Help with chain sizing
Old 02-14-23, 07:52 PM
bonsai171
Quoted: 750 Post(s)
Liked 90 Times in 70 Posts
Can someone tell me how to size a fixed gear chain? My current one is stretched, and I want to be able to switch from a 16t to a 17t (my current chain is too small).
dave
bonsai171 is offline
Old 02-14-23, 08:14 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,928 Times in 2,553 Posts
Easy way? Don't take the chain off. Get the 17. Screw it on. Try the wheel. Does it fit in the dropout? Do you like where it sits? Does the dropout allow you to move the chain in say 1/4" in both directions? If yes to all, simply "cut" your new chain to the same length. Don't even bother to read the rest of my post.
If the wheel sits too far forward in the dropout, see if there is room to slide the wheel back 3/8". (Two links of chain will allow the wheel to go back 1/2". One link on the upper chain run, one on the lower. The added cog tooth takes up 1/2" but that is split between the front and back, then again on the upper and lower runs so 1/8" per tooth.)
Or just look. Is the wheel 1/8" further forward OK? Go the same length. Add two links and it goes back 3/8" Or if you are using 1/8" chain (old fashioned single speed chain) you can go to a hardware store and buy a "half link" - one that is male at one end and female at the other. Single speed/fix gear shops will also have them but most other shops won't. A half link will alter the wheel position 1/4"
Edit: your stretch is almost certainly no more than 1/8" in 12 inches. Fix gear/single speed - roughly 100 links = roughly 4 feet so 1/2" total stretch. Divided by two for top and bottom runs = 1/4". You can measure the stretch easily with a regular steel tape measure. measure pin front to front of the pin 12 pairs of links away, Brand new chain - that is 12" exactly. Everything over that 12" is your "stretch". So the wheel will need to come forward roughly twice your "stretch" when you put on the new chain before you look at the cog size change. Again, do you like where the wheel (and axle nut) will be sitting after you move it forward?
79pmooney is offline
Old 02-14-23, 08:49 PM
bonsai171
Quoted: 750 Post(s)
I'll have flip the wheel around tomorrow and take some measurements. The 17t is already installed, so maybe I can measure where the 16t is from the front of the dropout, flip the wheel, set it another half inch back from that point, and then add half links (maybe 2)?
Old 02-15-23, 06:25 PM
bonsai171
Quoted: 750 Post(s)
Out of curiosity, what is the original application for the 1/8" half links at the hardware store? Would be cool if I can find that, don't know if there's any fixed gear or single speed bike shops around here, but there's a hardware store just down the road.
Dave
