How can I tell when my hydraulic disc pads need to be changed?
Old 08-09-22, 01:10 PM
Route 66
Route 66's Avatar
Bikes: Spot ACME with Shimano Alfine 11 & Gates Carbon Drive
Quoted: 34 Post(s)
Liked 64 Times in 21 Posts
My Spot ACME bike has Sram Level hydraulic brakes on it and I'm wondering how I will know when it's time to swap out the disc pads for new ones. I do have a set of calipers and a micrometer and can measure both the mounting plate's thickness and the pad material's thickness if that happens to be the first step.
Any input will be helpful.
Route 66 is offline
Old 08-09-22, 01:21 PM
rumrunn6
rumrunn6's Avatar
Quoted: 4783 Post(s)
Liked 2,591 Times in 1,754 Posts
I don't have the same brakes, but ...
I asked the same question a cpl years ago but never really got a definitive answer, other than don't wait to hear scraping metal sounds
I've changed mine twice since then. neither time did they look excessively worn
for me, I'll do it if the brake is making noise or there's a noticeable loss of performance, like from some kind of contamination - even after checking wheel alignment & cleaning the rotor
it was interesting to see that the inner & outer pads wear differently
old vs new
honestly don't remember what exactly these pics are that I took
rumrunn6 is offline
Likes For rumrunn6:
Old 08-09-22, 01:39 PM
Rolla
Groucho Marxist
Quoted: 1230 Post(s)
Liked 3,043 Times in 1,328 Posts
Yep -- pull the pads out and measure them with calipers. The Level manual says "When the thickness of the backing plate and pad material is 3 mm or less, they are worn and need to be replaced with new disc brake pads."
https://www.sram.com/globalassets/do...d-shifters.pdf
Rolla is offline
Likes For Rolla:
Old 08-09-22, 02:53 PM
easyupbug
Quoted: 450 Post(s)
Liked 386 Times in 286 Posts
I use 1mm pad thickness a a replacement point on bikes and a trike, I inspect often.
easyupbug is offline
Likes For easyupbug:
Old 08-09-22, 05:09 PM
Route 66
Route 66's Avatar
Quoted: 34 Post(s)
Thanks for all the helpful answers guys.
I have a follow up question too: what's the best way to clean the rotors before I install the new pads?
Route 66 is offline
Old 08-10-22, 08:27 AM
easyupbug
Quoted: 450 Post(s)
I use isopropyl alcohol because I am retired and so have the time to do it often before they get bad and it does not leave anything on the surfaces. I also don't get anywhere near my rotors with a spray of any kind. A tiny bit of mist of a chain lube or general lube of any kind can give you a mess very quickly.
Old 08-10-22, 08:56 AM
Route 66
Route 66's Avatar
Quoted: 34 Post(s)
Thanks for the reply. Are you able to clean them with the alcohol while they're still on the bike, or do the rotors have to be removed from the wheels first?
Route 66 is offline
Old 08-10-22, 09:00 AM
rumrunn6
rumrunn6's Avatar
ha! that must be why I also have these 2 pics of old pads prior to replacement
wish I could find that thread of mine from a cpl years ago ... found it!
rumrunn6 is offline
Likes For rumrunn6:
Old 08-10-22, 09:02 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Bikes: Stewart S&S coupled sport tourer, Stewart Sunday light, Stewart Commuting, Stewart Touring, Co Motion Tandem, Stewart 3-Spd, Stewart Track, Fuji Finest, Mongoose Tomac ATB, GT Bravado ATB, JCP Folder, Srewart 650B ATB
Quoted: 3641 Post(s)
Liked 2,584 Times in 1,623 Posts
We use steel wool first and follow up with alcohol leaving the rotors on the hub for easier holding of them and less time (but we do check the mounting hardware just in case) Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
