Tire Tread Aerodynamics
Habitual User
Quoted: 4946 Post(s)
Liked 8,085 Times
As I was riding this past weekend, observing my front wheel spinning below me, it occurred to me that nothing on my bike was moving faster through the air than the tread of the tire at that moment. I also realized that I hadn't read/seen anything discussing the effects of tire tread on aerodynamic drag. I would think the difference between a 25mm road tire and a 2.25" MTB tire would be somewhat significant because of both width and tread. Looking at just high-end road tires, how much difference would there be between slight variations of shallow patterns in what is considered a "slick" tread (Conti GP5000 vs. Pirelli P-Zero, for example)? Is it completely inconsequnetial, or are there a few watts difference?
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Likes For Sy Reene:
Perceptual Dullard
Quoted: 918 Post(s)
Liked 1,152 Times
DT Swiss have just been granted a patent on tire surface pattern.
https://bikerumor.com/dt-swiss-swiss...d-tire-patent/
Likes For RChung:
Habitual User
Liked 8,085 Times
To get you started: https://www.swissside.com/blogs/news/gravel-report
Quoted: 9653 Post(s)
Liked 6,365 Times
My P Zero Race TLR SL have a couple of gloves running in the direction of rotation. 15 watt advantage, at least.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1947 Post(s)
Liked 1,468 Times
Summary: JP Ballard from Swiss Side stated that Continental GP4000S II tire has sidewall and tread that improves transition of boundary layer from laminar to turbulent flow.
More recently (GP5000 vs. TT): Tire dependence for the aerodynamics of yawed bicycle wheels - ScienceDirect
Likes For SoSmellyAir:
Habitual User
Liked 8,085 Times
Likes For Eric F:
Likes For surak:
Quoted: 1277 Post(s)
Liked 1,392 Times
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Aero depressions?
Yeah, we've all been there. It's ok to talk about it.
Likes For znomit:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
The bottom of the tire is going 0 so it pretty much cancels out.
Jan Heine stated in an article that fenders over the top of the tire confer an aero benefit but I’m not going to Google it right now.
Genesis 49:16-17
Genesis 49:16-17
Quoted: 2333 Post(s)
Liked 2,097 Times
And attaching a samsonsite size handlebar bag is also faster when times with a GPS device once. And steel turns a bike into a plane. Wool is faster. Notice the picture of the fender in Heine's photo, It is as long as an elephant's snout. I have never seen such a snout on a bike in the wild. He also claims really fat tires are faster and I suppose professionals some day will ride 48 mm tires.
Liked 2,097 Times
Tire/rim interference can be measured and can easily be felt from wheelset to wheelset with variation of tire width thrown in.
Yes, a 1 inch wide tire has more area than a 2.25 inch tire. The fat tire is also taller. No rim is going to overcome that difference in the CdA department.
Quoted: 6193 Post(s)
Liked 4,809 Times
How concerned about aerodynamics are the people that don't ride paved roads? Or why would anyone that rides a paved road have much of any tread pattern on their tires?
Perceptual Dullard
Quoted: 918 Post(s)
Liked 1,152 Times
[Edited to add:] By "we" I meant, Tom Anhalt and I. I wasn't using the Royal We.
Likes For RChung:
Disco Infiltrator
Liked 2,105 Times
Liked 1,468 Times
That was a pretty puzzling result: he said that max speed was higher with the handlebar bag than without. It turns out that he'd recorded the ride on Strava so we downloaded his data file and looked at the speed. His max speed with the handlebar bag was a one-second anomaly where it jumped up by a couple of mph then in the next second it returned to normal. Without that one-second point, his max speed without the handlebar bag would have been higher. So his long blog post about the aero benefit of handlebar bags was based on that. We commented on his blog post explaining the one-second anomaly and he removed our comment but left the blog post up. (His GPS device was the iPhone he had in his pocket).
Liked 1,468 Times
Quoted: 3949 Post(s)
Liked 7,296 Times
Habitual User
Liked 8,085 Times
I'm learning here that even the minimal tread pattern (if you can even call it that) on high-performance road tires makes some difference.
Liked 2,097 Times
When some asked for data, he just closed off all comments and never provides raw data. But the results stand. Steel planes, suitcases are fast, fat tires are faster (settled) and snouty fenders are also fast. I am no diplomat and I no believe his results.
At least Flo and Swiss side will provide enough info that you can confidently say the 23mm GP4000 was the fastest tire on the Flo60 for some speeds. And the explanations make sense.
Liked 7,296 Times
I reached 47 mph in my last gravel race, and I didn't get close to the podium. Do you think aerodynamics might matter to fast riders?
Quoted: 4806 Post(s)
Liked 3,928 Times
So when are they going to figure out what the airplane folk got a long time ago? Cover or hide those wheels. Forget faster tread. A full faring is faster. (For a brief time, planes with fixed landing gear and teardrop bubbles over the wheels were popular. Then it was deemed better to hide them entirely inside the wing or fuselage when not in use despite the added weight and complexity.
I won't buy a fully faired bike. Just bringing this up to point out that optimizing tire tread is going after the small stuff.
Habitual User
Liked 8,085 Times
