search of a replacement hub? …and rebuild the wheel….<crying emoji>
Like maybe a NOS Shimano…
Thanks.
The French don’t copy anybody. And nobody copies the French!! — Click & Clack
Thanks.
Friendship is Magic
Bikes: old ones
Quoted: 26418 Post(s)
Liked 10,380 Times
...the old timey trick with which I am familiar is to throw them away, and construct a wheel, using a better hub. But I would try a different locking ring on there, before I gave up on it. Those lockrings are pretty cheesy, and I would presume the threads inside that would give out before the ones on the freehub body. I've tried never to get emotionally attached to a Helicomatic hub, and it's worked, pretty much.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
It looks like the outermost lockring threads on the hub are worn away, leaving only the innermost threads to engage the lockring. When the freewheel is installed, the lockring cannot thread far enough to engage the undamaged threads.
There is no easy fix for this. You could use JB Weld or bearing seating compound to secure the lockring in place, but that could make removing the freewheel difficult or impossible. Consider replacing the wheel.
Likes For JohnDThompson:
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
In the last five years I've rebuilt two 1983 Treks that came with Helicomatics. A different set of wheels was my first task on both.
Hang on to the bottle opener, though. It much classier than the one that comes in the Park tool kits.
Sure looks like the threads on the Helicomatic hub are stripped/worn away. Can't imagine the lock ring in much better, looks like time for a new hub set up to me.
Likes For Steelman54:
Yup, fully agree! While lots of issues are “fixable” on older bikes (even French ones ) this doesn’t look like one of them. I would however, totally disassemble the entire wheel, saving the rim, spokes, axle (& even the bearings) before tossing the hub in the recycle bin! If fortunate enough to find a hub with the same dimensions, it would just be a matter of relacing it to the OEM rim with the OEM spokes. If that’s the plan, remember the spokes on the drive side are slightly shorter than those on the Non-drive side.
Likes For sovende:
buy my bikes
Quoted: 519 Post(s)
Liked 428 Times
Thanks everybody! I was afraid a new hub was the way I was going to have to go.
Probably (more than a 50% chance) - I will go this way: https://velo-orange.com/collections/...heel-hub-126mm
Or I'll look for a deal on eBay: maybe make an offer on this - love me some DuraAce!
https://www.ebay.com/itm/16556616419...cab8%7Ciid%3A1
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3887 Post(s)
Liked 6,482 Times
I still don't understand why the lockring will thread on without the freewheel in place. I would keep trying.
That's the way to go for a budget build. Just look for a similar Maillard (non-Helicomatic) hub. I'd ask in the c&v "ISO" sticky thread.
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
100% would not go Uniglide, a standard freewheel would work and the VO would probably be a good option if you didn't want to go Phil Wood or say a vintage Dura Ace 7400. You might also find a slightly more modern freehub and swap out the Uniglide freehub for a Hyperglide and since the system you have is likely friction you can run a more modern 7 or maybe 8 speed cassette.or possibly higher.
Likes For veganbikes:
Old fart
Liked 3,400 Times
señor miembro
Liked 6,482 Times
I wouldn't want to own one of these hubs, but if this were a flip and the freewheel cogs were good, I would try to fix the threads before changing the hub. Use WD-40 and work that lockring back and forth. Use an iron file with a sharp edge on the thread spacing. Sand the base of the freewheel possibly. Anything...
buy my bikes
Quoted: 519 Post(s)
Liked 428 Times
Originally Posted by SurferRosa;[url=tel:22593038
22593038[/url]]I still don't understand why the lockring will thread on without the freewheel in place. I would keep trying.
you can see how the lock ring is sitting up higher with the freewheel in place when you look at the lock nuts.
the threads are just too far gone for the lock ring to threads and lock.
i might JB weld it in a couple spots until I get a 126mm replacement.
The threads look pretty good if anyone wants a lock ring! Hurry, it’ll be stuck soon!!
señor miembro
Liked 6,482 Times
You're basically just discarding a valuable vintage component by using the very short-term solution of JB Weld. These lockrings can go for $25+ on eBay. And then it makes it far more difficult to save the drive-side spokes. If you have a bike co-op, a replacement hub can be easily found.
Likes For SurferRosa:
If you're really insistent on using an adhesive-based solution, you might want to try one of the stronger Locktite products first. They're designed to allow the item to be removed later, at least in theory. JB Weld is fairly permanent.
Likes For Hondo6:
