32 mm tires that can climb in steep & sandy conditions
meh
Quoted: 1110 Post(s)
Liked 1,013 Times
I'm working on a long-planned adventure ride - climbing Mauna Kea. The bike for this adventure can take up to 32 mm tires. The climb starts with 34 miles of climbing, going up over 9,000 ft, on pavement. The last 8 miles (4,500 ft) of the climb is gravel with loose sandy sections with grades kicking over 15%. My bike has great gearing for climbing a wall (33/32), but I want a tire that will give traction on soft sandy climbs.
My first pick-thought is GravelKing SK 32mm - I know they are very popular with the gravel folks I ride with - but I don't know my 'narrow' gravel tires very well (my typical gravel bikes roll on 700x45 and 26x4).
Let me know your thoughts on 32mm tires that can ride both pavement and soft sandy climbs. Thanks!
Quoted: 507 Post(s)
Liked 237 Times
Ehh, how sandy are we talking? If it's sandy enough to sink in, then 32mm will be a pain even with a tread. You'd want a wide contact patch for that; it's more about bike control than grip at that point. If it's closer to 'a little bit of loose sand' than you should be fine. FWIW the GK SK are fairly grippy, just a hair more grippy than XPlor MSOs in my experience. I ride the 40mm version and usually have no problems unless the sand is deep enough for the tire to sink. You'll need to watch out on descents more so then on climb.
Another one to look at would be Vittoria Terreno Dry. I really wanted to get a set of them but they were on backorder for weeks; should be a faster-rolling tire than GravelKing but nearly as grippy. Not sure what the stock looks like this year. And, of course, there's the Schwalbe G-One and the various offerings from WTB though not all are made in 32mm.
Just for reference, this kind of stuff is perfectly doable on 28mm slicks but you do have to be careful especially on steep terrain; 32mm tires with tread would give you much more confidence.
Likes For autonomy:
Randomhead
Liked 3,687 Times
The 32mm SK might be large for a 32mm, anyone know? Which dimension is the limit on this bike?
I probably would get the GK+ file tread 32mm if it's just sand.
Quoted: 1455 Post(s)
Liked 1,477 Times
There really aren't a lot of 32mm knobby tire options out there, and for a 15% loose surface climb I would definitely want some tread, and as wide a tire as would fit.
32mm Gravel Kings are probably a top choice. If you can squeeze in 33mm, there's a bunch of CX specific tires out there that might work. Two of my favorites:
https://www.challengetires.com/shop/...s/dune-2/55047
https://www.donnellycycling.com/coll...ready-clincher
35mm Conti Terra speeds seem to measure a bit small on some rims, so they might be an option if you can squeeze them in.
Likes For msu2001la:
Likes For tangerineowl:
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
well, I'm thinking any 33mm CX tire should work unless you are really tight. I've used Schwalbe G-One in their CX version, and they are about the size of my 32mm tires.
That said, I spend most of my skinnier time on Conti GP5000 slicks (32mm). Personally, I've worked on developing a smooth pedal stroke and can do just about anything with slicks, short of real greasy stuff (wet rocks, roots, grass).
There are 30mm CX tires too (or used to be). some are mud some are semi-slicks for gravel riding on traditional road bikes.
Speed max:
https://www.levelninesports.com/ritc...xoCHqwQAvD_BwE
You thinking tubless?
Speed max:
Likes For chas58:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Challenge Dune (small shoulder knobs, running along a diamond file tread) or Chicane (bigger shoulder knobs running along a diamond file tread). The Chicanes were my go to tire for several years riding loose to chunky (not boulders, but bigger rocks) gravel. I'm login to run the treads off the Spesh Pathfinders my bike came with, then mount the Challenge Gravel Grinder (essentially a Chicane, in bigger volume). The tread is durable and hooks up well. I've never ridden on the big island, but I recall the "gravel" was sometimes treacherous with the volcanic rock, I'm sure you're taking this into account since it may chew up the tires pretty good, depending not he surfaces on the road you will ride.
Likes For Badger6:
meh
Liked 1,013 Times
Speed max:
Speed max:
I might go tubeless, but it's not required either.
To an earlier post, I don't know the conditions well, but from other ride reports, I understand it'll be dry powdery sand. I understand road tires will not be able to make the gravel climbs. I'm no stranger to steep gravel climbs*, just nothing this long or at this altitude.
* I've been riding gravel races for 10 years and see a wide variety of gravel conditions. The bike I plan to bring to Hawaii is not my typical gravel bikes, I have a Bianchi Infinito, it won't take a wide gravel/CX tire (max 32-33 mm). With a good tread that rolls well on the pavement sections, and offers traction while climbing loose sandy gravel. As I posted in the OP, I've got the gearing to stay in the saddle and spin, keeping weight on the rear wheel and avoid spinning out.
Likes For Hypno Toad:
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 238 Times
You might want to look at the schwalbe X-one bite or michelin cyclocross power
Liked 415 Times
Likes For chas58:
Thread Killer
Quoted: 3129 Post(s)
Liked 1,698 Times
Quoted: 722 Post(s)
Liked 353 Times
very affordable.
Quoted: 532 Post(s)
Liked 621 Times
Quoted: 264 Post(s)
Liked 238 Times
Otherwise, it is just hard pack gravel...
Quoted: 427 Post(s)
Liked 339 Times
Likes For dwmckee:
Liked 415 Times
I use the Schwalbe - they are fast rolling tires with lots of grip. Especially when they are broken in (obviously when I'm torqueing down on 1000+ watts, those knobs are gonna distort, but they are fine for <500watts or when worn down a little).
I've seen some of the Michelin's - but it seems the sub 33mm tires are mud oriented. That said, the knobs are pretty short. The power Jet tire looks great if it comes in the appropriate size.
meh
Liked 1,013 Times
Too funny, I found a great ride report here on BF ... but found it thanks to Google:
https://www.bikeforums.net/road-cycl...nd-hawaii.html
5 Miles of Unpaved Road, Just Because
Having read about it online, I knew the next 5 miles immediately after the visitor center were unpaved gravel. I also knew it was probably the toughest part, which is really why you bring a gravel bike instead of a road bike if you plan on making it the whole way on a single steed (as opposed to using a road and mountain bike for example, which is what some people do).
All that being said, I still grossly underestimated how hard it would be, especially when paired with the 9,000ft+ elevation and the fact that it ascends 2,600ft. Some sections in there felt like 15% incline, and many of those proved to be too much even for my 33mm Specialized Trigger tires.
I should also explain here that what’s being described as “gravel” is really more powdery ashes. If and when you hit a patch of it, there’s very little traction to be had! The net result for me was that I fell 3 times on my side and would have fallen 2 times more, had I not been quick enough with my unclipping. Luckily I was only going 3mph or so, so only my ego got hurt
I am now aware there is a lot of technique involved in tackling gravel (or powdery ashes) climbing. I personally have nearly zero experience on mountain bike so, while it may be obvious to others, I had to learn to keep a good amount of weight on the rear wheel as I slowly pedaled my way up, all the while zigzagging to find spots with the least amount of loose ashes.
Quoted: 507 Post(s)
Liked 237 Times
Quoted: 264 Post(s)
Liked 238 Times
As you are limited by the size, this is why Xone bite is a good option. you could look at G one Ultrabite too which it pretty similar however made for gravel so wider. Either way, you need the most aggressive UCI Cyclocross tyre to get the grip and remain within 33mm max.
I used to ride rocky hill which a mixture of shingle cotswolds stones, mud, sand and according to Strava 16% on panaracer comet 38-622 and the wheel was slipping a lot, that was "OK" for 100 to 200 meters but I would not do that for 8miles.
I remembered the XC setup I had 20yrs ago, check for evolutions and swap the tyres for Conti XKing front (all season) and Conti XKing rear (deep wet muddy winter) or RaceKing rear most of the year, I got up these hills without issue now.
Point being your las 8 miles are MTB-XC territory and is going to be the hardest so you have to compromise; with MTB "knobblyness", you will be slower on road tarmac but you will have a chance on these 8 last miles.
Likes For Fentuz:
meh
Liked 1,013 Times
The long story short, I didn't ride my Infinito, but rode my gravel bike on 50mm GravelKing SK ... and they were overkill and I never got them on the unpaved part of Mauna Kea. Here's a link to my ride report with all the details
https://bikesbeersstuff.blogspot.com...rld-mauna.html
Sunshine
Quoted: 10947 Post(s)
Liked 7,474 Times
So if the hardest ride is going one way, then the easiest route in the world is going the other, right? That route sounds like one I could handle!
Quoted: 425 Post(s)
Liked 454 Times
Glad you made it happen. Sorry you were overbiked. I guess since this was a special trip it was better to be over-prepared than under-prepared, anyway.
Likes For tFUnK:
meh
Liked 1,013 Times
Frau Toad is almost more interested in returning to this challenge than I am ... LOL. We were just talking this morning about the pro & cons of the Bianchi vs the Breezer. The Bianchi will be an asset with better gearing for the steepest ramps, and is much lighter to haul up the 45 miles getting to the short segment of unpaved road. I'm serious considering the revisit will be on the Bianchi and accept there will likely be some walking on the unpaved segment ... I think I'd end up walking anyway, only the fastest riders are going more that 5 mph so walking isn't sacrificing that much speed.
For reference: there is 4.65 miles of unpaved roads, starting at the visitor's center (9,200 ft); the last 2.5 miles to the summit is paved, and VERY steep, at high altitude. The whole segment from the visitor's center to the summit averages 11.4%, and kicks up to 20%.
Bikes: Waterford RS-11, Giant Talon 2
Your blog is correct about Waikaloa beach access. We once stayed in a condo there, but even as a legitimate guest I felt like a burglar walking around that resort.
IIRC there's public access all along the waterline and even some historic sites, but you wouldn't know it.
Likes For KWillets:
