Fall / winter jersey / jacket reco for long arms?
I am at the point of just simply wearing my summer hear with arm warmers. I have not met a long sleeve jersey that would go down to my wrist and stay there. The only thing I have that does this is Pearl Izumi jacket with thumb loops. Need something that would be race cut, warm and long in arms without going XXL. Ideas?
I wear a 37-38" shirt sleeve length, yet am thin enough to need a size medium. These all have sleeves that work for me:
They don't necessarily go all the way to my thumb, but close enough that I'm happy with them. Particularly the Santini, which has really good wrist coverage. I also wear thin wrist gaiters to close the gap to my gloves, and it's a winning combo. In particular, I like these a lot:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The Santini COLORE PURO - THERMAL JERSEY fits me great. I've tried other Santini jerseys that didn't work quite as well, so those can be hit & miss—but they honor returns. Good luck!
Edited to add: for jackets, I love the Santini Adapt for 32-60 degrees Fahrenheit. Bontrager Softshell also has sleeves that work for that temperature range. For below freezing my Bontrager Velocis S2 Softshell is ridiculously warm. Note that the two Bontrager jackets I mentioned do not have wind protection, so you'll need to include something windproof (I usually use a GORE Windstopper base layer which does the trick). The Santini Adapt is windproof (and water resistant) so you can use a thinner base layer that isn't necessarily windproof.
The two Bontrager jackets are old model years, and probably aren't available. But worth seeing what they launch for the cold-weather season since their sleeves are long enough..
This year I'm going to see if I can afford an Assos Johdah (pronounced "Yoda," apparently no kidding named for the Star Wars character). It is supposed to be the very best out there according to reviews. At $700, it'd better be!
Likes For GGDaddy:
Quoted: 6944 Post(s)
Liked 10,944 Times
All of my Rapha LS jerseys have rather long sleeve lengths..And the company does free shipping and free returns -- so no risk in trying it.
Quoted: 18883 Post(s)
Liked 10,646 Times
Arc'teryx Kyanite AR. Size down. Thank me later.
Quoted: 20808 Post(s)
Liked 9,450 Times
I was going to mention the same. I'm 5'11" with longish arms and my M LS jerseys are more than long enough. No issue with my Core Winter Jacket, either, though the sleeves seem a little shorter, proportionately, compared to the LS jerseys.
Bikes: SL8 Pro, TCR beater
Quoted: 981 Post(s)
Liked 583 Times
I have the Oakley thermal jersey and it's warm and comfy (I am OK at 5c (40f) temperature). True to size.
Bought the Essential Road Mid Long Sleeve from POC last week, it is less warm for sure. Should be OK for 10c (50f) temperature.
Quoted: 3241 Post(s)
Liked 2,512 Times
Just clarifying for the OP. Are the sleeves not long enough? Or, they're long enough but slide up the arm?
Just not long enough. I am 190cm and 75kg. Typically wear size L race cut clothing on the bike. But I have long arms and when stretched on the bike, this is amplifies the issue.
The only one that I have found that works for me is the Pearl Izumi PRO.
Looking to try others.
Quoted: 528 Post(s)
Liked 230 Times
Do you have to wear something cycling specific?
Personally if it isn't that cold, I just wear normal jersey with arm covers, and then when it does get cold a long sleeve sports shirt (I have one from Nike, and one from Oddlo that I also use for XC skiing) and a yellow high viz jacket that is also wind and rain proof. And if that's too cold, I don't ride outside. Although to be fair I hardly ever even wear that, I just use the trainer for half a year or so.
Likes For ZHVelo:
Liked 2,512 Times
Liked 10,646 Times
Likes For Seattle Forrest:
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1246 Post(s)
Liked 1,273 Times
No idea if the Kodiak is still available though.
Liked 10,646 Times
This works fantastically to add maybe 10* F. Goes between your base layer and jersey. Extremely breathable, dries quickly, anti stink works well, it's incredibly versatile, also soft and comfy.
Liked 10,944 Times
